I think you may want to read up on some of hte existing skate threads, both for boards and inlines, so you can learn what you need to know about motors and required power to move you around at the speed and accelerations you want, so you can then figure out what motor size and winding, controller size and type, motor/wheel gearing, and battery you'll need.
What parts you need depends on your weight, terrain you need to ride on, wind conditions you expect, distance you need to go, acceleration rate you need, etc.
These are some of the various non-board skate threads that may help you:
https://endless-sphere.com/forums/search.php?keywords=skates*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
There's other good info in the skateboard threads, but there's many more of those so a general search is less useful.
