Hello,
I've designed a FOC controller which runs in sensorless mode to drive different kind of ebike hub motors (geared and direct drive), and I'm wondering where does the difference in Vd required to maintain an Id near zero comes from ?
Some motors, typically geared ones, have a quite low Vd/Vq ratio (absolute value of about 1/6), but other ones have a much higher ratio, with some times Vd higher than Vq (in absolute value). In this case, there is a strange phenomenon : If we increase Iq ref, the speed becomes lower and motor consumes more (unloaded test). I think it's because of the circle limitation : we ask more Iq but as the Vd cannot go further (sqrt(Vq²+Vd²) = max output voltage), Id is increasing, hence motor going slower (contrary of flux weakening).
An other observation is that when I try to drive the motor in regeneration mode, motors which require an high vd have a very poor efficiency (most of the time, they provide a braking torque, but the regenerated power is close to zero, even close to nominal speed).
Anyway, has someone any idea of what makes some motor requires an higher Vd to maintain Id to 0 ? Is it related to motor saliency (I think ebike motor are only surface type PMSM, not IPMSM, so saliency should be very limited).
If you have any experience or explanation about this Vd/Vq ratio and its consequences on motor driving, don't hesitate to share them !
Thanks a lot,
Theophile
Thanks a lot,
Theophile
