Sensorless at standstill, development updates and status
Arlo1   100 GW
Re: Sensorless at standstill, development updates and status
Post by Arlo1 » Jan 09 2019 12:09am
Example of the open source world.
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 09 2019 3:35am
If I understand correctly (difficult to concentrate properly) this is about a company making their own product open source and selling more in the process. Not about someone having IP but no company. If I make my IP public I'm not going to sell more as there is nothing to sell except the IP.
lizardmech   10 W
Post by lizardmech » Jan 09 2019 10:06am
You can still sell IP and open source it, you just release it under a GPL license which requires the source code be distributed for the license to be valid, commercial customers typically won't want to release source codes for their products so you negotiate a non-GPL license with whatever terms you want. You're basically using the open source version as free marketing in that case.
Patents are separate but a huge headache, you can try and patent it if it's a novel method. The problem with patents is they're expensive, something like $10k USD+ per patent depending on the region, then even after you pay all the money the patent examiners they don't check for prior art, so you can have a registered patent that is not worth anything. Then even if you have a patent the government won't enforce it for you, if you find a large company is using it you have to sue them via a civil lawsuit, you will then waste about 2 to 5 years worth of legal expenses trying to enforce it. Eventually after all that if the opposing corporate lawyers fail to find any prior art or invalidate another way the patent it will become quite valuable but to get to that stage it would have cost 10 or 20 million.
Neither of them are mutually exclusive, it's just a matter of working out if patents are worth the investment since you have to do them first.
peters   1 kW
Post by peters » Jan 10 2019 5:47am
I'd recommend to design a controller and start selling a lot of them or cooperate with a manufacturer to include your firmware in their controllers (Grin tech maybe?)
Sooner or later others will develop a similar algorithm, because it is a known method just not spread yet, I've read about it also in a 20 year old book. I also tried it ~a year ago, but I just got to detecting the position in standstill. I'm not working on it now because I have other things to do, but I can tell your method should work with the 'standard' 205mm hub motors too, because their inductance change significantly by the position despite their rotors are not salient.
