asi bac 800 controller documentation and wiring
fitzroyjon   1 µW
Post by fitzroyjon » Jan 02 2019 10:31pm
Hi,
I've been searching high and low for documentation on the ASI bac 800 motor controller.
I've found this reference to the pinout of the 24 pin connector
http://accelerated-systems.com/files/BAC800-72-70.pdf
However, pin 1 is not referenced on the drawing. Can someone pls tell me which is pin 1 of the 24 pin connector on page 3 of the datasheet?
I purchased the ASI 800 controller from Luna with a Mini Cyclon motor. My intention is to use it with the Grin CA v3. The harness that is supplied by Luna is useless and simply doesn't map to anything that makes any sense. They don't know either.
From what I can tell, I just need to map the controller throttle input (Pin 14) to the CA v3 and either tie pin 21 to 22 (Key in/Key out) or pin 21 to V+ from the battery. That is if I knew where to count the pin number from.
Does that concur with anyone's experience?
I've sorted the power wiring.
Regards, Jon
PaulD   100 W
Re: asi bac 800 controller documentation and wiring
Post by PaulD » Jan 03 2019 12:57am
On the BAC 500, pin 1 is bottom right. I think it's the same.
If you have the mating connector, pin one usually has a tiny little arrow or triangle molded into it that points at pin 1.
evolutiongts   10 kW
Post by evolutiongts » Jan 03 2019 9:12pm
This is why you dont buy an ASI from luna
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
fitzroyjon   1 µW
Post by fitzroyjon » Jan 07 2019 7:05pm
Thanks, Pauld. That's very helpful. I'll give it a try. Regards, Jon
