prius inverter gen 3 + toyota rear motor
Abricosvw   10 mW
Post by Abricosvw » Jul 09 2018 7:30pm
hi ...
i am from NJ ... ((if someone is nearby??))
my new project I want to run prius inverter gen 3 + toyota highlander rear motor ... ((homemade hybrid))
I want to install all this set on to 96 vw passat B4 on rear wheels ... ((at an early date))
I do not have much experience and no education but I have a lot of interest ...
my first steps i got highlander rear motor 50KW
on the video, I just test it works or not ((12V cheap chinese driver))
[youtube]https://youtu.be/xrGgDHG6X7w[/youtube]
Abricosvw   10 mW
Re: prius inverter gen 3 + toyota rear motor
Post by Abricosvw » Jul 09 2018 7:32pm
step two prius inverter gen 3 100KW
couple of photos
Abricosvw   10 mW
Post by Abricosvw » Jul 09 2018 8:29pm
step three inverter connector + pigtail
pigtail from inverter connector is attached to fuse box
I do not have connector from resolver encoder ((sensor))
Abricosvw   10 mW
Post by Abricosvw » Jul 09 2018 8:39pm
step four
we need to understand what kind of wires ((enter and exit to the inverter))
if you pay attention to the blue electrical tape ...
there is a twist of wires and a change in the color coloration ...
Abricosvw   10 mW
Post by Abricosvw » Jul 10 2018 8:22pm
Now we need to understand which connector ((who is who)) ...
New Bitmap Image (2).jpg (145.12 KiB) Viewed 1143 times
New Bitmap Image.jpg (149.64 KiB) Viewed 1143 times
Abricosvw   10 mW
Post by Abricosvw » Jul 10 2018 8:43pm
now the most important thing we need to understand how to control the inverter ...
we need a diagram and pinout from connector which on the side ((enters)) in inverter ...
in attached pdf file we are interested connectors D29 A59
invertor diogram gen3.pdf
(1.04 MiB) Downloaded 93 times
Abricosvw   10 mW
Post by Abricosvw » Jul 30 2018 5:03pm
now we need to somehow manage the inverter ( driver ) ...
so that you can manage and change settings and customize how your electric motor should rotate and work ...
we need Electronic control unit ...
I chose Lebowski's motor control viewtopic.php?f=30&t=57877&hilit=Lebowski+Brain+board
in our option We only need Lebowski( chip brain ) ... and an expansion board ...
read the documentation how to manage the program download/file.php?id=108834
for windows 10 download Termite version 3.4 - complete setup https://www.compuphase.com/software_termite.htm
If you follow the instructions in the PDF file you will have same as in the photo below
:mrgreen: note :mrgreen:
I had a few problems
the first as I understood my laptop does not have ground wire ... I started using a desktop PC the noise was gone ...
there was also a problem with cheap RS232 Serial Port from 5 different worked only one
