New project- motor solution
jkrych
Gentlemen-
I've lurked for some time on the forum and let me say there is a wealth of knowledge here. That leads us to the reason for my inquiry-
I have a target rpm to reach under a 10 to 15 (mechanical)horsepower equivalent load. I was going an ICE route, but due to time constraints I have moved to BLDC.
I dug up a sizeable stator, 24 teeth, maximum outside diameter just under 5.5 inches(14cm), inner diameter 2.75(6.5cm) and I can fit 60 wires #18 in one slot. With the diameter of the rotor, I can't imagine I'd need more than 10 wires in a strand and with 6 turns the kv will most likely be very low.
Before I get into any more d-tails my next hurdle is ESC. This will be under remote control, so RC type or RC input possible motor controller that is affordable is what I'm looking for. I've heard a lot of positive remarks concerning castle controllers, and a 12 cell speed control would suit power requirements(15 cells I think would be ideal) but I'm not sure if this size motor can be driven by that type of esc- I hear something about very low inductance motors being hard on motor controllers.
Your thoughts?
Some thoughts, since youve not given enough specifics to let us help you figure out if what youv'e got will do what you want.
Less turns = higher RPM than more turns.
(as well as lower inductance, which is hard on controllers and batteries)
Lower strands in a turn = lower current handling ability than more strands in a turn.
narrower stators = lower torque than wider ones, all else the same.
Magnet strength and width also changes the torque and the kV. (and backiron for the magnets can change the flux which can change those too).
Caste controllers are often called Castle Cremations due to the way they fry when loaded incorrectly/etc. Don't know that you'll get 11kw out of one.
A controller doesnt' have to accept RC PWM throttle input directly, you can use circuits made to convert RC PWM input into voltage ranges for non-RC controllers.
Higher pack voltage (at full throttle) = higher RPM than lower pack voltage (at full throttle).
You don't mention your RPM or torque requirements, size limitations, or what the project is for, which are things that might help people help you work out exactly what you need.
Id like to keep the startup current low so at least a few turns. I mentioned #18 wire is available to me and i would rather not use a single turn
Yes, right now how many turns is going to be a function of the total number of wires i can fit in the slot, which is 60 #18.
i had an option for a three inch stator that was just a bit thicker than this one that was an outrunner, but the weight and size leads me to believe this inrunner style will have a higher power potential
i will get into that with the winding scheme.
the reason i asked is they are commonly used on 10 cells at excess of 200 amps in rc boats, so i figured that was right in my power range.
A controller doesnt' have to accept RC PWM throttle input directly, you can use circuits made to convert RC PWM input into voltage ranges for non-RC controllers. intredasting.
well, the most accurate torque requirement i can estimate is based off a startup peak, but id say its close to 5 newton meters. my target rpm is 15000, but the motor does not need to be direct drive, so i think that can be worked out in winding and with a gearbox. i currently have minor size limitations, (as the stator is 5 inches in diameter)
Soon as i figure out pictures i'll post a few.
Hey pictures!
so this is the stator. im not sure how thick the lams are, but they look to be between .020-.035, which i think is right around where i need to be. i dont plan on spinning this motor all that fast, or with a crazy amount of magnet poles, so if the lams are a bit thick and it hurts my efficiency it wont be that big of a deal.
10-15 hp is going to be a lot for that size stator. If you only need that much power for peaks and the average is lower, it could work.
I have see a few alternator motors used on mild hybrid cars that are in that range and maybe about the size of your stator. You might consider looking at some of those (available in junk yards).
Note that I said "all else the same".
If they're not the same (other than width) you can't directly compare a wider to a narrower motor--just being outrunner vs inrunner makes a difference, as does the diameter change, etc.
As for "power potential", size and weight don't necessarily have anythign to do with that, given that the two motors are essentially completely different from each other.
A motor with more physical mass can take a certain peak power for longer than one with a lower mass, but if the "containment" of the heat buildup is the same between them, then their continuous power limit would be teh same, if they both have the same wasted power inside them (efficiency).
If one is easier to cool than the other, you could get mroe continuous power out of it, as long as you actualy do cool it better.
If one is more efficient than the other, same thing.
If one is spun at a higher RPM, then all else the same (which they aren't), it could provide higher power, but it would have to be enough to overcome all the losses inherent in converting that higher RPM down to the range you need. A small motor can provide the same power a big motor can if you spin the small one faster (and keep it cool).
Castle controllers are often called Castle Cremations due to the way they fry when loaded incorrectly/etc. Don't know that you'll get 11kw out of one.
200A continous, or peak? And for how long?
I see over 100A battery current (different from motor current) on my SB Cruiser trike, but that's only at startup for a couple seconds, until I begin to accelerate less as I'm approaching cruising speed. After that it's less than a fifth of that worst case, and a tenth best case.
On most RC stuff, the props or wheels are essentially unloaded at startup, compared to using the same type of setup to drive a massive (hundreds of pounds) vehicle/rider. Their startup peaks are much much shorter, so the controllers (and motors) have plenty of time to cool down after that, and not much time during the peak to build up heat inside them to start with. The massive vehicle will have much longer peaks, with much more time to build up heat.
Even with external cooling setups, there may not be time enough to remove all that heat before damage occurs, especially inside the tiny RC controllers, which are not built in a way that enables easy removal of that heat--it tends to be concentrated and kept inside the parts for much longer than it would in a controller designed for higher continuous power levels, with cooling of the heat-generating parts being more direct than the typical RC stuff.
When inductance is too low on the motor, it causes even higher phase currents, which heats the controller even faster and to higher temperatures, and makes it more likely that any controller that allows heat buildup inside will fail spectacularly.
That's pretty low torque.
Not really a direct comparison, but it takes more than that to keep my SB Cruiser trike cruising at 20MPH, with the 20" wheel on a MXUS 3T DD hubmotor. Estimate 75Nm+ startup torque with it. The 4T on the other side estimates over 100Nm at startup.
http://www.ebikes.ca/tools/simulator.html?bopen=true&motor=MX4503&batt=B5216_GA&cont=C40&wheel=20i&frame=ELF&mass=170&hp=0&axis=mph&throt=56&cont_b=C40&motor_b=MX4504&batt_b=B5216_GA&wheel_b=20i&frame_b=ELF&mass_b=170&hp_b=0&throt_b=74
Why such a high RPM?
Note that gearboxes are going to be pretty loud with such high RPMs, assuming you can find some that will handle the power levels you're after at such RPMs.
Most of the stuff I've seen that reduces really high (RC motor level) RPMs to get more torque out of a small motor uses a belt reduction first stage, rather than gears, then a second stage taht can be another belt, or a chain, or gears.
I havent' worked with any stuff that uses a gearbox to get *higher* RPM out of a motor, so I don't know what that would be like.
