Bosch Active Line 3 mid-drive motor tear down
avandalen   10 W
Post by avandalen » Sep 08 2018 9:50am
For my solar powered bicycle, the Maxun One, I designed a very powerful and lightweight mid-drive motor. I also wanted to investigate whether I could use a Bosch Active Line 3 motor. The Bosch motor weight is 2975g, this is relatively lightweight for a mid-drive motor, but it is still too heavy for my solar bike.
So, I wanted to investigate if the Bosch motor can be reduced in weight, so I disassembled the motor. This is also a great opportunity to see how it works and which electronic parts are used.
See the whole article here:
http://www.avdweb.nl/solar-bike/hub-mot ... ine-3.html
What is striking after opening the motor is that there are only a few parts inside, that is a great achievement of the Bosch engineers:Image
robbie   1 W
1 W
Re: Bosch Active Line 3 mid-drive motor tear down
Post by robbie » Sep 09 2018 12:59pm
A great tear down, and fantastic website by the way.
Have you figured out where you can remove any material to lighten the product up?
SlowCo   100 kW
Post by SlowCo » Sep 09 2018 7:17pm
Beautiful engineering from Bosch and a nice tear down from you.
Some other light weight mid drives:
viewtopic.php?f=28&t=95704
https://www.gngebike.com/ultralight-300w-kit
And please show your own design here also.
casainho   10 GW
Post by casainho » Sep 13 2018 4:56am
avandalen, thanks for sharing!!
Really good to see the Bosch technology and compare to cheap chinese options like TSDZ2 mid drive motor: https://github.com/OpenSource-EBike-fir ... _wiki/wiki
Sure Bosch technology is more advanced but from the perspective of using the motor to other applications like hand bicycles, repair, DIY and having/owning knowledge about motor technology, cheap chinese like TSDZ2 mid drive motor is the way to go!!
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
avandalen   10 W
Post by avandalen » Sep 21 2018 9:51am
robbie wrote:
Sep 09 2018 12:59pm
No it is not possible.
I will switch to a Shimano Steps E8000 (2.88kg) or Brose mid drive motor (2.9kg in 2019)
avandalen   10 W
Post by avandalen » May 21 2019 7:45am
See the article about the motor graph here:
https://endless-sphere.com/forums/viewt ... 0&t=100180
