Tsdz2 firmware open source adapted to vlcd5, vlcd6 and xh18
revher   1 mW
Re: Tsdz2 firmware open source adapted to vlcd5, vlcd6 and xh18
Post by revher » Feb 13 2020 6:42pm
Hi,
I started a wiki page entitled "OS X and Linux installation" but my scripts (compile_20.sh and edit_advanced.sh) and my java patch are still on my computer. Stancecoke could I send them to you or to anyone by mail, in order to test them?
Regards,
revher
stancecoke   100 kW
Post by stancecoke » Feb 14 2020 1:47am
revher wrote:
Feb 13 2020 6:42pm
Just fork my repo, upload your changes and send a pull request!
regards
stancecoke
revher   1 mW
Post by revher » Feb 14 2020 4:11am
I am not well aware of git (but know very well CVS, yes I am old) and github. And for me it is still a waste of disk space to fork an entire repository for just adding two files and a java patch, but I will do it. Not right now but probably during the WE.
Regards,
revher
tannertasman   10 µW
10 µW
Post by tannertasman » Feb 16 2020 5:07pm
Hi,
I'm hoping someone can help me with some issues I've been having with my tsdz2 build.
I bought the 750w 48v motor, planning to get a 48v battery in NZ. This proved impossible for me so I had to settle for a 36v battery. I flashed the 36v files from the eco-bike tutorial which was easy enough. Only problem is I'm not getting assist at any level. All the VLCD5 settings seem fine. I posted on Reddit and was directed to Stancecoke's VLCD5 repo. Went through all of that, but I'm still not getting assist at any level. Thanks for your time helping me, in advance.
stancecoke   100 kW
Post by stancecoke » Feb 17 2020 2:41am
tannertasman wrote:
Feb 16 2020 5:07pm
Sorry please explain exactly, what you have done! Have you still the stock firmware and just edited the EEPROM for voltage setting (as described at eco-bike), or have you flashed the OpenSource firmware?!
If you have flashed the OpenSource firmware, please ask mbrusa at the italian forum.
regards
stancecoke
Elinx   100 W
Post by Elinx » Feb 17 2020 3:42am
tannertasman wrote:
Feb 16 2020 5:07pm
I'm hoping someone can help me with some issues I've been having with my tsdz2 build.....
If I understand you well, you try to use the 48V TSDZ2 motor with 36V battery.
Please explain more details what you have done with Open Source firmware. Which version, use of java gui or other, your (voltage)settings etc.
tannertasman   10 µW
10 µW
Post by tannertasman » Feb 18 2020 4:43pm
stancecoke wrote:
Feb 17 2020 2:41am
tannertasman wrote:
Feb 16 2020 5:07pm
regards
stancecoke
Thanks for getting back to me.
I'm not sure what the EEPROM is, I just followed this tutorial.
https://www.eco-ebike.com/blogs/eco-cyc ... rogramming
I downloaded the 36v program and data memory s19 files, and uploaded them per the instructions. Everything looked fine at this stage but I got no assist when I went to try the bike.
Next I was referred to your stock VLCD5 repo. I followed the wiki closely and it was easy enough to set the settings and then flash, but again I got no assist.
https://github.com/stancecoke/TSDZ2-Smart-EBike/wiki
Thanks again
obcd   100 W
Post by obcd » Feb 18 2020 5:03pm
The tutorial describes both stock firmware reprogramming and osf firmware programming. It's still unclear what you did.
The eeprom (electrical erasable memory) is a piece of memory used to store parameters that don't need to be changed frequently.
Those parameters remain in the memory when the power is removed.
So basically, you have flash memory that is used to store program code (firmware) and eeprom memory that is used for the parameters (settings)
In older designes, the eeprom used to be a separate chip. Nowadays it's usually part of the microcontroller.
flash memory needs to be erased before it can be reprogrammed.
eeprom memory locations can simply be rewritten one byte at a time.
So, on the stock firmware, rewriting the eeprom means changing some of the firmware settings. This could be maximum speed or minimum battery voltage (as examples)
twiersum   1 mW
Post by twiersum » Feb 18 2020 10:47pm
Is there any way to limit the "time out" duration...the time until motor quits after you stop pedalling... with this compiler? I'd like to turn it way down.
obcd   100 W
Post by obcd » Feb 19 2020 4:20am
Isn't that what ebrakes are for? The brake lever closes a contact that turns off the motor.
tannertasman   10 µW
10 µW
Post by tannertasman » Feb 23 2020 9:06pm
obcd wrote:
Feb 18 2020 5:03pm
Here's a screen grab of my settings and the error message
stancecoke   100 kW
Post by stancecoke » Feb 24 2020 3:24am
tannertasman wrote:
Feb 23 2020 9:06pm
'STVP_cmdline' is not...
So STVP is not installed or not in the right directory. The file STVP_cmdline.exe has to be in 'C:\STMicroelectronics\st_toolset\stvp', or the path has to be adapted in the .bat file.
https://github.com/stancecoke/TSDZ2-Sma ... /flash.bat
regards
stancecoke
w0utje   10 µW
10 µW
Post by w0utje » Feb 24 2020 8:56am
Just tried the last firmware, works like a charm. Have to get used the learn the settings and adjust the powerlevels.
Got an 11.6ah battery and it seems to drain quicker then with the stock firmware. Got it set in the settings of the ihx file on 14Ah, should I try a different setting to get less battery drain?
obcd   100 W
Post by obcd » Feb 24 2020 10:24am
To get power from the motor, you need to feed it current.
The osf firmware might be driving the motor a bit more efficient due to it using simplified foc, but the biggest boost likely comes from the fact that the motor current is less restricted and the software allows the motor to produce peaks of 500 - 750W.
So, you can turn the current down to get a longer battery life, but it will reduce motor power (and riding pleasure) as well.
Obvious, the more efficient your system is, the more miles (or km's) you are able to press out of your battery.
jeff.page.rides   10 W
Post by jeff.page.rides » Feb 25 2020 6:22pm
Rydon and I are trying to use this firmware with a VLCD5 for the first time. It is on my hand-cycle with a coaster brake motor. I would like to know how to change from Power Assist mode to E-MTB mode and how to know what one it is in at that time. I am not interested in Street mode, Torque Assist mode, Cadence mode or the Cruise mode. As they didn't work well for me with the TSDZ3 display. I can get it to change from E02, E03, EO4 but it always goes back to E02. Is that what it is designed to do?
It would be nice if the double push on the light button didn't turn the light on and off each time. If it would just stay on or stay off in less you pushed it a single time then it would turn it on or off. With the light constantly turning on and off it's hard to see the changes.
OK, I've been playing with it a little more and I think I understand it?
I turn the display on and then I go to level 2 Tour and push the light switch twice then toggle through until it says E02 and push it one more time E02 flashes and that puts it in Power Assist for all 4 levels is this correct?
Then If I go to Level 3 Sport push the light switch twice then toggle through till it says E02 and push it one more time it flashes and that puts it in E-MTB for all 4 levels is this correct?
I haven't taken it for a ride yet because I've been trying to figure out what I need to do when I'm out on the ride.
Please help and explain!
Thanks!
tannertasman   10 µW
10 µW
Post by tannertasman » Feb 25 2020 10:36pm
stancecoke wrote:
Feb 24 2020 3:24am
tannertasman wrote:
Feb 23 2020 9:06pm
regards
stancecoke
well that was an oversight on my part... I moved the file to C:\ and flashed, now it's working! There should be a minimum IQ requirement on these things.
Stancecoke - you're awesome, man. Thank you so much for your help. I was worried my bike was bricked. Can I buy you a 6-pack or some bud for your time?
mbrusa   100 mW
Post by mbrusa » Feb 26 2020 12:23pm
jeff.page.rides wrote:
Feb 25 2020 6:22pm
Thanks!
Yes, to set "power assist" and "e-MTB", what you wrote is correct.
Four assistance levels are available for each mode.
Feb 25 2020 6:22pm
I do not understand what you mean. Can you explain yourself better?
Keep in mind that the display is not programmable and from the motor controller I can only know the number of the level and whether the light is on or off.
Sorry, I use the translator.
Regards
revher   1 mW
Post by revher » Feb 26 2020 4:33pm
twiersum wrote:
Feb 18 2020 10:47pm
obcd wrote:
Feb 19 2020 4:20am
Yes, but I have no ebrake. The TSDZ2 is sold without any and I am not willing to have theses wires.
But I have a gear shift sensor which is currently useless; it was on my bike when it was equipped with a Bafang and I did not remove it. I am quite sure that if I was able to connect it to the TSDZ2 controller I could keep the Open Source firmware. It is really a huge improvement but it is dangerous in town; the "time out" duration is too long before the motor quits and you can hardly change gear or even brake.
Therefore I looked back at the wiring of the Bafang gear speed sensor (most common) which has a yellow 3 pin male connector (similar to e-brake Bafang connectors):
  • 8 black ground;
  • 4 blue (brake signal or speed sensor or gear shift sensor);
  • 6 red 5V;
and it could (I am not sure) be connected, respectively, to the TSDZ2 speed sensor male 6 pins:
  • 1 orange ground;
  • 2 white (speed sensor). 5V or nothing;
  • 3 green (+ 5V for light);
I have on one side a useless (illegal in the EU) Bafang throttle which has a yellow 3 pins female connector and on the other side a TSDZ2 extension cable with a useless female 6 pins connector. It could therefore be easy to make an adhoc short connection cable, but I have two questions:
  • Is my above wiring plausible? (I don't fully understand the wiring but I need this gear speed sensor...)
  • As I don't need the lights, one of the Y branch is free to be connected with this new cable (if the answer to my first question is yes, of course) but how would the gear shift sensor interact with the speed sensor? I mean that when shifting gear, the 8 and 4 will be connected (or, here, the white speed sensor will be connected to the ground) for half a second to stop the motor, but will it damage the controller? will the speed sensor work again after shifting?
I would appreciate if someone has an idea on this important point. With the stock firmware, the gear shift sensor was useless, but with the Open Source software, I think that it is mandatory in town, with red lights, high traffic etc.
Regards,
Revher
Waynemarlow   1 kW
Post by Waynemarlow » Feb 27 2020 9:02am
Aren't you making life awkward for yourself, both the OS and the V20 have a brake wire, its a simple fit and already at the VLCD5 display. The gear shifter is another set of wires which you are going to have to wire in and doesn't really do anything other than what the brake wire will do ?
Both the Bafung and the OS TSDZ2 have a slight over run, the V20 is almost negligible and I think if you rotate the peddle backwards slightly will disable any drive, but like all chain drive systems under load the chain will not like to be displaced sideways, have you thought about just as you change to back off and either rotate the peddle backwards slightly or tap the brake lever slightly.
On my Shimano XT 10spd with a newish chain and good gears under full load it will still change up and down almost faultlessly, as soon as the chain gets to about 1/2 worn I start to get less reliable changes.
revher   1 mW
Post by revher » Feb 27 2020 11:37am
Waynemarlow wrote:
Feb 27 2020 9:02am
Thank you for your kind reply even if you did not answer to my two questions.
  • I am trying to make my life easier :P
  • I don't have a VLCD5 but a XH18 display; also my gear shifter cable is at the rear and the open end of this cable (which is currently not connected) is located close to the end of the speed sensor cable;
  • you are underestimating the duration and strength of the over run. But there is probably a parameter which could be reduced. Please tell me. I am using the reduced config.h and did not changed the advanced.h
  • also, I have an internal 8 speed gear hub Nexus with coaster brake. And that is the reason why I changed my BBS01 for a coaster brake TSDZ2: to be able to use again the coaster brake.
  • I already asked on this list if there is a coaster brake version of the mbrusa/stancecoke Open source software because there are two different versions of the original Open source of casainho https://drive.google.com/drive/folders/ ... jMrpW2ZqvH . But no one answered yet.
  • I made a YouTube video of my transformation from a Bafang to a TSDZ2 at https://youtu.be/V7BcizF8LV8 if you want to see the shift sensor in place (at the minute 1:08).
  • I have used this shift sensor on the Bafang and it changed my life. In town, you have to change gears every 10 to 30 seconds (?), and it is really a good option. Recent Bafang motors have a special cable for the gear shift sensor. Therefore, I am sure that having a shift sensor for the TSDZ2 and the current OpenSource V20 would be a solution, probably not for mountain bike, but for a pedelec under heavy traffic in a city like Paris.
I am please to read your advices (even if I do not agree with them...)
Regards,
revher
PS: I was in Rome last week (but did not meet mbrusa nor casainho) and haven't had time to upload on github my changes to the Java navigator (in order to make it working on OS/X and Linux), but may be during the next WE.
Post by jeff.page.rides » Feb 28 2020 5:33pm
mbrusa wrote:
Feb 26 2020 12:23pm
Feb 25 2020 6:22pm
Thanks!
Feb 25 2020 6:22pm
Regards
When I double or single click the light button to go through the programming it works but also each time it turns the display light on or off.
ilu   10 mW
Post by ilu » Feb 28 2020 6:01pm
revher wrote:
Feb 27 2020 11:37am
Which display and firmware version are you using? I have no idea if you can connect the gear shift sensor to the speed sensor wiring, but it should be possible to connect it straight to the controller.
https://github.com/OpenSource-EBike-fir ... kes_sensor
This page explains the general idea with brake sensors, and apparently the gear shift sensor works as the HWB sensor.
From the pictures below you should be able to determine which wire conects where, at least if the pinouts are the same as on a non-coaster-brake controller. Ignore the throttle (THR) pin as you'll only need 5V, GND and brake.
6-pin display cable
8-pin display cable
mbrusa   100 mW
Post by mbrusa » Feb 29 2020 1:28am
Feb 28 2020 5:33pm
I understand, but it cannot be done differently.
The control of the lights button is in the display software, it cannot be changed, it always turns the light on or off.
It is only the state of the lights that is used for programming, on or off.
At the first click when the lights come on I cannot know what the operator's intention is, for this reason programming with E02 always starts, if within 5 seconds the second click does not arrive it is clear that the intention is only to turn on the lights, programming is interrupted.
Another clarification, the need for a double click in programming is to not leave the lights on.
Regards
w0utje   10 µW
10 µW
Post by w0utje » Mar 01 2020 11:33am
obcd wrote:
Feb 24 2020 10:24am
Went back to the marcoq 1.9c, that delivers the same power on emtb mode but seems a lot more eco friendly. My 11.6 Ah battery does like minimal 45km's on 3/4 and even longer on setting 1/2.
godofglow   10 mW
Post by godofglow » Mar 01 2020 12:48pm
w0utje wrote:
Mar 01 2020 11:33am
obcd wrote:
Feb 24 2020 10:24am
:bigthumb:
Same experience.
Did some tests with same settings
