20Ah li-on NMC cells UK London new boxed £12 each on box of 50 limited stock
amberwolf   100 GW
Re: 20Ah li-on NMC cells UK London new boxed £10 each on 50
Post by amberwolf » Dec 14 2019 10:57pm
jimbob01 wrote:
Dec 14 2019 10:05am
Depends how big your bike is... people are running them..and at 10c they are nice for high power applications. :D
That's 10C burst for a few seconds, only 5C continuous. ;)
(I use this model of EIG cells on my SB Cruiser trike, used, from a different source).
jimbob01   100 W
Post by jimbob01 » Dec 14 2019 11:12pm
SB cruiser...cool 😁
cwah   10 GW
Post by cwah » Dec 15 2019 6:14am
I really like it but I can't see how I can fit it in my normal ebike. Will get 18650 instead.
Too bad because I like the price and I'm in london as well
jimbob01   100 W
Post by jimbob01 » Dec 15 2019 6:46am
They do pull out of the aluminium cases which makes them 7mm thick 225mm high Inc terminals and 130mm wide ..
😊 They are priced to sell and I've sold quite a few...I still have several hundred available
amberwolf   100 GW
Post by amberwolf » Dec 15 2019 10:18pm
Those cases are the best way to keep them housed; they make packaging and connection VERY easy and reliable. Though they do add bulk to the resulting pack, they also protect the cells.
These are a good reliable brand and model cell.
If I had any money to spare for it, I'd buy as many as I could afford. (but shipping would be insane from UK to Arizona.... :( ).
cwah   10 GW
Post by cwah » Dec 16 2019 3:01pm
Same if there was space on my bike i 'd buy them
jimbob01   100 W
Post by jimbob01 » Dec 18 2019 5:27pm
I've got more stock left at £10 a cell on a box of 50
I will sell any quantity 😁
frenchie   10 mW
Re: 20Ah li-on NMC cells UK London new boxed £9 each on 50
Post by frenchie » Dec 25 2019 4:48pm
Weird looking things
I'm trying to get my head around the config and @amberwolf seems to think these things are magic :D
Soooooo in 1 of your pics you have 10 cells, 2 lots of 5 with the metal clamp here (the 2nd image) https://imgur.com/a/NEzsbRo
I think that one could maybe fit inside a bike frame cos it's like 50mm thick?
What are the volts, amps and watts in that config?
I know 'Ivy Watts has the power' from school but someone help me out please :lol:
jimbob01   100 W
Post by jimbob01 » Dec 25 2019 5:21pm
Hi Frenchie that pic is just to show various types of connection plates...they are 5p end plates in the pic.. 10cells will give you 36v nominal @20 ah....you would have to use small copper strip to make a 1p pack ...10s 1p
10 cells in series are good for 100amp continuous
200 amp for 10 sec bursts
James
snejky   10 W
Post by snejky » Dec 28 2019 2:37am
I just want to share my experience with buying from James. James is very helpful. The business was exemplary. I bought 3 boxes of 50 batteries. I feel like I've never made a better purchase. All batteries in the original packaging. All batteries have a storage voltage of 3.73V. I'm sure we'll buy more batteries from him. :bigthumb: :bolt:
acollins22   1 µW
Post by acollins22 » Dec 28 2019 1:11pm
Hi Folks,
I'd just like to echo what snejky has said.
I've been to see James and had a very good chat about batteries and EV in general before purchasing a few boxes of these cells. All have been stored well with no signs of damage at all. Still in their boxes and plastic tie straps.
As well as the cells I came away with some very helpful information and some real enthusiasm for the project that awaits me :-)
Cheers,
Andy
ecross   1 kW
Post by ecross » Dec 30 2019 12:31pm
jimbob01 wrote:
Oct 21 2019 4:36am
NEW PRICE!!! £9 each !!!!
Eig co20b 20 ah cells boxed and sealed 3.7v screw terminals
Energy innovation group high quality li-nmc South Korean cells I have several hundred for sale
all are boxed
pm message me if you are interested
£9 a cell on 50 cells
5c continuous rated
10c bursts
Tested 95 -105% capacity
http://imgur.com/gallery/lo8jgaO
http://imgur.com/a/NEzsbRo
I'm in London UK :D
Hello James,
EU is very good!
-the 50 cells are coming without bus-bars, or?
-for example: a 50 cells box need some bus-bars for a 10S5P battery like 36V and 100Ah!
-I`m looking for 36V 100Ah battery, so I need also the bus-bars, do you have some 5P bus-bars for sale?
BR
ecross
NC 2805 mod.
H4080 mod.
4504 mod.
4503 mod. with watercooling
LiIon 24S16P from Sony, Sanyo, Panasonic
Siemens 2000W travel charger
jimbob01   100 W
Post by jimbob01 » Jan 01 2020 5:50am
Hi ecross... The cells come in boxes of 50 cells sealed in new packaging...
I have laser cut some 5p bussbars in 3mm aluminium.. I have some at £4 each
Drawing is freely available if you want to cut your own
Also other people are making packs in 7p 2p and I'm sure they will share dFX files which the laser people request... 😁
Regards James
amberwolf   100 GW
Post by amberwolf » Jan 01 2020 1:54pm
while it's not as easy to assemble as simple busbars, for lower current applications you can also crimp small eyelets to braided wire (similar to what solderwick looks like) or regular wire, and bolt the eyelets to the cell package terminals. since there's two bolt holes in each terminal, you can use two wires for each current path, doulbing the current from a single wire. to use larger eyelets you just have to file the edges flat so they fit between the plastic ridges.
thats how my original 4s1p lighting pack was built, though i only used one wire on each path as i only needed a few amps at most for the lights.
but i use busbars on the traction packs because much higher current is needed and it's simpler to build--but wires could be used instead for the same thing if busbars are out of reach for you.
this post has pics of some of my traction pack stuff, including fusing and interconnects
viewtopic.php?f=2&t=67833&p=1263618
i just use a piece of lexan taped across the top of the pack to prevent anything from landing across the busbars. ;) but i can still see everything and i can cut the tape on one edge and lift the lexan to check balance/etc occasionally, without the hassle / risk of thin balance wires on every cell group.
amberwolf   100 GW
Post by amberwolf » Jan 01 2020 2:01pm
also
viewtopic.php?f=9&t=90740&p=1323258&#p1342871
jonescg wrote:
Dec 24 2017 10:49pm
I actually designed a selection of termination kits for the EIG cells, including 2p, 3p and 4p. They have been sold, but I have the PCB files here if anybody is interested.
agniusm   10 MW
Post by agniusm » Jan 04 2020 7:22am
@jimbob01 what year are those cells manufactured?
Thanks
jimbob01   100 W
Post by jimbob01 » Jan 04 2020 9:05am
They came from Detroit electric a couple of months ago and they said they were manufactured 2014/15.
All tests have shown 95% to 105% capacity
With pretty much every cell coming out the box at 3.73v..storage.
Regards James
jimbob01   100 W
Post by jimbob01 » Jan 13 2020 11:43am
I now have a drawing for 1p busbars that I'm happy to freely share please pm a what's app number if you would like to receive it 😁
amberwolf   100 GW
Post by amberwolf » Jan 16 2020 12:09am
i have an odd question, not related to buying cells from you (would if I could, though!).
do you have a way to get a reasonably accurate mass (weight) for one cell plus it's plastic holder/frame, plus the thin aluminum plate that's part of that holder? but not including busbars, etc?
i ask because i have a stack of these cells that i could use as a "calibration mass" for a scale i found at goodwill, but i have to know how much one weighs so i can make a 25kg mass (and a 50kg, and if necessary a 100kg if i have enough cells for that).
i know the mass of a single bare cell from the datasheet, but after quite a lot of searching and reading, i couldn't find the mass for the frame/plate or for a cell with one.
i don't have a caibrated scale that will measure this or i would do it myself..but once i have this scale calibrated, it will be useful for getting mass data for various ebike related stuff posted on es. ;)
jimbob01   100 W
Post by jimbob01 » Jan 17 2020 6:46pm
I will check on return from vacation and inform you after weighing 🙂 best regards James
amberwolf   100 GW
Post by amberwolf » Jan 18 2020 2:31am
i appreciate it. :)
oleon   1 µW
Post by oleon » Jan 18 2020 5:33pm
Hello
Can you ship 60 cells to Mallorca, Spain?
Send a pm with an estimate.
Thanks
jimbob01   100 W
Post by jimbob01 » Jan 18 2020 6:51pm
Hi there yes pm sent...
nickceouk   100 mW
Post by nickceouk » Jan 23 2020 8:33am
Not sure if the pm I sent you works as it s in Outbox and not going to Sent :?
Can I do a local London pickup - 14 cells ? Pm me how with details - can do same day too.
amberwolf   100 GW
Post by amberwolf » Jan 23 2020 2:06pm
nickceouk wrote:
Jan 23 2020 8:33am
https://endless-sphere.com/forums/viewt ... 13&t=15521
