TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
casainho   100 MW
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by casainho » Sep 10 2018 1:00pm
EndlessCadence wrote:
Sep 10 2018 11:56am
Funny how we all experience this issue but didn't talk about it before :D Yes I have the same problem but I thought it was because of the aforementioned setting. I think this behaviour is quite annoying.
I verified I changed PAS cadence calculation in a way it is fast to detect stop of pedaling and also is is slower to detect start of pedeling -- maybe if we go back to previous values it will work well again.
Can you guys go back to previous values on main.h file and test??
Previous:
Code: Select all
// PAS_ABSOLUTE_MAX_CADENCE_PWM_CYCLE_TICKS = (x / PAS_NUMBER_MAGNETS)
#define PAS_ABSOLUTE_MAX_CADENCE_PWM_CYCLE_TICKS  (6250 / PAS_NUMBER_MAGNETS) // max hard limit to 150RPM PAS cadence
#define PAS_ABSOLUTE_MIN_CADENCE_PWM_CYCLE_TICKS  (156250 / PAS_NUMBER_MAGNETS) // min hard limit to 6RPM PAS cadence
Current values:
Code: Select all
// x = (1/(150RPM/60)) / (0.000064)
#define PAS_ABSOLUTE_MIN_CADENCE_PWM_CYCLE_TICKS  (93750 / PAS_NUMBER_MAGNETS) // min hard limit to 10RPM PAS cadence
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
jbalat   10 kW
Post by jbalat » Sep 10 2018 6:51pm
Sep 10 2018 11:56am
This happens with my bosch ebike too and it is more annoying on that one than the tsdz2. I am still running 0.3 JB version (sorry) and it still happens on that version as well. It may think you are starting from rest. Easy fix is just to check the speed sensor. I will check the code and see if I can find it ?
Will be upgrading when my temperature sensors come in, so may changes but for me I am 99% happy with how the bike performs with my settings on 0.3.
Please subscribe to my Youtube home page for Quadcopters, FPV and Bike Rides http://www.youtube.com/jbalatutube
My build log here http://endless-sphere.com/forums/viewto ... =6&t=55352
For some cool ebike talk join us on The Best ebike https://www.facebook.com/groups/193581737807033/
Tech talk TSDZ2 Opensource firmware https://endless-sphere.com/forums/viewt ... &start=150
Opensource TSDZ2 Wiki https://github.com/OpenSource-EBike-fir ... _wiki/wiki
Dirkro   1 W
1 W
Post by Dirkro » Sep 11 2018 1:04am
casainho wrote:
Sep 10 2018 1:00pm
I have a issue with my LCD 3 , when I move / touch it it is going for reset or switching off.
have to look into it today .
Then I will continue testing
Oh darling, this is not a new bike.. :roll:
Dirkro   1 W
1 W
Post by Dirkro » Sep 11 2018 1:16am
casainho wrote:
Sep 10 2018 1:00pm
Maybe the change in torque sensor value is good ro detect the start of pedaling
casainho   100 MW
Post by casainho » Sep 11 2018 10:09am
Did a new release V0.11: Now each assist level and boost level are defined in watts.
I also updated the wiki page to reflect this changes.
Dirkro   1 W
1 W
Post by Dirkro » Sep 11 2018 10:53am
I just flashed this version I think, with a compiler
Thank you for the fitness bike :-) I was suprised to see the assistance levels
but no more than 260 W 7.4 amps
Crosschecked all parameters.
But I have to admit that I first flashed the motor firmware on the LCD
But I recognized my fault directly after flash!
EndlessCadence   100 W
Post by EndlessCadence » Sep 11 2018 1:44pm
Hi Casainho, thanks for your hard work! I'm developing some features as well but I find it hard to keep up with your changes. Is it possible for you to have the new features beta tested before they end up in master? Now it feels like everything changes every day :P I experience some bugs as well and I'm constantly in doubt whether I just introduced that particular bug or not :D
I've just created a PR with a fix for one the bugs, the lights couldn't be turned off.
jbalat   10 kW
Post by jbalat » Sep 11 2018 7:00pm
Sep 11 2018 1:44pm
I tend to agree, we are trying to get new users to use this firmware but realistically there are potentially bugs everywhere and all we will end up with are a lot of disgruntled people.
So the branch should stay out of the master until at least one person tests it, unless it is just an easy bug fix
Dirkro   1 W
1 W
Post by Dirkro » Sep 11 2018 11:35pm
Dirkro wrote:
Sep 11 2018 10:53am
Maybe a RTFM Error, I thought thet the value for assistance where percentage, not watts
Will give it a try this evening
One more thing I faced: The standard power for the Batterie was 8000 wh.
casainho   100 MW
Post by casainho » Sep 12 2018 4:24am
jbalat wrote:
Sep 11 2018 7:00pm
Sep 11 2018 1:44pm
Then I think I will create the "development" branch an put there the new code. Let's see if this will work well.
Sep 11 2018 1:44pm
Great!! Let's see if we get lights working as expected!! I will test (although I have no lights) and close the issue if is fixed.
casainho   100 MW
Post by casainho » Sep 12 2018 7:36am
casainho wrote:
Sep 12 2018 4:24am
Sep 11 2018 1:44pm
Thanks to your pull request and info I could understand what was wrong -- my code!! I put the new code on "development" branch. Can someone please test? I want to make a new firmware release as this is important for some users.
That was not good code... you see, that if only happens when I turn on the lights bit but when I reset, the if never happens and then it does not reset the lights.
And for me, I can switch on/off the lights and the motor assistance keep working as expected.
Code: Select all
       // set lights state
-      if (p_motor_controller_data->ui8_lights == 1) ui8_tx_buffer[2] |= 0x01;
       // walk assist level state
-      if (p_motor_controller_data->ui8_walk_assist_level == 1) ui8_tx_buffer[2] |= 0x02;
+      ui8_tx_buffer[2] = (p_motor_controller_data->ui8_lights & 1) |^M
+          ((p_motor_controller_data->ui8_walk_assist_level & 1) << 1);^M
Post by EndlessCadence » Sep 12 2018 8:51am
Casainho, I don't understand why you've fixed it again yourself. You could just have completed the PR (or at least discuss about it), albeit to the development branch. It was already tested!! Also, I don't know why this should fix the motor assistance issue when the lights are turned on. That's why I created a separate bug report for that issue.
This isn't the first time and as much as I appreciate your work and time devoted to this project (I really do!), do you want collaboration or do you prefer to develop it by yourself? This makes it almost impossible for me to contribute to this project...
That said, it's great that we have a development branch now :D
casainho   100 MW
Post by casainho » Sep 12 2018 9:10am
Sep 12 2018 8:51am
I didn't understand very well your changes but I did understand what was wrong and it was very quick to fix, I did and then I tested. I also tested and found I have no issue about the assistance and so I kept my changes. I closed the issues about that because I don't have them and I can't see what can be failling.
I am kind if new to pull requests but I accepted them before. It is also new to me to have other developers doing pull requests. Maybe we should first discuss before anyone start implementing a new feature?? -- I can say I am now trying to implement simple things like adding battery voltage configuration to reset the WH counter -- I am trying to add to EEPROM a few of variables for that small things that are on issue list.
For instance, I am not working on walk assist feature as you told you were.
Post by EndlessCadence » Sep 12 2018 10:03am
casainho wrote:
Sep 12 2018 9:10am
Sep 12 2018 8:51am
A PR is a perfect occassion for discussing the feature or bug fix! Feel free to ask for clarification of the code!
Regarding the other issue: if you don't experience the issue that doesn't always mean there is no issue, especially if you're not using lights yourself.
No problem, we should help each other to collaborate and improve the firmware together. I work with PR's on a daily basis. Yes we should discuss issues/features before implementing, we did this already with the speed limit feature but you did that one yourself too.
Of course you master this firmware but with a little help and patience others can help as well, including myself. Also with testing :D
Great! I need your help on that one! See https://github.com/OpenSource-EBike-fir ... e/issues/7
Btw, I had offroad mode implemented as well and was testing it but then then you merged many changes back into master one day. :P I have to fix the merge conflicts first and will create a PR then, okay? Here or when the PR is created we can discuss and improve further before merging the feature back into master or development.
Dirkro   1 W
1 W
Post by Dirkro » Sep 12 2018 10:26am
Dirkro wrote:
Sep 11 2018 11:35pm
Was not RTFM
No way to get more than 250 W
Is there a secret 250W limit in version 10 when 25 hm/h is on?
anyone same experiance with 36 V Motor 36V Batt.
Regards
Dirk
casainho   100 MW
Post by casainho » Sep 12 2018 10:33am
I implemented the "battery voltage reset value for WH counter" and created a new wiki page for the information about configs as the code is only on development branch:
Code: Select all
Voltage to reset Wh counter
54.2 (volts)
On power on the LCD, this value is compared to the battery voltage and if is lower, means that battery is fully charged and the Wh counter is reset.
To find the correct value for this field, fully charge your battery and measure the voltage on LCD3, use a slight lower voltage value for this field, example: my 48V battery charges up to 54.6 volts and so I use the value 54.2.
https://github.com/OpenSource-EBike-fir ... EVELOPMENT
Dirkro   1 W
1 W
Post by Dirkro » Sep 12 2018 2:30pm
one stupid newbe question:
How do I reset the EEPROM
casainho   100 MW
Post by casainho » Sep 12 2018 4:29pm
Dirkro wrote:
Sep 12 2018 2:30pm
I know why you ask.
The firmware was implemented with a key value on EEPROM address 0, that if is different of the expected value when system boot, will write all values to the default. So, you just need to write 0 to the first address or to change the key value on EEPROM file of the firmware.
Dirkro   1 W
1 W
Post by Dirkro » Sep 13 2018 12:50am
casainho wrote:
Sep 12 2018 4:29pm
I know why you ask.
For a simple mechanical engineer, this maybe needs a litte bit more explanation:
What I would try..
So if I open the flash tool, I go to the data memory , read it, and put 00 to the upper left ?
then write, restart firmware
right procedure?
casainho   100 MW
Post by casainho » Sep 13 2018 4:41am
Dirkro wrote:
Sep 13 2018 12:50am
casainho wrote:
Sep 12 2018 4:29pm
I know why you ask.
What I would try..
right procedure?
I just added an option for LCD configurations to be reset to default values. It is on development branch. I am implementing a few configurations and I will document in the end of today.
Dirkro   1 W
1 W
Post by Dirkro » Sep 13 2018 8:35am
casainho wrote:
Sep 13 2018 4:41am
When I want to flash the developement branch, this is only the LCD, Will this work together with the master of the 011 firmware for the motor?
Please confirm that the hard coded 250W limit is off for this version !!! :evil:
Post by EndlessCadence » Sep 13 2018 10:10am
Which hardcoded 250w limit are you talking about?
Dirkro   1 W
1 W
Post by Dirkro » Sep 13 2018 10:23am
Sep 13 2018 10:10am
It was in the one Version
I flashed on 11to September
I connot get it over that limit,
@ EndlessCardence: Is your "Off Road " Fork wready for use ? How to confirure? What are the files working toghether?
Regards
Dirk
Post by EndlessCadence » Sep 13 2018 4:11pm
Dirkro wrote:
Sep 13 2018 10:23am
Hi Dirk, if you want to try it, go ahead! I would like to encourage other beta testers as well! :D It could be that power limiting isn't working yet but speed limiting should work as desired. I've no more time to test here today because it's dark and the motor assistance doesn't work with the lights turned on :P Does anybody else have this issue as well?
Let me know what you think of the offroad feature!
You can download the version including offroad functionality here:
https://github.com/endlesscadence/TongS ... froad_mode (motor controller)
https://github.com/endlesscadence/Kunte ... froad_mode (display)
Beware that you have to compile the hex files yourself as the included hex files are outdated.
edit: pre-compiled hex files can be downloaded here:
KT_LCD3_Flexible_OpenSource_firmware-v0.11_offroad_beta.hex
TSDZ2_Flexible_OpenSource_firmware-v0.11_offroad_beta.hex
Configuration:
Use configuration menu 7
0. Offroad functionality -> enable/disable, default disabled
1. Offroad mode active (unlimited speed) on system startup -> enable/disable, default disabled
2. Speed limit when offroad mode not active but enabled (setting 0) -> km/h, default 25 km/h
3. Power limit -> enable/disable, default disabled
4. Power limit -> watts, default 250W
Using (only applicable if setting 0 above is enabled):
1. Offroad mode is shown by the motor assist symbol (directly above the assist level)
  • No blinking -> offroad mode inactive
  • Blinking -> offroad mode active
2. Button on/off + button up (together and both just a short press) -> offroad mode active
3. Button on/off + button down (together and both just a short press) -> offroad mode inactive
Keep in mind that the other speed limit can still be used, so for instance it's possible to have two limits e.g. 25 km/h and 35 km/h.
Dirkro   1 W
1 W
Post by Dirkro » Sep 14 2018 2:25am
Thank you, I am keen to try!
I am a fan of a 35 km/h offroad mode
do I need to reset the Eprom?
Regards
Dirk
