20Ah li-on NMC cells UK London new boxed £12 each on box of 50 limited stock
Re: 20Ah li-on NMC cells UK London new boxed £11 each on box of 50 limited stock
No worries still have some pm sent
Still I have stock for EU and UK .. outgoing messages dont seen to be going so if interested please pm me an email address so I can reply.. or a what's app... James
Just to be clear the last of the stock I have of these are £11 a cell when buying a full box of 50 cells.
Up to 49 cells are £12 per cell.
I have 1p 2p 3p 5p and 7p busbars available also.
Happy days.
Happy days.
Yes I still have some eig co20b cells and can send to Europe until late December Please pm me if you need any ... UK based near London.
Could I rig 4 of these up in series to give 14.6V and use a FSESC thingy like this as a controller?
To drive one of these
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Well, four in series, fully charged to 4.15v each is going to be 16.6v. Nominal at 3.65v / cell makes that 14.6v. If the controller can handle that, then it'd work, depending on the current requirements of your system; the cells themselves are rated for 5C continous so can do 100A all day long (well, for about 10 minutes till they're empty
) at 4s1P. Can do 200A (10C) for a few seconds at a time.
Whether the Flipsky thing can run whatever motor you're using under whatever loading conditions you have, I couldn't say.
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
@amberwolf thanks for your input
I think I only want to do single figure amps pull
this is the motor spec
Model: 6384
Motor KV: 120KV
Voltage: 24-36V
Speed: 45km/h
Power: 4600W
Unloaded Speed: 3600rpm/24V
Unloaded Current: 2.5A/12V
Efficiency: 85%
Load Bearing: 150kg
Axle Dia: 10mm
Size: Approx. 63 * 80mm / 2.5 * 3.1inch
Weight: Approx. 1052g
These cells might seem like overkill BUT me, bike and all the hardware would likely be less than 80kg - that's 175LBS in old money
SOOOOO if I can do 100-200km with a 2kg battery pack then that's winner winner healthy dinner
Model: 6384
Motor KV: 120KV
Voltage: 24-36V
Speed: 45km/h
Power: 4600W
Efficiency: 85%
Load Bearing: 150kg
Axle Dia: 10mm
Hi James. My emails is ferencis@yahoo.com, please send me yout contact details. Thanks
Re: 20Ah li-on NMC cells UK London new boxed £12 each on box of 50 limited stock
I still have a some cells... remaining stock is £12 a cell I need to make some doe on some ...loads sold and in lots of great projects
Do you know the story about shipping them to Ireland? Any issues with import duty etc....?
Hi there I can ask about Ireland... Pm me
Do you still have cells avaliable
Yes still have some left PM me for details.
Hey Jimbob,
I've got your cells and your aluminium busbars.
The terminals on the cells appear to be copper - is it a good idea to connect them using alu busbars? Won't such connection corrode significantly?
Thanks
Thanks
- amberwolf 100 GW
- Contact:
You can use NoAlOx to help with that.
https://www.idealind.com/shop/noalox.html
Thanks - will it cope with high current? I've only ever seen such pastes on application with very small wires.
Would nickel plating help?
Some are tin plated... Or some people use as amber wolf suggests the no alux paste
- amberwolf 100 GW
- Contact:
The NoAlOx doesn't do the current conducting--it just protects the connection against oxidation by keeping the air out of it.
You can also think of it similar to way heatsink compound works: filling all the little macroscopic and microscopic pits and scratches, to keep the air out, while the actual metal-to-metal contact of heatsink to device does most of the work, because you don't want to slather it on in gobs...just barely coat the surface...that's all it takes.
In the case of heatsinks, it's because air is a TERRIBLE heat conductor, and almost anything is better than having air between the surfaces.
NO-OX-ID "A Special"
been told better than any others, at least in a salt-spray/fog environment
