ASI BAC Controllers Worldwide Vendor
Eryk   10 µW
10 µW
Re: ASI BAC Controllers Europe Vendor
Post by Eryk » Oct 10 2020 2:11pm
Hi, it this offer aktual? I have sent another query but no response
DtiK   1 W
1 W
Post by DtiK » Oct 12 2020 6:02am
i also sent message. is these available?
Electroenduro   1 µW
Post by Electroenduro » Oct 12 2020 4:59pm
I order one from martinmertik :thumb:
Waiting now, hope it will be greate update for Sur-Ron
Sur-ron 2020
john61ct   100 GW
Post by john61ct » Oct 12 2020 7:20pm
Darn, and thought there was one good dealer on the planet.
Martin-ASI wrote:The controller has components that will let out the magic smoke at 100V +/- 10% for hardware variance
How does ASI identify competent and reliable resellers for us?
I don't need one "near me", willing to pay international shipping
but need them to offer stellar after-sales support remotely over the internet.
Macmaxi   1 mW
Post by Macmaxi » Oct 14 2020 7:30pm
Is it possible with the Asibac 800 to always be able to use the throttle with full power regardless of the set support level?
If yes, a guide can help you achieve this,
Many Thanks
Macmaxi   1 mW
Post by Macmaxi » Oct 14 2020 7:32pm
Many Thanks
Fidel   100 mW
Post by Fidel » Oct 26 2020 8:30am
I even sent him an email, and no response.
Enviado do meu ONEPLUS A5010 através do Tapatalk
speedy1984   10 W
Post by speedy1984 » Oct 27 2020 12:45pm
Are these still for sale?
john61ct   100 GW
Post by john61ct » Oct 27 2020 12:53pm
The problem atm is no user support
wakko   1 mW
Post by wakko » Nov 02 2020 2:28pm
I've just checked the Bacdoor app on my phone and it no longer works. Anybody got any info on what we're supposed to do?
john61ct   100 GW
Post by john61ct » Nov 02 2020 2:35pm
@Martin-ASI ????
I would hope the mothership will support abandoned customers, at least referring to other dealers
wakko   1 mW
Post by wakko » Nov 02 2020 2:44pm
I hope so, I haven't even mounted the controller to the bike yet as I've been gathering other bits.
Eryk   10 µW
10 µW
Post by Eryk » Nov 04 2020 12:44am
I am thinking about buying, but I see only bad information here :( Maybe the seller will say what it is?
john61ct   100 GW
Post by john61ct » Nov 04 2020 8:24am
The seller has apparently disappeared
wakko   1 mW
Post by wakko » Nov 04 2020 3:57pm
I messaged ASI directly a few days ago and haven't got a response yet.
Nixunen   100 mW
Post by Nixunen » Nov 04 2020 5:16pm
wakko wrote:
Nov 04 2020 3:57pm
Unless ASI supports abandoned customers I can say that ASI has ripped me off as I have no way of programming my controller. I messaged ASI directly a few days ago and haven't got a response yet.
I think ASI can help you. But it cost like 200€ per hour. Or at least that is something i have read. Those password / login info from Martin haven't been working over a month now.
And ASI is not who is ripping you off, it is Martin. You have always option to bought directly at ASI and get your own login information. Problem here is, that Martin gave those passwords to every customers, when they are not meant to work like that. They are meant to only seller, and seller should config all controller, not end users.
Eryk   10 µW
10 µW
Post by Eryk » Nov 06 2020 10:08am
ASI has no interesting policy. As a result, controllers sooner or later become a worthless piece of brick. Second-hand purchase is a mistake.
xenodius   10 kW
Post by xenodius » Nov 06 2020 11:10am
I bought a devkit from ASI and I have never had problems with my login. But you only need the login for the bluetooth app and support site, you can program the controller by serial without a login via BacDoor even if it's second-hand.
wakko   1 mW
Post by wakko » Nov 08 2020 10:28am
xenodius wrote:
Nov 06 2020 11:10am
Where can you download the Bacdoor software for the PC though? ASI don't have a link on their website, probably just for the devkits.
jonnydrive   100 W
Post by jonnydrive » Nov 18 2020 1:26am
Same problem as you guys.
I partially solved using this:
https://www.amazon.com/DSD-TECH-Adapter ... 779&sr=8-5
Note: use jumper to select 5volt output signal
With the pc backdoor app (attached).
I also attached the wiring schema, the pins I use to connect TTL to BAC controller are: 17 e 18 for signal and 16 for common ground between controller and PC.
Bacdoor software (2).7z
(2.41 MiB) Downloaded 122 times
40-000417-A-01-R11-BAC500-EVALUATION-HARNESS.pdf
(46.48 KiB) Downloaded 77 times
Chin0   10 mW
Post by Chin0 » Nov 19 2020 7:15pm
jonnydrive wrote:
Nov 18 2020 1:26am
Excellent and thanks for sharing. Did you connect succesfully the ASI controller to the BacDoor PC software with this 3rd party adapter? The connection was full and stable?
jonnydrive   100 W
Re: ASI BAC Controllers Worldwide Vendor
Post by jonnydrive » Nov 20 2020 7:52am
It seems to be stable, I only use it for programming not for monitoring during ride
xenodius   10 kW
Post by xenodius » Nov 21 2020 11:49am
If anyone is curious, the usb-TTL adapter that came with my BAC8000 is a TTL-232R-5V-WE cable, with a 3-pin JWPF connector, and a UH401-2KV usb isolator. I would recommend using an isolator if you use another TTL adapter.
martinmertik   10 W
Post by martinmertik » Nov 27 2020 6:53am
For everyone that was asking.
I have not disapeared, I had problems with my website and mailing server. I did not receive most of my emails. All of customers that have already bought controllers from me got support and frequent replies through Facebook and whatsapp.
Also I couldn't get access to endless sphere forum for some time (some error.), after I used VPN servers I could get access.
Only new customers that were trying to get quotes and information about controllers did not get answers right away. I still have very good support.
I have updated front page of this topic and I redirected all new customers to my now sorted out email address.
martinmertik   10 W
Post by martinmertik » Nov 27 2020 7:09am
john61ct wrote:
Oct 12 2020 7:20pm
I went back through all my retrieved emails and personal mesages and I didn't find yours. I think you have not bought anything from me?
