KMX Trike Rear Suspension
adam333   100 W
Post by adam333 » Jul 05 2019 6:15pm
KMX Rear Suspension
Fit on any recent adult KMX steel frames.
Travel : 60mm (2.35in)
Bike total length will increase by 70mm (2.75in)
Material: Alu 6061-T6 Black Anodized
Weight: 2.24 kg ( reg shock )
2.10 kg ( air shock )
!!! Modification is required on your KMX. !!!
This kit instalation requires you to cut and drill your KMX steel frame.
You need to be confident enough in your hand skills and have a few basic tools.
Read the PDF procedure here before placing an order : Rear suspension procedure
Warning!! This custom item will only fit on a KMX Trike but it is not a genuine KMX product!!!
This kit include a rear suspension unit + hardware + step by step instruction.
___________________________________________________________________________
Regular shock:
Good with light weight rear wheel ( no hub motor )
Air shock:
Recommended if you have a heavy rear wheel ( hub motor )
The air shock will help to reduce the rebound.
Rear seat posts are no longer attached near the rear wheel.
They are now bolted to the new suspension.
1 min video showing the suspension in action:
Reg shock kit : 450 us$ + shipping
Air shock kit : 495 us$ + Shipping
qwerkus   10 kW
Re: KMX Trike Rear Suspension
Post by qwerkus » Apr 03 2020 4:15pm
Nice work. Have you considered just sawing off completely the square tube below the seat all the way up to its perpendicular counterpart and develop a matching bolt-on solution ? I think you could gain around 50mm total length this way an make for an even cleaner look. Not sure it would work on you kart because of the battery case.
adam333   100 W
Post by adam333 » Apr 03 2020 7:50pm
Thanks!,
Agreed, the tube could be cut at a different place, but I had no other option for my trike because of the battery box.
adam333   100 W
Post by adam333 » Jun 18 2020 6:56pm
Here is a good example of the tube being cut even longer than mine :
Thanks Carroll for the pictures.
