Page 8 of 8
Re: ASI BAC Controllers Worldwide Vendor
Posted: Aug 14 2021 12:05pm
by xenodius
Tiber wrote:
Aug 13 2021 11:15am
Would the BAC2000 be sufficient? The 4000 is out of my price range for now.
I have a BAC8000 and a QS205. Personally I would not use less than a 4000, it really is pretty well matched for the QS205. The biggest reason I like having an 8000 over the 4000 is the phase amps-- I've got upgraded phasewires, statorade, and hubsinks on my QS205 and while 450 is a very respectable peak phase current there have been times when I've enjoyed being able to crank the phase amps to 600 and watch the douche-canoes in supercars stop showing off to gawk at the 'bicycle' that just outpaced their six-figure midlife crisis... or to show off acceleration when people ask about it. 8) Technically my QS205 saturates around 220 phase amps but I've noticed 450 amps is about the point at which I notice it starts heating up much faster. I've only used 600 in short bursts.
I use my open-source Pi display to switch between power profiles on the fly with a 3-position switch, honestly if it wasn't for that and my motor mods I'd probably have been better off with a BAC4000 and sticking to 450 phase. :thumb:
Posted: Aug 17 2021 2:33pm
by Audisport09
Another BAC4000 happy customer, thank you Martin. Fast delivery and great support. ASI is the t*ts!
Posted: Aug 20 2021 9:22am
by martinmertik
Audisport09 wrote:
Aug 17 2021 2:33pm
Thank you :D
Posted: Aug 23 2021 7:07am
by Macaiah
I really want to purchase a BAC4000 OR BAC8000, but I need it wired for a Cycle Analyst V3 and anti-theft.
Is this something that can be done?
Sent from my SM-T860 using Tapatalk
Posted: Aug 25 2021 1:38am
by martinmertik
Macaiah wrote:
Aug 23 2021 7:07am
Hey,
yes, no problem. Write me to info@bull-bikes.si and we can talk further.
Best regards
Posted: Sep 18 2021 12:40pm
by msim
Any update on availability of BAC855. Last I emailed they were out of stock.
Posted: Sep 22 2021 6:00am
by martinmertik
msim wrote:
Sep 18 2021 12:40pm
Hey,
I'm getting them shortly, could you just send me an email so I can notify you when they are ready to ship out.
Regards
Posted: Sep 22 2021 11:47am
by markisha
Hi all, can anyone give me a suggestion where I can get BBSHD harness for ASI BAC855 in EU, preferably.
Thanks!
Best regards,
Posted: Sep 22 2021 3:59pm
by aztecsurf
Did anyone ever find a copy of the Bacdoor software we can get a hold of?
Posted: Oct 13 2021 5:35pm
by Ziip0
Hello,
I would like to change my Adaptto Max-E 14kW controller (dead) for my NYX bike.
I got a QS 205 3000W.
I want same power, or even more, something that really kicks some ***
Motor change is an option too.
Any suggestions ?
Thanks.
Re: ASI BAC Controllers Europe Vendor
Posted: Nov 07 2021 4:29am
by XSRe
I wanted to confirm if you can program any (programmed or unprogrammed) ASI BAC controller with this software and without a login? Because from my limited understanding so far, it seems you need a login to program the controller?
Some clarity would be much appreciated.
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Same problem as you guys.
I partially solved using this:
https://www.amazon.com/DSD-TECH-Adapter ... 779&sr=8-5
Note: use jumper to select 5volt output signal
With the pc backdoor app (attached).
I also attached the wiring schema, the pins I use to connect TTL to BAC controller are: 17 e 18 for signal and 16 for common ground between controller and PC.
Posted: Nov 14 2021 4:18pm
by papo2110
This is the motor I am running I want to know if it can be programmed into that BAC200 CONTROLLER
10S LIPO
https://youtu.be/HLEOIJ-lrhk
Motor Power: 5000W Max
Motor KV: 191kv
Model Type: 63100
Motor Wind: 9
Idle current: 3.1A at 10V
Motor Resistance: 0.0173hm
Motor inductance: 40uh
Max. current: 110A
Battery type: 4-12S
ESC: 100-120A
Torque: 9Nm
Diameter(mm): 63.4
Length(mm): 103
Total length (mm):135.5(including shaft)
Shaft(mm): 8/10 with keyway
2.0mm jst 6 pin hall sensor, if needed 1.5mm jst 6pin, pls let
Posted: Nov 16 2021 5:52am
by jonnydrive
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
I have only one controller, the BAC 855. It seems that the software and the interface are the same for all the BAC controller, but I cannot be sure.
Posted: Nov 16 2021 3:40pm
by Audisport09
jonnydrive wrote:
Nov 16 2021 5:52am
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Hello, could you please kindly explain which pins I would need to connect to my ASI 8000 for the USB to work? I need to adjust my throttle Thank you
Screen Shot 2021-11-16 at 20.36.35.png (183.39 KiB) Viewed 149 times
Posted: Nov 25 2021 5:26am
by martinmertik
Audisport09 wrote:
Nov 16 2021 3:40pm
jonnydrive wrote:
Nov 16 2021 5:52am
XSRe wrote:
Nov 07 2021 4:29am
Regards,
jonnydrive wrote:
Nov 18 2020 1:26am
Hello, could you please kindly explain which pins I would need to connect to my ASI 8000 for the USB to work? I need to adjust my throttle Thank you Screen Shot 2021-11-16 at 20.36.35.png
If you have a USB device, then you will need controller that is turned on and TX, RX and GND connected, pin 3, 13 and 14/15.
Posted: Nov 25 2021 2:47pm
by Welshdye
Please can you let me know the price of a asi bac 855 controller kit with wire harness for bbshd,
Including shipping costs to the UK. Many thanks
Posted: Nov 27 2021 5:12am
by martinmertik
Welshdye wrote:
Nov 25 2021 2:47pm
Hey, we don't have BBSHD harness in stock unfortuantely for quite some time now.
We are sorry.
Posted: Nov 27 2021 5:13am
by martinmertik
For all inquiries please send us an email at info@bull-bikes.si
Thank you :D
