Hi LucaLuca68 wrote: ↑Jun 11 2020 3:19amHello to all and a dutiful thanks to all those who contribute with their knowledge and their time.
Over time I have electrified several bicycles with the tsdz2 and thanks to you I find them all fantastic.
Now my question
after analyzing all the various forums (even the Italian one) I don't understand why the SW102 display with 8 pin adapter works with the original sw without the need of bootloader (for example the one sold by eco cycle) and cannot work with the firmware modified by mbrusa (thanks again for the effort)
Of course I don't want to be able to change parameters on the fly just to use it as a command to change assistance levels and to be able to view battery power and speed.
I usually change the parameters only with the java configurator
so I ask you if it is possible to use the SW102 command in place of my current VLCD5 and possibly how to set the java configurator to make it active.
Thanks Luca
Are you sure that this display works on all engines and not only those sold by them?
If ecocycles assures that it's okay for the original firmware it might also work, but until you try it, there is no certainty.
Even between VLCD5, VLCD6, XH18, there are some differences and in the firmware I had to take this into account.
