Hello,
I need to figure out what is the best hub motor (and battery) to use for this scenario:
If someone can give me a simple enough answer for a non-technical person it will be awesome... something like "X motor with Y battery"
But if a more complicated answer is needed, I'll try to follow.
If this is not the best place to post such a question in this forum, could you please point me to the best place?
Thank you!
Dimitre
- not assist, just throttle
- up to 150kg person (in reality 100kg will be max)
- starting from 0 km/h, and capable to maintain low speed even upslope
- needs to climb up to 30 degree slope, but ideally even more
- want to be able to go over obstacles at zero speed... so you put the front tire on the curb and power it over it
- 20 km/h max speed is good (on horizontal surface, not upslope)
- about 25-30 km range
- rear drive
- longevity is very important - for both the motor and the battery
- cost is much less important than longevity
- ideally quiet
Thank you!
Dimitre
