ASI BAC Controllers Worldwide Vendor
xenodius   10 kW
Re: ASI BAC Controllers Worldwide Vendor
Post by xenodius » Aug 14 2021 12:05pm
Tiber wrote:
Aug 13 2021 11:15am
Would the BAC2000 be sufficient? The 4000 is out of my price range for now.
I have a BAC8000 and a QS205. Personally I would not use less than a 4000, it really is pretty well matched for the QS205. The biggest reason I like having an 8000 over the 4000 is the phase amps-- I've got upgraded phasewires, statorade, and hubsinks on my QS205 and while 450 is a very respectable peak phase current there have been times when I've enjoyed being able to crank the phase amps to 600 and watch the douche-canoes in supercars stop showing off to gawk at the 'bicycle' that just outpaced their six-figure midlife crisis... or to show off acceleration when people ask about it. 8) Technically my QS205 saturates around 220 phase amps but I've noticed 450 amps is about the point at which I notice it starts heating up much faster. I've only used 600 in short bursts.
I use my open-source Pi display to switch between power profiles on the fly with a 3-position switch, honestly if it wasn't for that and my motor mods I'd probably have been better off with a BAC4000 and sticking to 450 phase. :thumb:
Audisport09   10 W
Post by Audisport09 » Aug 17 2021 2:33pm
Another BAC4000 happy customer, thank you Martin. Fast delivery and great support. ASI is the t*ts!
martinmertik   10 W
Post by martinmertik » Aug 20 2021 9:22am
Audisport09 wrote:
Aug 17 2021 2:33pm
Thank you :D
Macaiah   1 µW
Post by Macaiah » Aug 23 2021 7:07am
I really want to purchase a BAC4000 OR BAC8000, but I need it wired for a Cycle Analyst V3 and anti-theft.
Is this something that can be done?
Sent from my SM-T860 using Tapatalk
martinmertik   10 W
Post by martinmertik » Aug 25 2021 1:38am
Macaiah wrote:
Aug 23 2021 7:07am
Hey,
yes, no problem. Write me to info@bull-bikes.si and we can talk further.
Best regards
msim   1 µW
Post by msim » Sep 18 2021 12:40pm
Any update on availability of BAC855. Last I emailed they were out of stock.
martinmertik   10 W
Post by martinmertik » Sep 22 2021 6:00am
msim wrote:
Sep 18 2021 12:40pm
Hey,
I'm getting them shortly, could you just send me an email so I can notify you when they are ready to ship out.
Regards
markisha   1 µW
Post by markisha » Sep 22 2021 11:47am
Hi all, can anyone give me a suggestion where I can get BBSHD harness for ASI BAC855 in EU, preferably.
Thanks!
Best regards,
aztecsurf   100 µW
100 µW
Post by aztecsurf » Sep 22 2021 3:59pm
Did anyone ever find a copy of the Bacdoor software we can get a hold of?
Ziip0   100 µW
100 µW
Post by Ziip0 » Oct 13 2021 5:35pm
Hello,
I would like to change my Adaptto Max-E 14kW controller (dead) for my NYX bike.
I got a QS 205 3000W.
I want same power, or even more, something that really kicks some ***
Motor change is an option too.
Any suggestions ?
Thanks.
XSRe   100 µW
100 µW
Re: ASI BAC Controllers Europe Vendor
Post by XSRe » Nov 07 2021 4:29am
I wanted to confirm if you can program any (programmed or unprogrammed) ASI BAC controller with this software and without a login? Because from my limited understanding so far, it seems you need a login to program the controller?
Some clarity would be much appreciated.
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Same problem as you guys.
I partially solved using this:
https://www.amazon.com/DSD-TECH-Adapter ... 779&sr=8-5
Note: use jumper to select 5volt output signal
With the pc backdoor app (attached).
I also attached the wiring schema, the pins I use to connect TTL to BAC controller are: 17 e 18 for signal and 16 for common ground between controller and PC.
papo2110   100 W
Post by papo2110 » Nov 14 2021 4:18pm
This is the motor I am running I want to know if it can be programmed into that BAC200 CONTROLLER
10S LIPO
https://youtu.be/HLEOIJ-lrhk
Motor Power: 5000W Max
Motor KV: 191kv
Model Type: 63100
Motor Wind: 9
Idle current: 3.1A at 10V
Motor Resistance: 0.0173hm
Motor inductance: 40uh
Max. current: 110A
Battery type: 4-12S
ESC: 100-120A
Torque: 9Nm
Diameter(mm): 63.4
Length(mm): 103
Total length (mm):135.5(including shaft)
Shaft(mm): 8/10 with keyway
2.0mm jst 6 pin hall sensor, if needed 1.5mm jst 6pin, pls let
jonnydrive   100 W
Post by jonnydrive » Nov 16 2021 5:52am
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
I have only one controller, the BAC 855. It seems that the software and the interface are the same for all the BAC controller, but I cannot be sure.
Audisport09   10 W
Post by Audisport09 » Nov 16 2021 3:40pm
jonnydrive wrote:
Nov 16 2021 5:52am
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Hello, could you please kindly explain which pins I would need to connect to my ASI 8000 for the USB to work? I need to adjust my throttle Thank you
Screen Shot 2021-11-16 at 20.36.35.png (183.39 KiB) Viewed 193 times
martinmertik   10 W
Post by martinmertik » Nov 25 2021 5:26am
Audisport09 wrote:
Nov 16 2021 3:40pm
jonnydrive wrote:
Nov 16 2021 5:52am
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Hello, could you please kindly explain which pins I would need to connect to my ASI 8000 for the USB to work? I need to adjust my throttle Thank you Screen Shot 2021-11-16 at 20.36.35.png
If you have a USB device, then you will need controller that is turned on and TX, RX and GND connected, pin 3, 13 and 14/15.
Welshdye   1 µW
Post by Welshdye » Nov 25 2021 2:47pm
Please can you let me know the price of a asi bac 855 controller kit with wire harness for bbshd,
Including shipping costs to the UK. Many thanks
martinmertik   10 W
Post by martinmertik » Nov 27 2021 5:12am
Welshdye wrote:
Nov 25 2021 2:47pm
Hey, we don't have BBSHD harness in stock unfortuantely for quite some time now.
We are sorry.
martinmertik   10 W
Post by martinmertik » Nov 27 2021 5:13am
For all inquiries please send us an email at info@bull-bikes.si
Thank you :D
