Nucular electronics - complete kit for ev! [beta]
icherouveim   100 W
Re: Nucular electronics - complete kit for ev! [beta]
Post by icherouveim » Sep 24 2018 4:42am
VasiliSk wrote:
Sep 24 2018 3:26am
price will be known after production
Will it be cheaper compare to a similar adaptto ?
VasiliSk   100 W
Post by VasiliSk » Sep 24 2018 5:05am
there is no adaptto analogue for 6F
12F price in first message, same as all information about controllers
macribs   1 GW
1 GW
Post by macribs » Sep 24 2018 5:28am
VasiliSk wrote:
Sep 14 2018 10:55am
Owner of bike planning to make 20S battery.. with 200Ab max, so 15kW.
Absolute limit for 24F controller may be 25kW
The adaptto max-e was an 18 fet controller, or was it the midi that was 24 fet?
I am still trying to take in the power numbers for your upcoming 24 FET controller. Seems it will be a perfect match for the Sur Ron and other hot rod builds. I think your 24 Fet will be perfect for a scooter convertion, I bought one long ago to make it into electric but I never found the controller and charging that met what I wanted but this might be it.
Can you say a little about charging? It will be charging via controller kind of like on the adaptto?
VasiliSk   100 W
Post by VasiliSk » Sep 24 2018 5:35am
charging through controller almost same, but in most cases you don't need extra coil (also right now only charging through motor is supported)
macribs   1 GW
1 GW
Post by macribs » Sep 24 2018 6:33am
Nice to not need the coil, real estate is always at a premium, and no coil means more room for batteries etc.
Charging thru motor? Can you elaborate more in details? What kind of charger will you recommend, preferable a charger that is so small it will be possible to have a on-board charger permanently mounted on the scooter. Will it balance the cells as well? High and low cut off? These are settings in the controller display?
My overall goal is to try to avoid filling up all the cavity under the seat with hardware, so that the scooter can be an all round usable daily rider around town, room for a bag of groceries, a place to store laptop or tablet to work, etc. But still with enough battery and power to pack a punch when the red light turns green and to keep up with traffic. Don't need a whole lot of range honestly as long as the charging is done in an easy manner.
VasiliSk   100 W
Post by VasiliSk » Sep 24 2018 6:35am
English subs
http://bit.ly/2mBptBB
schematic
at least you need to unplug charging port
macribs   1 GW
1 GW
Post by macribs » Sep 24 2018 6:51am
Nice!
csc   100 W
Post by csc » Sep 24 2018 11:28am
Excellent. Now I know why I kept my Flatpack.
VasiliSk   100 W
Post by VasiliSk » Sep 24 2018 12:03pm
Hi guys, i have promotional code for free tickets on mondial.tech, PM me if you want some
neptronix   100 GW
Post by neptronix » Sep 24 2018 1:33pm
That's a lot of power in a small package.
Are you using IGBTs or some magical FET??
Efficiency is everything :bolt:
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
The monster scooter: ? on a Cannondale Semi Recumbent.
icherouveim   100 W
Post by icherouveim » Sep 25 2018 12:21am
Powervelocity.com wrote:
Sep 24 2018 1:04pm
Maybe I missed it on pics, but I don't see shunts on the board. Is it using hall sensors for current sensing? Also, is it measuring current on DC line or on phases?
I am very happy to see other respectable developers to participate in this threat, that means we all think as a family and not like enemies like politicians do.
VasiliSk   100 W
Post by VasiliSk » Sep 25 2018 3:36am
Im using shunt that measures phase current.
I have done some R&D work to make that power, it is complex, not only FETs, but PCBA and heat dissapation.
IGBT may be used only in 300V+ applications, not here
Powervelocity.com   10 kW
Post by Powervelocity.com » Sep 25 2018 11:18am
I would think it's more than just one shunt if phase current is measured. Two or three shunt configuration?
VasiliSk wrote:
Sep 25 2018 3:36am
icherouveim   100 W
Post by icherouveim » Sep 25 2018 2:11pm
VasiliSk wrote:
Sep 25 2018 11:43am
just one
Probably it measures one phase current and the software multiplies it times 3.
VasiliSk   100 W
Post by VasiliSk » Sep 25 2018 2:36pm
no, it actually sees every phase current. 2 phases for one cycle, 3d phase calculated
Post by Powervelocity.com » Sep 25 2018 3:57pm
With one shunt, I am guessing it would be low side DC measurement with calculation/reconstruction of the phase currents.
Something like this:
VasiliSk wrote:
Sep 25 2018 2:36pm
madin88   100 MW
Post by madin88 » Sep 26 2018 5:13am
To achieve accurate measurement of all ?? current's in less than 1µs with just one single-shunt, i guess it makes it necessary to use latest measurement technique (i mean newest chip's or hardware).
That's probabaly the main difference compared to those standard e-bike controllers (Infineon etc) which have also just one shunt in the DC- line. And added to this those standard controllers usually have no low-inductive power stage which is important as well to prevent the FET's from blowing at high currents..
csc   100 W
Post by csc » Oct 01 2018 3:23am
Well, ladies and gentlemen, I have two 12F in my hands. Just need to reassemble the whole bike and I'll give it a try. Very excited !
redline2097   100 W
Post by redline2097 » Oct 01 2018 4:55am
This can't be run with those LMX/Denzel motors? Like these:
http://www.eastgem.net/d4500.html
Is it cause high impedance or rough signal in these motors?
EDIT: Oh I saw this :"Hall filter programmed in my controllers."
So it could work now? Even with 10kw peak power? I could test it on my sons Kart thats currently running lmx motor and one of these shitty Kelly controllers. :D
maitilupas   100 W
Post by maitilupas » Oct 01 2018 6:19am
is this a sinewave motor? some are not sine , they look the same and have different waveform
ElectricGod   10 MW
Post by ElectricGod » Oct 01 2018 12:33pm
This is a cool project!
Any news when you will be selling product?
What about voltage range? Is 150 volts a possibility?
