SiliXcon FOC Controllers, small, powerful and many features
madin88   1 GW
1 GW
Post by madin88 » Jan 16 2019 5:18am
Hey guys,
it happended that i came across mentioned controller company. I thought it would be of iterest here as these controllers have outstanding features like FOC with direct torque control, MTPA (maximum torque per amp) control and zero-RPM sensorless control.
MTPA under field weakening would be useful for IPM motors which can produce reluctance torque.
They are available in three different sizes (impressiv small) and cover a power range of 2kW - 20kW nomninal and almost twice the peak power.
The voltage range is 12s - 20s LiIon.
http://silixcon.com/products/
https://www.facebook.com/SiliXcon/
Features:
  • Motors: PMSM (BLDC, BLAC), Induction, Stepper
  • Vector drive with DTC and FOC
  • Block commutation Drive with DTC and hybrid sensorless control
  • Zero-RPM sensorless control
  • MOS-FET power stage with all kinds of protection incl. phase short circuit
  • Designed for highest dynamic response
  • Charge step-up conversion and SOC estimator with current and voltage logging
  • Capacitors pre-charge option
eee291   100 kW
Re: SiliXcon FOC Controllers, small, powerfull and many features
Post by eee291 » Jan 16 2019 6:25am
Hmm the SC and SL Controllers are interesting since they go up to 24S Lipo according to the datasheet.
EDIT:
It's the same guy that made this video.
https://youtu.be/PcBaZ9sO9A4
I remember him posting about his Controller Company on here a few years ago. It used to be called PearControl
https://endless-sphere.com/forums/viewt ... l#p1134661
https://endless-sphere.com/forums/viewt ... l#p1260845
litespeed   100 kW
Post by litespeed » Jan 16 2019 7:41am
Looks like they could be great controllers just simply on size.....they have many, many features as a bonus. BMS coming soon it says.
Need someone to come out with a full controller/display/BMS package......again.
Tom
madin88   1 GW
1 GW
Post by madin88 » Jan 16 2019 9:03am
eee291 wrote:
Jan 16 2019 6:25am
:lol: :lol:
Yes it seems like the company was split or is from pear control.
Those are the specs of the smallest size, the AM controller:
51A/100A or 2200W/4300W with 12s (51V) battery
60min/10sec rating if mounted to a heat sink
size: approx 100x35x13mm :D
Let's hope that they sell to private persons with included program software and everything needed like documentiation of wiring. And hopefully then programming goes easy from hands.
fechter   100 GW
Re: SiliXcon FOC Controllers, small, powerful and many features
Post by fechter » Jan 16 2019 9:44am
The big 24.5kW version would be good for a Sur-ron. I wonder if it is a headache to program like an ASI or Sevcon.
Ohbse   10 kW
Post by Ohbse » Jan 18 2019 4:20am
Anybody got pricing on any of the models? Certainly looks great, even the ''big'' version is tiny.
peters   1 kW
Post by peters » Feb 21 2019 1:51am
I asked them, they don't sell to individuals yet.
The numbers look impressive, but I'm wondering how they are built inside and the switching waveforms. From the size, they probably use SMD FETs, maybe HSOF or DirectFET
Recently I started to work on test boards with HSOF and it is absolutely not easy to make a good half-bridge layout with them. To make use of the low package inductance and high switching speed, ideally it would be on a 2-layer insulated metal substrate, any other solution seems to be more or less compromised.
wil   10 W
Post by wil » Mar 12 2019 4:37am
Any prices or more info?
Neanderthul   1 mW
Post by Neanderthul » Mar 25 2019 9:07am
I reached out to them and they told me they do not sell to individuals “yet”. Did any of you get a different answer?
eee291   100 kW
Post by eee291 » Mar 25 2019 9:45am
Group buy maybe? I live like a 2 hour drive away. I believe its a similar distance for madin88, maybe we both could take some time to go visit :)
Neanderthul   1 mW
Post by Neanderthul » Mar 25 2019 10:39am
I messaged back and offered to pay extra for the trouble, I’ll see what they have to say. I would be in for a group buy!
j bjork   1 kW
Post by j bjork » Mar 26 2019 7:45am
It seems like you also found an old thread about the controllers:
https://endless-sphere.com/forums/viewt ... 3&start=25
Neanderthul   1 mW
Post by Neanderthul » Mar 26 2019 9:55am
What do you mean?
Neanderthul   1 mW
Post by Neanderthul » Mar 26 2019 10:07am
eee291 wrote:
Mar 25 2019 9:45am
They gave me a quote of 508USD + extra charges for a single AM controller. I was pretty shocked because I don’t really have that in my budget. Can’t decide what to do as of now.
j bjork   1 kW
Post by j bjork » Mar 26 2019 10:14am
I only mean that there was a thread already about these controllers, I had not seen it before. You replied in it, so you must have found it. I just thougt it could be interesting to have a link to it here. It was from 2015-2016 :shock: , they were apparently almost ready to be sold to the public back then..
madin88   1 GW
1 GW
Post by madin88 » Apr 03 2019 5:37am
Neanderthul wrote:
Mar 26 2019 10:07am
Not cheap concidering that you would get only a single 12s 50/100A controller without display.
Does anyone have seen the Mrazek e-bike?
Because it looks like it is powered by a Silixcon SC controller which would be plausible as they are also located in Czech:
http://www.mrazek.com/about-revx.html
