Has anyone successfully programmed an em3ev 12fet controller to use a speed above 100%? I know it works with the standard Infineons / Lyens. I'd like to program mine to 120% but I'm not sure if it works on the em3ev versions.
Thanks for the replys. I contacted em3ev and this was their response:
We strongly recommend that any speed greater than 100% is not used. The controller’s lifespan will be adversely effected if it is set beyond 100%. It is supported, but it is strongly not recommended.
