HughF   100 W
Re: TSDZ2 mid drive with 860C, 850C or SW102 displays only -- Flexible OpenSource firmware (Casainho code only)
Post by HughF » Jul 15 2020 4:25pm
jeff.page.rides wrote:
Jul 15 2020 11:05am
Hey All,
I am now using an 860C with version 1.0.0 on my handcycle.
I'm having trouble getting the 860C V1.0.0 dialed in, and I need some help with 4 different settings. I adjusted these a little bit one at a time and didn't notice a noticeable difference.
I want to make the torque sensor as sensitive as possible!
(1) Maximum Battery Current,
No matter how many times I turn it up past 16 amps and no matter what I've tried, once I turn off the system when it turns back on its back at 16 amps.
What do I need to do to keep it at a higher amp setting?
(2) Minimum current value (in ACD steps),
What does a higher number setting do compared to a lower number setting?
(3) Torque ACD threshold value,
(4) Coaster Brake ACD steps,
Does a higher or lower number make it easier to pull back?
You should set up as follows:
Motor current calculation: torque mode
Current ramp: 10a
Assist w/o pedal: enabled
Startup boost: disabled
Startup boost fade: default
Startup boost duration : default
And calibrate the torque sensor, this is super important.
With those settings you should have power from the moment you apply pressure to the pedals/hand cranks, and the assistance will start irrespective of whether you are below the cadence sensor sensing threshold. This is really important to help people get moving and assistance from a start and with a low cadence.
Genesis iOiD Alfine8 Hard tail MTB, 36v TSDZ2, 13s battery, SW102 display
Raleigh reynolds road frame from the 80's, TSDZ2, SW102 display, 1x10 drivetrain, gravel tyres
HughF   100 W
Post by HughF » Jul 15 2020 4:27pm
Benoit wrote:
Jul 15 2020 4:21pm
casainho wrote:
Jul 10 2020 8:17am
Benoit wrote:
Jul 10 2020 7:48am
casainho wrote:
Jul 10 2020 6:00am
Maybe at the end of next week. There are some small changes to the FOC, that was sent to me by an user.
Ok, so I'll try to make the PR in the next days, maybe this weekend. If I don't have time to fix my mistake about the distance calculation, I'll make PR with my current commit. (And I still have to change the daily RTC counter reset to make the auto reset trip memories above 24h works)
And about the boost feature, what is buggy ? I would like to see if I can fix it but I don't know what's wrong with it.
Ok, good idea.
About boost feature, I lost the track of what is wrong.
I just did the pull request. I hope I did not made mistake in the code, it's the first time I work on that kind of project.
I did not fix the trip distance calculation, no time to test the fix I did. But I did not encounter any issue since the last 2 weeks where I use my bike every day of the week. (tested only on 860C display)
You found and fixed the bug in the boost logic?
Benoit   10 mW
Post by Benoit » Jul 16 2020 2:31am
HughF wrote:
Jul 15 2020 4:27pm
I read the code but I don't understand what could be wrong for now. I don't have enough time currently, maybe next two weeks I'll can investigate more as I'll be in holiday (but without testing as I won't have my bike with me).
Nfer   10 W
Post by Nfer » Jul 16 2020 8:45am
Benoit wrote:
Jul 16 2020 2:31am
HughF wrote:
Jul 15 2020 4:27pm
From ebike_app.c file
is the first line correct?
m_config_vars.ui8_startup_motor_power_boost_feature_enabled = ui8_rx_buffer[8] & 1;
Code: Select all
      m_config_vars.ui8_startup_motor_power_boost_always = (ui8_rx_buffer[8] & 2) >> 1;
      m_config_vars.ui8_startup_motor_power_boost_limit_to_max_power = (ui8_rx_buffer[8] & 4) >> 2;
      m_config_vars.ui8_torque_sensor_calibration_feature_enabled = (ui8_rx_buffer[8] & 8) >> 3;
      m_config_vars.ui8_torque_sensor_calibration_pedal_ground = (ui8_rx_buffer[8] & 16) >> 4;
      m_config_vars.ui8_motor_assistance_startup_without_pedal_rotation = (ui8_rx_buffer[8] & 32) >> 5;
      m_config_vars.ui8_motor_type = (ui8_rx_buffer[8] >> 6) & 1;
CatfishMan   1 mW
Post by CatfishMan » Jul 16 2020 1:36pm
So I finally updated from v0.4.0 to v1 and WOW what a difference! Huge improvements in performance and functionality. And thank you so much for breaking the configuration menu down into sub-categories! It was always a huge pain scrolling through that entire menu. @casainho contribution made!
A couple issues I found:
  • My throttle trigger doesn't work at all now even though I have it enabled in the configuration.
  • I notice a slight delay (like 2-3 seconds) for the motor to kick in after I start pedaling. It didn't behave this way with 0.4.0. Is this by design? Do I just need to calibrate the torque sensor?
HughF   100 W
Post by HughF » Jul 17 2020 1:22am
CatfishMan wrote:
Jul 16 2020 1:36pm
Set up with my configuration settings I posted a few pages back. That will give you the best performance and response. Some say it's nearly as good as a brose 👍
Although I can't help with the throttle issue, I'm pas only
bikesnobyyc   1 µW
Post by bikesnobyyc » Jul 17 2020 7:55am
HughF wrote:
Jul 06 2020 10:15am
James Broadhurst wrote:
Jul 06 2020 7:17am
HughF wrote:
Jul 06 2020 5:56am
I also think the problems came from the anti-rotation plate/system. By default it comes supplied with an m8 socket button for fixing the clamp plate down. Socket buttons are total junk for getting any sort of decent torque on, without them rounding out. I've changed this now for a high tensile socket cap and I think I've done a better job of tightening the anti-rotation system up.
Same here. When I first read your original post I thought that it was about time I did what I’ve been threatening to for some time - buy a Bafang side bracket as Wayne describes it so I did. I think it will hold better than Wayne’s pot marks but otherwise his instructions are very, very good. I might be lucky and get one of the M5 bolts to hold .....!
Agreed, the M8 are very difficult; the seat tube obstructs you getting a clear shot at tightening it and I’ve shortened a few Allen keys to fit it in but it’s a little hit and miss.
Yes, seat tube access certainly makes tightening this fastener difficult.
I went with an M8 13mm standard hex head bolt from a hardware store and it works great. It's easy to tighten it up with an open-ended 13mm wrench.
casainho   10 GW
Post by casainho » Jul 17 2020 8:21am
Nfer wrote:
Jul 16 2020 8:45am
Code: Select all
This is the code on the display side:
On the configurations menu, value 0 for disable and 1 for enable:
Code: Select all
FIELD_EDITABLE_ENUM("Feature", &ui_vars.ui8_startup_motor_power_boost_feature_enabled, "disable", "enable"),
On the UART tx, first bit:
Code: Select all
      ui8_usart1_tx_buffer[8] = rt_vars.ui8_startup_motor_power_boost_feature_enabled |
          (rt_vars.ui8_startup_motor_power_boost_always << 1) |
          (rt_vars.ui8_startup_motor_power_boost_limit_power << 2) |
          (rt_vars.ui8_torque_sensor_calibration_feature_enabled << 3) |
          (rt_vars.ui8_torque_sensor_calibration_pedal_ground << 4) |
          (rt_vars.ui8_motor_assistance_startup_without_pedal_rotation << 5) |
          ((rt_vars.ui8_motor_type & 1) << 6);
So yes, I think it is correct. Thanks for looking at it.
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
Nfer   10 W
Post by Nfer » Jul 17 2020 10:00am
does the boost problem affects all the screens or just SW102?
I have SW102
casainho   10 GW
Post by casainho » Jul 17 2020 10:15am
Nfer wrote:
Jul 17 2020 10:00am
I have SW102
I just can tell that the firmware on the display side, for boost and other configurations, as also UART communications, is common to both displays.
jeff.page.rides   100 W
Post by jeff.page.rides » Jul 17 2020 2:59pm
sorry I don't know how to delete a duplicate post
Post by jeff.page.rides » Jul 17 2020 3:04pm
Jul 17 2020 2:59pm
HughF wrote:
Jul 15 2020 4:25pm
Current ramp: 10a
Hugh thanks for the reply,
I'm not doing this just for myself I'm trying to get all the default setup for anyone that has a handcycle. Most of us don't have the time or the ability to calibrate the torque sensor without recruiting someone else to do it for us. So I need to get all the settings working the best they can without the torque sensor calibration and then if they want to get it calibrated they can go from there.
I need these questions answered by you, Casaino, or anyone!
cellmate   100 µW
100 µW
Post by cellmate » Jul 17 2020 4:07pm
https://github.com/OpenSource-EBike-fir ... tor.c#L482
Is this why battery max current isn't being respected during field weakening?
HughF   100 W
Post by HughF » Jul 18 2020 1:41am
Jul 17 2020 3:04pm
Hi Jeff, with regard to the torque sensor calibration, what I have found to work well for me is not performing complete calibration, but merely setting the max ADC values and weights for your actual weight. I weighed myself on the scales, I'm about 75kg's so I set the maximum weight for left and right hand pedal to that weight. I then stand on each pedal and make a note of the ADC value - then put that in for the maximum weight adc value field.
By default I think the maximum weight value is 110kg's for left and right, if you don't weigh that much, or cannot push/pull that much on the hand cranks then you'll never see maximum performance from the motor.
I am running 1.0.0.alpha, not the latest 1.0.0.beta code, this does NOT reset the max battery current on power down, it stays at 20a. I'm afraid I cannot answer you about points 2,3,4 because I don't know what they do either. I know that I have not adjusted them from default and I am very impressed with the performance of this motor now.
I think with Casainho now working full time at the university and his free time being spent on the TSDZ2 ANT+ wireless project, it will be up to us users to work out these final bugs on 1.0.0.beta
casainho   10 GW
Post by casainho » Jul 18 2020 4:28am
Battery max current default to 16A: a developer found the issue and did a pull request.
Higher max current on Field Wakening: I solved this issue.
All this changes are on the main branch and will be included on a next release.
M4ttgreen   1 µW
Post by M4ttgreen » Jul 18 2020 10:48am
Sorry didn't see this thread as I had orginally posted this in the tsdz2 thread. I have looked through the instructions and it doesn't seem to mention this error(picture attached) as anyone had this it know of a fix
Screenshot
Post by jeff.page.rides » Jul 18 2020 7:26pm
casainho wrote:
Jul 18 2020 4:28am
Hi Casaino,
It's always good to see fixes for the bugs that are there!
Will you please answer the questions below?
It will really help me out knowing what these settings do and which direction to go.
Thanks,
Jeff
Looks like you fixed this above?
Rydon   100 W
Post by Rydon » Jul 19 2020 4:34pm
Jul 18 2020 7:26pm
casainho wrote:
Jul 18 2020 4:28am
Hi Casaino,
Thanks,
Jeff
Jeff, regarding your reposted laundry list above. Casainho answered your (1) by telling you that the max battery current bug is being fixed by another developer and will be in a future release.
If I understand correctly, Hughf answered your number (2) question by showing you that torque sensitivity is impacted much more by max weight and corresponding ADC value than the min weight and ADC value that you asked about.
I would guess that (3) Torque ADC threshold is the amount of torque applied to the pedal before the motor starts when in torque only mode (instead of power mode)
As for (4) Coaster Brake ADC steps. This is a bit of a mystery to me. We found that setting it as high as 80 reduced the forward jerk when you go to apply the coaster brake. I assume that is what you mean by "easier to pull back". Casainho does not have a coaster brake motor and very few other people on this forum do, so it may be up to us that do to figure that out. It would be nice if a developer could help with that as in my testing power does not cut quick enough when you apply the coaster brake. Setting that value very high does help though.
HughF   100 W
Post by HughF » Jul 20 2020 1:34am
M4ttgreen wrote:
Jul 18 2020 10:48am
Wait, is that a screenshot, of a photo, of a screen? #recursiveexplode
ilu   10 W
Post by ilu » Jul 20 2020 3:49am
HughF wrote:
Jul 20 2020 1:34am
M4ttgreen wrote:
Jul 18 2020 10:48am
It seems to be of this fancy modern technology though, as no image is printed in the process!
Nfer   10 W
Post by Nfer » Jul 20 2020 7:30am
Jul 18 2020 7:26pm
From the 0.20.0 configuration:
(0) Disabled
(X) Enabled with torque sensitivity X %
If you wish to enable startup assist without pedal rotation it is done by appropriately configuring this variable. If set to (0), startup assist without pedal rotation will be disabled. But any value above (0) will enable assist without pedal rotation. The percentage value will determine the sensitivity of torque applied. 100 % sensitivity will assist from the slightest of torque applied. It is advised to use e-brakes if startup assist without pedal rotation is enabled.
When configuring it is good to incrementally increase the sensitivity until you are satisfied. Do not start with too high values. The sensitivity is different for each and every bike and should be configured after personal preference with the main riding mode you intend to use.
Recommended values range between 10-15 %.
perryscope   100 W
Post by perryscope » Jul 20 2020 10:23am
Has anyone experienced issues with the SW-102 display when setting the number of assist levels?
If I reet to defaults it has 20 levels and they are all available to select when riding but then if I set it to have 10 levels I only get 6 available to use, i cannot select 7?
Interestingly if I switch it back to 20 I then only get 12?
Empowered people support rider and trustee
www.empoweredpeople.co.uk
Davo   10 µW
10 µW
Post by Davo » Jul 20 2020 12:24pm
Hello
Eco-bikes have a great step-by-step on programming the 850C: https://www.eco-ebike.com/blogs/eco-cyc ... e-tutorial
My question is... can I use the same tutorial to program the 860C? Are there any differences I need to be aware of?
mallesepp   10 mW
Post by mallesepp » Jul 20 2020 1:34pm
Davo wrote:
Jul 20 2020 12:24pm
Hello
Your found instructions also work with the 860C. Flashed successfully with this guide!
Below is the link to the wiki: This will also refer to the page you found: https://github.com/OpenSource-EBike-fir ... bootloader
Hardtail Canyon AL 6.0 (2014) TSDZ2 36V 10S5P 860C
RaceBike Canyon AL 9.0 Di2 (2011) Humanpower 220 Watt/120 Minuten
Garmin Edge 1000, bePro Powermeter, Garmin Edge Remote
Davo   10 µW
10 µW
Post by Davo » Jul 20 2020 2:24pm
mallesepp wrote:
Jul 20 2020 1:34pm
Davo wrote:
Jul 20 2020 12:24pm
Hello
Brill! Many thanks mallesepp
I also noted the Eco-Bikes have lots of different cables (1T1, 1T2, etc https://www.eco-ebike.com/search?q=1T1). Would I need one of these cables to programme the 860C or the TSDZ2? If not, what are these cables for?
