Vector Storm e-bike Frame 299€ / Parts WORLDWIDE
Artur   100 kW
Re: Vector e-bike Frame 599$ /Adaptto/Parts WORLDWIDE
Post by Artur » Jul 11 2018 3:13am
We use set of rings so you can use any fork. Headset included.
calfeetwenty   100 mW
Post by calfeetwenty » Jul 12 2018 9:13am
Artur wrote:
Jul 04 2018 12:27pm
4t has high speed, low torque
7 t has high torque , low speed
5t in between
If you want to climb a mountain and don't need high speed take 7t for better efficiency
If you ride on flats and need high speed take 4t
Whant to be in a middle - take 5t
Thanks for that simple explanation. I have a 6t that I have not been able to use because of a broken arm. I have been going crazy wanting to try it out but will have to wait about a month. Your explanation makes me think I made a good choice.
Electra 7D/BBSHD, 24 spd hybrid drive 52 volt.
Electra 7D Fat/Mxus 3000 Turbo, 72 volt.
Paratrooper Pro/BBS02/Alfine 8, 52 volt
KMX Trike 1500 Edge 72 volt
Luna Cargo/ QS 205/50 6T back at it
Vector Typhoon…..soon
ryllz   1 µW
Post by ryllz » Jul 14 2018 5:21pm
I'm looking to buy an adaptto setup for a upcoming build, but can't find a 30A charging coil for sale anywhere - vector does not sell them separately (only with a power supply at an extra $105) and I haven't got any responses from envolt. Is there any other resellers I can buy from?
chilltrout   10 W
Post by chilltrout » Jul 19 2018 10:28am
Artur wrote:
Jul 11 2018 3:13am
Do you have some pictures of this?
Artur   100 kW
Post by Artur » Jul 19 2018 10:57am
chilltrout wrote:
Jul 19 2018 10:28am
Artur wrote:
Jul 11 2018 3:13am
http://vectorebike.com/gallery/photos/8 ... 2000w.html
calfeetwenty   100 mW
Post by calfeetwenty » Jul 20 2018 1:22am
What is this piece for? I didn't receive one.
Artur   100 kW
Post by Artur » Jul 20 2018 2:15am
Part of the battery.
ryllz   1 µW
Post by ryllz » Jul 20 2018 8:15pm
Just bought a complete Mini-E/BMS/coil kit from Vector - ended up just going with the coil/PSU combo since that was the only option.
Waiting to confirm the specs on the PSU as the initial 48v 35A one offered didn't fit in the package for shipping.
Pretty good communication with Vector, and the response is quite consistent (much better than Luna so far).
Will make a post on my build and how the controller performs (pairing it with a MXUS 3kW Turbo).
Heard good things from my friend with a Mid-E and Mini-E, but another one with a Max-E has had some issues (his own fault mostly). Excited to get my kit running! :D
Artur   100 kW
Post by Artur » Aug 01 2018 10:23am
Bg-electric-cycle   10 mW
Re: Vector e-bike Frame 349$ /SUMMER DEAL/Parts WORLDWIDE
Post by Bg-electric-cycle » Aug 06 2018 3:12pm
Just waiting for my invoice to begin my journey into the Vector club. :D The special offer is to be seized upon while it lasts.
Artur   100 kW
Post by Artur » Aug 06 2018 5:25pm
Bg-electric-cycle wrote:
Aug 06 2018 3:12pm
Wellcome onboard! :D
Artur   100 kW
Post by Artur » Aug 28 2018 12:53pm
We continuesly improve our products with your help guys. Now we offer right smooth bolts with frame for rear shocks, no therad on contacts - less preasure on material!
Artur   100 kW
Post by Artur » Sep 04 2018 11:34am
only 10 frames for this price.
Artur   100 kW
Re: Vector Storm e-bike Frame 299€ / Parts WORLDWIDE
Post by Artur » Sep 11 2018 2:08pm
Artur   100 kW
Post by Artur » Sep 17 2018 10:39am
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 14 2018 6:30am
People , buy these frames,
so that Artur can start selling frames ( light frame ) with a better swingarm, and with the main frame that has the opening on the side ( not bottom ) for the batteries , so that we can take out the battery pack each ride .
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 23 2018 2:03am
ScooterMan101 wrote:
Oct 14 2018 6:30am
so that Artur can start selling frames ( light frame ) with a better swingarm, and with the main frame that has the opening on the side ( not bottom ) for the batteries , so that we can take out the battery pack after each ride .
Dumsterdave   100 W
Post by Dumsterdave » Oct 25 2018 12:44am
Oct 14 2018 6:30am
I agree with the swingarm part, but I like how the battery is semi-permanently installed. Just add s charge port and there is no need to remove the battery
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 25 2018 1:45pm
I must take the batteries off/out of any bicycle frame that I own.
I use lipo's , you can not just use a charge port for them. there are several ( now up to 8 , and for a bike frame like the storm I would use 10-14 ) for balance charging charge one or two batteries at a time.
And
With lipo's you must store them correctly, that means in a lipo bunker, however you make your own bunker.
I keep the batteries outside in a safe " Bunker "
and
My bikes inside .
From what I have seen all the other bike frames from Vector/FUTR/EEB/ and others have the opening on the side.
I like this Vector Storm/Light frame because it is lighter than the others. and the price is right .
Now
If Artur can just get the Mfg to make a better swing arm ( 148 mm wide and for 27.5 and 29 er wheels ) that is more like the FUTR Beta Swing Arm
With option for ordering different plates on the back for
Hub Motors or Through Axle for mid drive applications .
1) for 10 mm slotted 135 wide hub motors
2) 10 mm slotted wider for the larger higher power hub motors
3) 12 mm 143 mm through axle hub ready
4) 12 mm 148 mm wide for the new boost standard through axle hub wheels.
and
Have the opening on the side for installing batteries and anything else
Vector / Artur would then have a winning combination of Price/Weight/Function.
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 25 2018 3:03pm
Many people have burned part of their house charging battery packs, even the so called safe round cells.
Here is just one article on what can happen.
Remember this happened to many people. Many people both with e-bikes and Hobby Flyers .
Lipo's or Round 18650 cells.
It really is better to take the batteries off your bike to charge and store them, no matter which kind of battery pack you have
viewtopic.php?f=1&t=87975&hilit=dogman+dan
coldyl   1 µW
Post by coldyl » Oct 29 2018 7:55am
Hi guys.
Would this crankset work with Vector Typhoon?
https://www.aliexpress.com/item/2018Alu ... 511d7e41bd
I would probably add 42T chain ring on it.
Artur   100 kW
Post by Artur » Oct 29 2018 8:30am
I don't see the reason it won't fit. :-)
coldyl   1 µW
Post by coldyl » Oct 29 2018 9:01am
Artur wrote:
Oct 29 2018 8:30am
Thank you Artur. :thumb: While i have you here, can you recommend size/lenght/spring for rear shock?
Artur   100 kW
Post by Artur » Oct 29 2018 9:04am
We recommend and offer 650/850 lbs springs. 220mm eye to eye shocks.
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 31 2018 12:26am
When you do design some new Light/Storm frames , I request among other things, shock mounts that are for 200 mm eye to eye. Perhaps a mount that will accept either a 220 mm eye to eye shock and a 200 mm eye to eye shock.
And A light frame designed to work with 130-160 mm travel front and back, that will allow us to use off the shelf Fox/Rockshox/Manitou/X-Fusion , etc. forks that are common and can be bought for good prices for last years models. Tapered , Single Crown .
And
Different plates on the rear of the swing arm to be able to switch / use different back wheels like ...
130mm x 10 mm slotted axles
150 + mm x 10/12 slotted axles for the heaver and large DD hub motors
143 x 12 mm through axle hub wheels
148 x 12 mm through axle hub wheels
And
swing arms designed to accept 27.5 and 29 er wheels, up to Boost/+ size tires.
And
Opening on the side on the the light/storm frame for the battery placement.
I am available to help you/the mgf. of the Vector frames design a newer improved frame .
Come to California , meet with me for design improvements.
( We have great weather this time of year in California for some extra incentive to fly over her for a week or two )
