casainho   10 GW
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by casainho » Jun 06 2019 4:59am
thineight wrote:
Jun 06 2019 1:46am
I do not understand why you mention that the bike can start at high speed/power as the values are set quite low for the various assistance levels, perhaps I miss some tips in the coding itself.
I am being using walk assist mainly on mountains. I found that a value of PWM duty cycle we set for walk assist on a flat terrain is very different from the one on mountains -- we need a very high value on mountains and if we use that value on flat, by mistake or just because we need first to try to see if it is ok or not, the bicycle will simple go off very fast and that is dangerous.
When I had to use walk assist on a steep stairs (or big rock), because on uneven of the stairs, I had wheel running very fast sometimes to just after run at the speed I need -- when the wheel loses traction momentarily, will run at very fast dangerous speed. And when it gains traction again, the energy on the wheel from being rotating such fast, gives a strong pulse of force forwards and all this makes hard and dangerous to keep on control of the bicycle.
I think walk assist is a must to have and I prefer to have as it is however I know it is dangerous and for that reasons I don't want my 9 years old son to use it.
I think it must have a speed and power controllers as also soft start. As user, I want to configure the speed and max power(currently max power is like 900 watts on walk assist!!). For steep hills and dangerous terrain I would go with low speed like 4 or 3 km/h. For the power I would configure some low value like max of 200 watts and usage will depend on the weight of the bicycle, if I pull myself on the handle bar and the inclination.
- TSDZ2 OpenSource firmware
dameri   100 W
Post by dameri » Jun 06 2019 8:57am
I have 36V and 250W motor.
Menu 9:2 standstill and pedals horizontal 40
Driving without assist and light power 55- 57 at start 67
thineight   100 W
Post by thineight » Jun 06 2019 10:31am
dameri wrote:
Jun 06 2019 8:57am
Interesting, compared to mine the absolute values are different but the delta is similar (17 in your case Vs 20 for light pedaling and 27 Vs 30 for higher torque).
I'm curious on how buba intends to utilize these info..
MTB KTM Ultra 29" - City bike DAYTONA 28"
dameri   100 W
Post by dameri » Jun 07 2019 2:06am
thineight wrote:
Jun 06 2019 10:31am
dameri wrote:
Jun 06 2019 8:57am
Do you have same motor as I have? I think values may be different if motor power changes.
I checked readings few times.
thineight   100 W
Post by thineight » Jun 07 2019 3:50am
dameri wrote:
Jun 07 2019 2:06am
thineight wrote:
Jun 06 2019 10:31am
dameri wrote:
Jun 06 2019 8:57am
I have the 36v too.
I think the reading at rest is just the number from the torque sensor, not dependant on the motor type. Also the "work" reading, being taken at assistance 0, should be independent from the motor voltage.. maybe just the actual gear and the internal friction can vary the number.
I guess buba would like to understand the reading range to see if the resolution is sufficient..
dameri   100 W
Post by dameri » Jun 07 2019 4:03am
thineight wrote:
Jun 07 2019 3:50am
dameri wrote:
Jun 07 2019 2:06am
thineight wrote:
Jun 06 2019 10:31am
dameri wrote:
Jun 06 2019 8:57am
I have the 36v too.
Okay, I was just quessing. I don't understand very much electric motor technic. I think too buba understand, because he asked readings.
I check values again today.
buba   10 kW
Post by buba » Jun 07 2019 2:31pm
dameri wrote:
Jun 06 2019 8:57am
Thank you very much, dameri!
So far we have:
Standstill/ADC pedal torque sensor
thineight: 48-49
dameri: 40
buba: 51
StartUpTorque/ADC pedal torque sensor
thineight: 78
dameri: 67
buba: 82
RidingTorque/ADC pedal torque sensor
thineight: 70-71
dameri: 55-57
buba: 75
I am most interested in the StandStill value. It is the only one that can be compared between different users. The other values only give an indication of typical values as they naturally have large variations. But data is king so I value your feedback highly! Thanks! I know it was tricky.
buba   10 kW
Post by buba » Jun 07 2019 3:13pm
thineight wrote:
Jun 07 2019 3:50am
Correct. Want to make a complete model of the torque sensor and am just testing typical min/medium/max. Possible improvements in the future:
* Error code if user has applied torque during startup.
* Error code if there is a broken torque sensor or with limited resolution.
* For users that have disabilities it is maybe more convenient to have a calibration function instead of calibration during power up.
* Increase resolution and account for non-linearity. This creates a better feeling when riding, even a better response. Bonus: More accurate human power.
* Able to have a smoother start with faster motor engagement without compromising safety.
Not promising anything but just wanted to fully explain why I inquired some values. This is maybe not a priority. But later on this will be one of many ways we can improve the system even more.
buba   10 kW
Post by buba » Jun 07 2019 4:05pm
A new beta soon to be released!
I had some time today to make the last changes and have already submitted the Pull Request. As usual, Casainho will review the changes and then release the beta for the community.
Changes:
* Have rewritten the button code for the entire system. No more bugs. If there are bugs it is very simple to sort out and change behavior now. Button logic for the user is still the same but faster and should be really solid. Much easier to adjust parameters and create new button events.
* Another benefit with the new button code is that we have gained memory space in the KT-LCD3. Biggest space gain from a "single" change so far!
* We have Street Mode now with simpler logic of operation.
* Possible to disable the throttle when in Street Mode.
* More space, less processing and better layout on the controller firmware.
* Overall changes in how the numbers are shown and so on. Better and more consistent experience throughout.
I have tried to make this version the absolute best so far, by a margin! And this will hopefully be very close to the stable version 0.19.0!
Here is the updated wiki:
https://github.com/OpenSource-EBike-fir ... ion-0.19.X
dameri   100 W
Post by dameri » Jun 08 2019 1:31am
buba wrote:
Jun 07 2019 4:05pm
Changes:
Nice work again buba :bigthumb:
thineight   100 W
Post by thineight » Jun 08 2019 3:02am
buba wrote:
Jun 07 2019 4:05pm
Great buba :bigthumb:
Looking forward to try that out!
Hope you sorted also the off-road mode key combination that was reading also tho ON and DOWN button pression individually.
buba   10 kW
Post by buba » Jun 08 2019 6:07am
dameri wrote:
Jun 08 2019 1:31am
buba wrote:
Jun 07 2019 4:05pm
Thank you, dameri! Hope you like it!
thineight wrote:
Jun 08 2019 3:02am
buba wrote:
Jun 07 2019 4:05pm
Thanks thineight!
That was one of the reasons I rewrote the button code. Was really hard to guess what button event to flag/clear and at what time to make it work perfectly. Timing problems throughout if a button event clearing is missed. Button events could end up not being registered. Or in the case you mention, too many events are registered. This happens very often when projects grow more complicated and you need to add more functionality to core functions. The core functions need to evolve as well and this time we had to evolve the button action management.
New button code:
- no local clearing,
- no timing,
- low execution time,
- better suited for 8 bit,
- easier to change button action times,
- easier to add new button events,
- smaller, more modular and simpler code,
- anyone can easily change the system behavior without much effort
- automatically resets every cycle so new button events are never missed, no need to power cycle
Grisha_lv   1 µW
Post by Grisha_lv » Jun 08 2019 8:35am
jbalat wrote:
Nov 04 2018 11:59pm
Just some testing on the inverse ramp factor to reduce lag
Hello,
I'm new to this forum. I just installed and flushed Kt-lcd3 with my TSDZ2. I also experience this lag which you have mentioned before and would love to fix if but I don't now how. I already checked WiKi and watched your video about it and still didn't figure it out.
It it's not too much to ask could you please step by step guide me what exactly I have to do.
How to compile?
How to flash if back to the controller?
P. S. I really like your videos about installing and flashing Kt-lcd3 with TSDZ2.
casainho   10 GW
Post by casainho » Jun 08 2019 11:06am
New beta version with the changes previous announced by Buba:
https://github.com/OpenSource-EBike-fir ... 19.0-beta8
andrea_104kg   100 W
Post by andrea_104kg » Jun 08 2019 2:56pm
just flashed version 19.8
Everything went well without any errors at the first flash
Tried only 300 meters near home for the arrival of the night.
- There is no resistance to backward anymore, I didn't care much about it, but that's fine
- There is no more the annoying leap forward if I kept my foot on the pedals and this is beautiful
- the attack and the detachment are immediate as always.
- reversed off-road - legal or street mode compared to 18.2, but it's just a matter of habit.
I would say that the 19.8 version for LCD03 now has a level of maturity equal to commercial softwares.
Strangely, after the flash I didn't configure anything, the old parameters were still present, n ° levels, battery capacity, etc. Possible?
Also because I tried to enter the configuration menu but the new menu logic is completely illogical for me and I didn't understand anything from the brief test done.
For now very happy even if the test was too short ...
thineight   100 W
Post by thineight » Jun 08 2019 3:52pm
buba wrote:
Jun 07 2019 4:05pm
Buba, since the street-offroad is now inverted, I guess there is a typo in the new wiki. In fact at menu 0-2 the wiki asks to input the max legal speed, which instead should be the max off-road speed as the legal speed is set in menu 8, isn't it?
buba   10 kW
Post by buba » Jun 08 2019 4:33pm
andrea_104kg wrote:
Jun 08 2019 2:56pm
Yes, Casainho solved it, nice to not longer work against the motor!
andrea_104kg wrote:
Jun 08 2019 2:56pm
Great! :bigthumb:
andrea_104kg wrote:
Jun 08 2019 2:56pm
Very possible and should be that way if coming from a recent version!
andrea_104kg wrote:
Jun 08 2019 2:56pm
This a common feeling when encountering the new logic for the first time. Please let me know if I need to clarify it some more anywhere or if there are any bugs.
* To enter the Configuration Menu, press and hold UP and DOWN buttons
* To navigate between different sub menus press either the UP or DOWN button
* To enter a sub menu, press the ONOFF button
* To exist a sub menu, press and hold the ONOFF button
* To navigate inside the sub menu press either the UP or DOWN button
* To change a variable inside the sub menu, press the ONOFF button and then increase or decrease the value with the UP or DOWN button
* To stop changing the variable, press and hold the ONOFF button
TIP: Whatever you are changing will be blinking to indicate that it is possible to change with the UP or DOWN button.
I know it might be difficult to understand at first. But I promise that it will be logical after some testing!
andrea_104kg wrote:
Jun 08 2019 2:56pm
:bigthumb:
thineight wrote:
Jun 08 2019 3:52pm
buba wrote:
Jun 07 2019 4:05pm
Well spotted and you are right! Thank you for taking the time to look through the wiki and report the typo! It is now corrected:
Dirkro   10 W
Post by Dirkro » Jun 09 2019 3:13pm
Hi, I have installed 19.8 on 36V motor and battrie
Thank you for this!!!
- I like the new button logic.
- The change from road mode to offroad mode I cannot real understand, because it is not logical to for me to swich to road mode through a button code.
It is running well in my opinion but following things we can think about:
- The calculated human power seemed to be too high
- The calculated cadence is lagging going up quite slow from 50 to my cadence (70 -80) . The pedal rmp are essential for calculation of human power basicaly (rpm* torque)*(2*Pi*60) ... hopefuly I am right...
I think the power calculation is much more faster than the cadence.
- The engine (36V - 36V )is working significant better in high cadence mode and much more responsive and and a bit stronger also in low cadence. Furthermore the in standard mode the engine get stucking at 85-90 rpm. Maybe the standard mode can be improverd.
Will try with an analog torque wrench to note readings (10, 20, , 30, 40,50 Nm) with correlating sensor readings.
Oh darling, this is not a new bike.. :roll:
buba   10 kW
Post by buba » Jun 09 2019 3:55pm
Dirkro wrote:
Jun 09 2019 3:13pm
Great! :)
Dirkro wrote:
Jun 09 2019 3:13pm
The change was done partly from feedback and partly to simplify the logic. Every time a user activates a function the system should be using the parameters that are set in that particular function.
But I think what you mean is that you wish that the Street Mode should be active from start and not through a button event. This can be enabled. Please take a look at the wiki under sub menu 8, Street Mode, and then 2, Active on system startup. Set to 1 to always have the Street Mode enabled when powering up the bike. Let me know if this helped in any way and sorry for the possible confusion!
https://github.com/OpenSource-EBike-fir ... treet_Mode
Dirkro wrote:
Jun 09 2019 3:13pm
I have previously given a few notes on the human power:
buba wrote:
Apr 28 2019 6:43pm
A word on somewhat accurate human power readings to the community: It is possible to define a complete system model. Starting with the torque sensor and measuring the output from known inputs in the complete defined operating range. The same is done on the rotation/cadence sensor. The two sensors define the system calculating the generated pedal power. If this is carefully calibrated and there is no large discrepancies between components in different units we have the foundation to a somewhat accurate power meter. Not saying anything about the level of accuracy. The hardest part is to create an algorithm that not only takes into account the lack of precision and resolution of the sensors but that also correctly models the power generated on a complete pedal revolution.
Another approach is the black box approach. We would have an accurate and known input (easier said than done) and measure the output of the complete system, meaning the two sensors combined. Thus defining the system response to different inputs. It would then be possible to map the sensor values to human pedal power values.
So in short, there is a need to study the hardware and make good enough sensor models and appropriate calibrations. All of which will aid in making a more accurate human power meter. If this is what the community wants.
This is not something that will be solved in the stable version 0.19.0. But maybe in the future. I like that you are willing to make some tests and would be very interested to see your results, Dirkro!
Dirkro wrote:
Jun 09 2019 3:13pm
I have also noticed this. Good that you mention it. This can be solved and improved in future versions!
jderb   1 µW
KT-LCD3 Issues
Post by jderb » Jun 09 2019 7:27pm
I just got a TSDZ2+KT-LCD3 kit for use with the Open Source Firmware. I can't get the LCD3 to boot after flashing. This has happened with 2 different LCD3s and 2 different motor controllers. Even when just plugged into the ST-LINK, the displays just hang in the "all bits on" stage. The second LCD3 was flashed by Electrifybike.com, where I bought all my parts. I think the second LCD3 did boot up properly once.
I'm sure I'm just making some stupid noob mistake, but it's driving me frikin nuts.
casainho   10 GW
Re: KT-LCD3 Issues
Post by casainho » Jun 09 2019 9:58pm
jderb wrote:
Jun 09 2019 7:27pm
That happens if you have brake sensors pressed. Maybe you have the magnetic brake sensors pressed??
jderb   1 µW
Re: KT-LCD3 Issues
Post by jderb » Jun 09 2019 10:29pm
casainho wrote:
Jun 09 2019 9:58pm
jderb wrote:
Jun 09 2019 7:27pm
Aha! You are my hero. Although the magnets are not yet installed, I disconnected the break sensors and it boots!
Uturn   1 W
1 W
Post by Uturn » Jun 10 2019 1:39am
what exactly is high cadence mode changing technically? I use a 48V motor, switched it on, but I do not feel much difference.
How does it work? Does it affect the efficiency? Why does the menu warn this might harm the motor? Why does the menu state the mode might not have any effect on 48V motors? My cadence ist not extremey high, I don't go often above 110 rpm. But I'd like to improve my cadence.
jbalat   10 kW
Post by jbalat » Jun 10 2019 5:25am
Grisha_lv wrote:
Jun 08 2019 8:35am
jbalat wrote:
Nov 04 2018 11:59pm
Hello,
How to compile?
Grisham I made one change to the variable using version 16 and that eliminated the drag for me. As I have not moved to any newer versions of the firmware I cannot comment as to whether it has been addressed or not. At the time boost mode was causing issues and had to be disabled. Perhaps someone else can answer. If this is fixed then you won’t need to compile it yourself.
Thanks
JB
Please subscribe to my Youtube home page for Quadcopters, FPV and Bike Rides http://www.youtube.com/jbalatutube
My build log here http://endless-sphere.com/forums/viewto ... =6&t=55352
For some cool ebike talk join us on The Best ebike https://www.facebook.com/groups/193581737807033/
Tech talk TSDZ2 Opensource firmware https://endless-sphere.com/forums/viewt ... &start=150
Opensource TSDZ2 Wiki https://github.com/OpenSource-EBike-fir ... _wiki/wiki
jbalat   10 kW
Post by jbalat » Jun 10 2019 5:53am
Uturn wrote:
Jun 10 2019 1:39am
Uturn, high cadence mode removes the maximum motor speed limit present in the code which then allows it to over spin, then it increases the amount of advance of the magnetic field to actually force the motor into going faster than its design speed, while this is considered risky by the developers it is referred to as field weakening and is a lot more common than you think. I have been running my 36v motor at up to 120cadence for more than 10,000kms now, I have not noticed any issues with the motor or less efficiency. It does indeed work for the 48v motor also. You will only know it is working if you peddle greater than 90 cadence, if it is turned off then it will be almost impossible to reach cadence of 100, when it is switched on it is possible to get to 120 cadence. Usually I can only achieve 120 if I am Pedalling like crazy just before I hit a jump. If I can’t hit this high rpm before hitting a ramp then it is impossible to get a good launch. I can also notice it when racing my friends, without it switched on the motor would lose power at an early rpm and force you to change into a higher gear which is frustrating, hope this helps, thanks JB
