Hello experts,
Also am an electronics noob, so apologize in advance if this is too basic.
I have 2 motors from 2 brands.
These are BLDC In-Hub Motors for an Electric Scooter (2 wheelers - not toys you see in curbs of American cities!!)
One claims a rated power of 1000 watt and peak power of 2500 watt, Gradebility of 22 degrees. This uses a 72V system.
Another brand says they have a motor rated at 1000W with a Peak power of 1500W and claim Gradebility of 7 degrees and this uses a 48V system.
Both use a 2 kWh battery packs.
Now how do i arrive at the power (in kW - don't care bout antiquated HP) that will be generated by each motor at say 2000 RPM
And how do i arrive at the Torque at the said RPM.
Apart from Power at RPM and Torque at RPM, what other parameters do i need to look for while comparing the two.
How do we trust their grade-ability claims?
Thanks in advance!
Thanks in advance!
