Mac motor, em3ev battery, 56t ring, CA V3, ebrakes, etc...
Peterfr12   100 mW
Post by Peterfr12 » Jul 28 2019 3:25pm
I am building a new ebike with a MXUS motor, 12F nucular controller and a 20s14p battery with a new 80t ring and ENO freewheel. Hence, I need to get rid of my former ebike kit and other goodies which has been unused the last 6 months.
EM3EV KIT with 9684 km on it used only on Tarmac in UK. Kit was purchased in June 2016.
MAC hub motor 8t laced to a new black 26 inch Halo SAS rim (at 5000 km) and fitted with a brand new 365 Schwalbe marathon tyre (0 km on it). Dropout: 135 mm. Motor has been fitted with a new clutch at 5000 km. It includes the DNP 11t 7speed freewheel and two torque arms and 2 brand new nuts and a new electric plug. The Halo SAS is a very strong rim. I have no issue with this wheel. Price : 140£ negotiable
mac motor 2.JPG (65.02 KiB) Viewed 857 times
mac motor 1.JPG (65.24 KiB) Viewed 857 times
Nuts for mac motor.JPG (95.58 KiB) Viewed 857 times
torque arms.JPG (85.28 KiB) Viewed 857 times
12 FET Infineon Controller 40A : Price : 30£
em3ev controller 40A.JPG (81.72 KiB) Viewed 857 times
One clutch : 15£
2 ebrakes from Grin technologies Canada including a Rear Trp disk brake calliper and cables: 30£. There are few scratches on the levers but it does not affect their function. See the pictures.
ebrake with Trp for rear.JPG (76.9 KiB) Viewed 857 times
2 HWBS ebrake sensor : 10 £
One Cycle Analyst V3 with cable for computer: 70£
CA V3.JPG (48.1 KiB) Viewed 857 times
A 56t ring TA Zephyr 110mm BCD 5 Arm Outer Chainring. Silver. 60£. useful in combination with a 11t sprocket to be able to pedal at 37 mph at low frequency.
56t Ring.JPG (57.98 KiB) Viewed 857 times
A 24 inch black SAS wheel 36 holes, 36 mm width– very strong wheel - with Shimano XT hub. In the sale I include a 180 mm disk brake and Schwalbe marathon tyre (not new). The wheel has only done 4500 km, only on UK tarmac. 60£
24 inch SAS Halo disk .JPG (95.71 KiB) Viewed 857 times
DC DC converter from em3ev. Never been used. still wrapped in plastic. 7£
One 14s9p battery. 58V 27Ah with 80A BMS; 30Q cells. Rcold= 0.016 ohm; Rmax=0.070 ohms after 30 miles . At least 215 cycles as I forget to reset the battery after charging it several times. Always charged at 80% and never discharged below 20%. When new I could cover 30 miles with only 11 Ah @ 30 mph. The battery is still working well and I can cover 30 miles easily @ 30mph while charging it at 80%. However, it seems that a row of cells has been disconnected as suddenly the voltage dropped to 54V when I pulled 40A in January 2019, and then the voltage decreases continuously slowly from 54V to 51V. I have not opened the battery. For someone who can solder, it will be really a good bargain. 200£ negotiable.
14s 9p battery.JPG (74.87 KiB) Viewed 857 times
14s 9p battery paper.JPG (46.18 KiB) Viewed 857 times
Two Chargers from em3ev for 14s battery : 40£ each
Mean Well 50W Isolated DC-DC Converter Chassis Mount, Vin 36 → 72 V dc, Vout 12V dc ,can be adjusted between 11 and 16V , I/O isolation 1.5kV ac, output : 50W max. £15.
50W dc dc converter.JPG (84.91 KiB) Viewed 857 times
A brand new 17 inch motorbike wheel laced to a Novatec 20 * 110 mm hub. Still in its box. Never been used. 85£
17 inch motorbike wheel.JPG (41.7 KiB) Viewed 857 times
2 stainless steel 316 plates. These plates were designed to be used as torque arms but I have to change the design once I received them.
Pate 1 ; Length : 153 mm; Height : 73 mm Thickness : 8 mm with several holes
Plate 2 ; Length : 147 mm; Height : 79 mm; Thickness : 8 mm with several holes
10£ each
plate stainless.JPG (85.4 KiB) Viewed 857 times
Shipping from UK is not included in the price. I can ship worldwide (except the battery maybe). Price can be negotiable. payment by Paypal/bank transfer or cash on collection.
Any questions, please ask.
Best regards,
Peterfr
Jonacourt   1 µW
Re: Mac motor, em3ev battery, 56t ring, CA V3, ebrakes, etc...
Post by Jonacourt » Jul 30 2019 10:07am
Hi,
I am looking to build an ebike and the 8T is the motor I was looking at, with your speed controller and 26” wheels what was your top speed and setup, if I took the motor,speed controller and CA what would your price be?
Regards,
Jon
Jonacourt   1 µW
Post by Jonacourt » Jul 30 2019 11:28am
Hi,
I am in the UK so no problem, I would like the motor, speed controller, ca and a charger, depending on your location I can collect, would you accept £240 for all,
Regards,
Jon
Peterfr12   100 mW
Post by Peterfr12 » Jul 30 2019 11:47am
Hi John,
My top speed with a battery (14s9p) charged at 80% was 35 mph with a recumbent bike, 31 mph with a diamond frame.
Where are you based, i am in hertfordshire? I made an offer to someone who wants to purchase the wheel, CA, controller and also the big battery. if he refused it, I will come back to you.
Best regards,
Peterfr
Jonacourt   1 µW
Post by Jonacourt » Jul 30 2019 1:22pm
Hi Peter,
I am in Somerset so not that far from you, I am happy to collect, I will wait to see what happens,
Regards,
Jon
Peterfr12   100 mW
Post by Peterfr12 » Jul 31 2019 6:51am
Hi John,
I send you a private message. OK for £240.
Best regards,
Pierre
Jonacourt   1 µW
Post by Jonacourt » Jul 31 2019 9:05am
Hi Pierre,
Many thanks,
How do you want the money, I can pay you in cash on collecting, just let me know,
Regards,
Jon
Peterfr12   100 mW
Post by Peterfr12 » Jul 31 2019 11:18am
hi John,
Cash on collection.
Best regards,
Peterfr
mxer   1 kW
Post by mxer » Aug 05 2019 3:39am
Did everything sell ?
Peterfr12   100 mW
Post by Peterfr12 » Aug 05 2019 5:26am
Hi
Motor, CA, charger and controller will be collected this evening.
so battery is left as well as the ebrake, large 56t ring, 24 inch wheel. I have also an extra charger left.
Best regards,
Pierre
mxer   1 kW
Post by mxer » Aug 05 2019 6:59am
Thanks.
Re the battery if someone can help out on the voltage drop?..
The reason I ask is I believe they are spot welded, unlikely a cold solder fix?. Also read 30q cells don't last too long, which brings me to the conclusion some cells have failed? Is this an easy fix,find?.. I'm interested in buying but need to be sure what I'm buying?.
