Tsdz2 firmware open source adapted to vlcd5, vlcd6 and xh18
mbrusa   100 W
Re: Tsdz2 firmware open source adapted to vlcd5, vlcd6 and xh18
Post by mbrusa » Jun 04 2020 3:44am
jeff.page.rides wrote:
Jun 02 2020 4:53pm
So changing the display to always-on kept the display always on. But if you turned off the power on the display it wouldn't turn back on unless you shut off the power at the battery and then turned it back on.
Is this just my system and if so how do I fix it? or are others having the same problem, then it's a bug?
Hi Jeff
I have never had bug reports about it.
Display working on -> the display to turn off after 5 minutes of inactivity and the motor must no longer run.
Display always on -> the display never turns itself off, only manually with the on/off button.
From what you write, your VLCD5 display has a problem.
Flexible OpenSource firmware for TongSheng TSDZ2 motor and VLCD5 VLCD6 XH18 displays
https://github.com/emmebrusa/TSDZ2-Smart-EBike-1
Suggy   10 mW
Post by Suggy » Jun 04 2020 6:58am
Can Someone help me with a change of setting please.
I am working with the new configurator I have changed a few settings but for some reason now when I start pedalling and when I stop pedalling my pedals seems to pull outwards like there is to much torque it is mostly recognisable in eco mode and tour mode it never use to do this. Just wondering if it is a setting or maybe a mechanical problem.
Atrihalov   100 mW
Post by Atrihalov » Jun 04 2020 8:35am
The same problem, when you touch the pedal, the motor cuts all the crap.
When you drive it is somehow not noticeable, but when you are standing at the transition, the pedal hooked, you can jump out onto the road. I watched through the test at this moment the value of the ADC, the sensor sensor jumps.
Suggy   10 mW
Post by Suggy » Jun 04 2020 9:18am
Atrihalov wrote:
Jun 04 2020 8:35am
So not just me then. I have no idea of what setting to try and change.
mbrusa   100 W
Post by mbrusa » Jun 04 2020 11:16am
Suggy wrote:
Jun 04 2020 6:58am
I didn't quite understand what you mean.
Post the first tab of your configuration.
Suggy   10 mW
Post by Suggy » Jun 04 2020 11:57am
mbrusa wrote:
Jun 04 2020 11:16am
Suggy wrote:
Jun 04 2020 6:58am
When i first put power down whether it is from the throttle or the pedals you can feel the pedals hook outwards. You can also feel them hook outwards when you brake.
mbrusa   100 W
Post by mbrusa » Jun 04 2020 12:25pm
Suggy wrote:
Jun 04 2020 11:57am
There are no wrong settings, all right.
The only difference with my setup is that I haven't enabled the brakes.
Tomorrow I will try to enable them.
Suggy   10 mW
Post by Suggy » Jun 04 2020 12:48pm
mbrusa wrote:
Jun 04 2020 12:25pm
Suggy wrote:
Jun 04 2020 11:57am
Do you mean the brake sensor
Suggy   10 mW
Post by Suggy » Jun 04 2020 1:04pm
mbrusa wrote:
Jun 04 2020 12:25pm
Suggy wrote:
Jun 04 2020 11:57am
problem solved the silver nut was loose made a lot of difference lol
mbrusa   100 W
Post by mbrusa » Jun 04 2020 1:11pm
:bigthumb:
lupe   10 mW
Post by lupe » Jun 06 2020 4:08pm
emr wrote:
Mar 26 2020 2:54am
emr wrote:
Mar 06 2020 7:41am
I found this item, which appears to be what we need for the Gear shift sensing as it connects to the existing VLCD5 brake sensor sockets, but it doesn't appear to use 5v source. Unsure how it can work without the 5v. It also has brake sensors suitable for hydraulic brakes...
https://www.aliexpress.com/item/33060254663.html
I purchased one of these gear sensors and have fitted it near the gear changer on the handlebar. I haven't tested on the road but I can confirm it does turn the motor off momentarily (maybe 0.5 of a second (estimated)) when changing gears on the workstand. I suspect it will be the solution to the IGH issue of needing to stop pedalling to allow the hub to change gears.
Hi Emma
I received my gear sensor the other day. However I'm not sure it is working. I have plugged it in bit the light doesn't turn on? I also put a gear cable through it and tried running the motor via the throttle - but it doesn't seem to work at all while I have the gear sensor plugged in. Was there any tricks to install it? I have a bbshd with a gear sensor and they was very straight forward to install.
Thanks
Matt
emr   1 W
1 W
Post by emr » Jun 06 2020 5:27pm
lupe wrote:
Jun 06 2020 4:08pm
emr wrote:
Mar 26 2020 2:54am
emr wrote:
Mar 06 2020 7:41am
Hi Emma
Thanks
Matt
Hi Matt,
I also had the issue where I couldn't see the small blue LED light illuminate when I moved a cable through the gear sensor. I then made sure the plugs on the gear sensor leads were very firmly pushed into the VLCD5 sockets, and it then started to work.
I don't use a throttle due to having a temperature sensor in the motor (which everyone should have) which disables the throttle,so unsure on that issue. I wouldn't have expected the gear sensor to affect the throttle operation, as the gear sensor is only producing an imitation of a momentary application of the brake.
Cheers Em
Atrihalov   100 mW
Post by Atrihalov » Jun 08 2020 7:14am
Hello everyone. Help me. I flashed the last configuration, indicated that only the inductor and in the configuration file put 1 on the inductor. But the motor does not work from drosel. What else needs to be done?
mbrusa   100 W
Post by mbrusa » Jun 10 2020 2:16am
Atrihalov wrote:
Jun 08 2020 7:14am
I did not understand the question.
Can you explain yourself better?
Atrihalov   100 mW
Post by Atrihalov » Jun 10 2020 10:27am
Sorry, bad translation. The question is this. Throttle does not work. Programmed the last configuration. In the configuration files, I set the value to 1 to the throttle.
mbrusa   100 W
Post by mbrusa » Jun 10 2020 11:24am
Atrihalov wrote:
Jun 10 2020 10:27am
Have you enabled "Brake sensor"?
Atrihalov   100 mW
Post by Atrihalov » Jun 11 2020 12:51am
mbrusa wrote:
Jun 10 2020 11:24am
Atrihalov wrote:
Jun 10 2020 10:27am
The brake sensor did not turn on.
HrKlev   1 W
1 W
Post by HrKlev » Jun 11 2020 1:00am
Regarding the hardware calibration method that is described in the Wiki, what exactly do you calibrate when you perform this method? The scale of the sensor? I have 2 bikes with the tsdz2, and on my main bike the difference between right and left pedal is big. Its not a problem when I'm up to a certain speed, it is the force that is needed on the pedal to get assistance from standstill that is a little annoying. I have tuned hat when I push the right side pedal really hard, it starts the assistance. That makes the left side so that I can barely rest my foot on the pedal without the assistance starts. It is a little annoying in the technical trails when trying to get up on the bike, it is not always possible to start with the left foot.
If it wasnt for my other bike which is damn close to perfect, I would have just thought you get what you pay for (this motor is really cheap for what it is capable of after all). If it is an easy way to fix it, I figured it was worth a shot. I tried to read the wiki, but I'm not sure if hardware calibration of the sensor would help this issued with the pedals being so different?
Atrihalov   100 mW
Post by Atrihalov » Jun 11 2020 2:18am
Atrihalov wrote:
Jun 11 2020 12:51am
mbrusa wrote:
Jun 10 2020 11:24am
Atrihalov wrote:
Jun 10 2020 10:27am
The brake sensor is not turned on.
Luca68   1 µW
Post by Luca68 » Jun 11 2020 3:19am
Hello to all and a dutiful thanks to all those who contribute with their knowledge and their time.
Over time I have electrified several bicycles with the tsdz2 and thanks to you I find them all fantastic.
Now my question
after analyzing all the various forums (even the Italian one) I don't understand why the SW102 display with 8 pin adapter works with the original sw without the need of bootloader (for example the one sold by eco cycle) and cannot work with the firmware modified by mbrusa (thanks again for the effort)
Of course I don't want to be able to change parameters on the fly just to use it as a command to change assistance levels and to be able to view battery power and speed.
I usually change the parameters only with the java configurator
so I ask you if it is possible to use the SW102 command in place of my current VLCD5 and possibly how to set the java configurator to make it active.
Thanks Luca
mbrusa   100 W
Post by mbrusa » Jun 11 2020 3:25am
Atrihalov wrote:
Jun 11 2020 2:18am
The throttle works only with the brake sensor enabled in the JavaConfigurator.
Atrihalov   100 mW
Post by Atrihalov » Jun 11 2020 5:50am
mbrusa wrote:
Jun 11 2020 3:25am
Atrihalov wrote:
Jun 11 2020 2:18am
Fulfilled all the recommendations, but the motor does not work from the throttle.
mbrusa   100 W
Post by mbrusa » Jun 11 2020 6:36am
Atrihalov wrote:
Jun 11 2020 5:50am
If the throttle does not work and the settings in the configurator are ok, it does not depend on the software.
There is probably a problem with the throttle wiring, or with the brake sensors.
Atrihalov   100 mW
Post by Atrihalov » Jun 11 2020 6:42am
mbrusa wrote:
Jun 11 2020 6:36am
Atrihalov wrote:
Jun 11 2020 5:50am
Thanks for the advice. I do not have brake sensors. The throttle works on factory software. I like how the motor works on your configuration, I need a throttle to start. But alas, it does not work.
mbrusa   100 W
Post by mbrusa » Jun 11 2020 6:53am
Atrihalov wrote:
Jun 11 2020 6:42am
I don't understand if "Brake sensor" is enabled?
It must be enabled even if they are not installed!
