Seeking info on this hub motor
johnnyfoos
South East IDAHO USA
Hello
Happy New Year
I'm seeking info on this hub motor
Was in this weird three wheeled front drive with very small rear wheels unit
was kind of like an upside down "Y"
It is in a 16" wheel
Has "HL" stamped into the solid rim
6 spokes solid Alum.
Also has 36V 350 W stamped into it, { XY36V350W12076367 }
Has 5 Hal wires, 3 field wires
A drum brake on one side with freewheel threads on other side
9 screws holding the side plates
Black paint on inner area
On the tire
Colored letting, E in a circle followed by CYT above BIKE
(and a bunch of China letting I think )
54-305/ 16X2.125, CHAO * YANG
HANG ZHOU RUBBER FACTORY, NYLON
Thanks for any help
That is a lot of views with no help
thought the
"Has "HL" stamped into the solid rim"
would get some kind of info,
O-well
I do have it spinning using a Amajoke china controller
36V 350W
that has NO wiring info with it
But, I'm getting there
Thanks
A few pictures would be very helpful.
I maybe found out about this motor
"ZooMe 3 comes with a powerful 350 watt brushless hub motor"
"https://www.amazon.com/Drive-Medical-Zoome-Recreational-Scooter/dp/B01LYI8JX7/ref=pd_sbs_121_1/145-8488460-8942323?_encoding=UTF8&pd_rd_i=B01LYI8JX7&pd_rd_r=2771a74d-40a2-11e9-acad-c779d924d9c8&pd_rd_w=kPeTU&pd_rd_wg=DxDRO&pf_rd_p=588939de-d3f8-42f1-a3d8-d556eae5797d&pf_rd_r=9CT3H666BHSP39672R4N&psc=1&refRID=9CT3H666BHSP39672R4N"
Anyway the unit it came off of looks like any one of these type of Medical mobility scooters.
And I took it apart and finger nail clear coat sealed a few of the magnets that look like the plating was compromised.
Had something like 50 magnets and 54 poles or visa versa. over all looks pretty good inside.
I am planning on using it as rear wheel on an OLD Schwinn YO Deluxe stun kick scooter
Just stalled thinking about a sort of long tail add on using a little kids suspension bike rear end
mounting the BB off it into the YO's rear axle spot and cutting the rest of it off just in front of the rear shock top mount.
I have had it running on a cheap china controller that i wish i knew how to hook up the extra wires on,
like
brake low level
brake high level
anti steal
3 speed
I'll try to post a build log when I get closer.
Still building a MOT spot welder, just got it tack welded back together
and working on the control stuff now
L8R
