cheap brushed controllers advice
ZERONEST   1 mW
Post by ZERONEST » May 29 2018 6:07pm
I'm wondering if I can use something like this power a brushed e scooter motor?
https://www.banggood.com/10-50V-60A-300 ... rehouse=CN
If it is possible im also wondering if I can simply replace the potentiometer with a hall effect throttle?
And lastly would it possible to run two of these controllers in parallel to one motor but using one pot/hall throttle to control both controllers?
Any advice or other cheap suggestions would be great thanks!
Dauntless   100 GW
Re: cheap brushed controllers advice
Post by Dauntless » May 30 2018 12:15am
Why would you want to use that instead of something suited to the job? There will be something more to putting a throttle on there, probably you would wire it up to the potentiometer. Don't expect people here to know much of anything about that device.
viewtopic.php?f=16&t=12261&p=182473&hil ... er#p182473
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
ZERONEST   1 mW
Post by ZERONEST » May 30 2018 9:57am
Dauntless wrote:
May 30 2018 12:15am
Because it is cheap and supposedly handles 3000w, if someone could suggest another similarly cheap brushed controller that would be really helpful but the most I have found is 1000w
Thanks
spinningmagnets   100 GW
Post by spinningmagnets » May 30 2018 12:06pm
The specs look like an electric golf cart, or a small electric forklift (a walk-behind).
Don't try running two controllers in parallel, they will fight each other, even though the motors are brushed (it's been tried...several different builders).
The price is tempting, but there have been plenty of times when me or a friend bought something that was "too cheap to pass up", and it was a total waste.
If you can afford to blow one or two up, go for it...experimenting is fun. If you have a 6000W job that needs to be done, find an existing brand and model that actually works.
ZERONEST   1 mW
Post by ZERONEST » Jun 03 2018 7:14pm
spinningmagnets wrote:
May 30 2018 12:06pm
Thanks for the advice! I did some searching, does anyone know if this controller is any good?
http://kellycontroller.com/kds48050e50a ... p-282.html
if not can anyone suggest something similar in price and power?
Thanks
