Holstedtr's PedalUma Ad Thread
Holstedtr   10 µW
10 µW
Post by Holstedtr » Jan 25 2021 2:04pm
Last night I made a dust cover for my battery that looks a lot like a water bottle. I cut off the bottom of a Gatorade bottle then used a heat gun to fit it over the battery. The USB port is accessed by unscrewing the orange top. Does it look electric? Do you have a stealthy eBike build? Pictures of some stealthy eBikes that are clean mid-drive builds are on PedalUma.com
Stealthy electric bikes. Battery 'dust cover.'
dust cover.JPG (272.42 KiB) Viewed 471 times
. This is so much fun!
Holstedtr   10 µW
10 µW
Re: Stealthy Mid-drives that Do not look electric
Post by Holstedtr » Jan 26 2021 6:42pm
Did you make an eBike that does not 'look' electric? Please post photos.
Steel Public V7i with Nexus hub and battery that looks like a water bottle Torque sensor mid-drive Petaluma
Classic ride with Union Jack Torque sensor mid-drive that does not look electric Clean build Petaluma
Holstedtr   10 µW
10 µW
Post by Holstedtr » Jan 26 2021 8:29pm
What do you think about the wire spaghetti on this Specialized Chisel? I put a gravel riser/drop/flare bar on this standard mountain bike. Then I dropped it from an 11-Speed to 9 because the KMC X-8 chain is stronger and thicker. It has a torque sensor mid-drive. I can easily pull the battery and use a larger one anytime or take two to do a Century ride. Let's see some of your bikes that outperform the clunky ones from stores and do not look electric. See the wire from the 'water bottle'?
Specialized Chisel Conversion to Gravel mid-drive electric. PedalUma.
Takemehome   1 kW
Post by Takemehome » Jan 27 2021 1:08am
This is the FOR SALE section
Don't dream your life, live your dream.
Don't buy anything before visiting http://ebikes.ca
Justin, Thank you.
thepronghorn   1 kW
Post by thepronghorn » Jan 27 2021 2:22am
Yeah it was originally in the normal ebike section, but it got moved here since it's just advertising.
Small batteries in water bottles plus hiding the motor with camera angles can make a conversion look quite clean :wink:
Manbeer   100 W
Post by Manbeer » Jan 27 2021 7:20am
thepronghorn wrote:
Jan 27 2021 2:22am
so all these are is just a tsdz2 with water bottle battery right?
Holstedtr   10 µW
10 µW
Post by Holstedtr » Jan 27 2021 2:07pm
This is a Wicked Witch Princess Bike
It is for Tweed Run Days. I took the photo from a different angle as suggested to better show what is going on. The battery can be easily swapped for a more stealthy one. They just slide in and out of the water bottle cage. I went for one with 1/3 more capacity, and a flat top given this bike was designed in 1920 and has a lugged steel frame with internal brakes and gears. It also has baskets for the Farmers' Market and for Toto.
Do you have a clean build with a theme? Have you built a clean & classic Tweed Run electric bike?
Wicked Witch Princess eBike for Tweed Run days, has baskets for Toto and Petaluma Farmers' Market
Book Jacket Title
Witch Princess.jpg (25.74 KiB) Viewed 283 times
Holstedtr   10 µW
10 µW
Re: Gadgets on your eBike that you couldn't live without
Post by Holstedtr » Jan 28 2021 12:13am
It depends on the bike and style of riding. For a mountain bike I like a riser bar that drops and flairs and a dust cover for the battery that looks more like a water bottle. For a town bike I like a coffee cup holder, leather grips, a Brooks saddle and a bell. I do not want an electric bike with messy wires or a hub-drive with lag and surge or a primitive thuggish Bafang. https://pedaluma.com has some images of mid-drives with minimalist accessories such as these. Cheers to AU day!!!
leather grips on town bike with Brooks saddle electric bike. Pedaluma
Coffee cup holder. Pedaluma. e-Bike.
Riser drop bar on mountain electric bike Clock tower Petaluma.
dust cover for battery on electric bike Pedaluma
dust cover.JPG (272.42 KiB) Viewed 256 times
TDB   1 mW
Post by TDB » Jan 28 2021 3:14am
Holstedtr wrote:
Jan 28 2021 12:13am
...hub-drive with lag and surge or a primitive thuggish Bafang...
Funny guy...
Holstedtr   10 µW
10 µW
Re: Holstedtr's PedalUma Ad Thread
Post by Holstedtr » Jan 29 2021 11:29pm
You win. With your ugly, and burdened, heavy zip tie spaghetti-mess conversions suffering vulgar surge and lurch. Declare Victory. I am out. Thank you for your input. The gull out flies the turkey at PedalUma.com
Dumb Bafang with surge and lurch mistake and messy wire spaghetti wires conversion.
DSCF6680 (2).JPG (291.34 KiB) Viewed 186 times
Manbeer   100 W
Post by Manbeer » Jan 30 2021 7:51am
Dude, i think you are missing the point. While this forum caters to people of all skill levels, many of the posters are pretty skilled.
Not trying to sound like a dick so I will just assume that maybe you didn't bother to do much looking before posting. Most people here are at least somewhat familiar with the TSDZ2. Which, for what it is has its advantages over bafangs in some ways And disadvantages in others (Check the 300 page long thread on this motor in the non hub motors sections)
You did give the impression that you were showing off builds that were stealthy, but the reality is it would be like showing off a google home Or echo and saying "Check out the stealthy home automation system I created"
On that note, on your website you claim that they use open source software, yet none of the displays on any of the bikes are the ones that are compatible with the open source flash - Which by the way, was created by users on this forum
amberwolf   100 GW
Post by amberwolf » Jan 31 2021 12:00am
The OP pretty clearly only came here to drive business to his website (which is why his stuff was moved to this thread/subforum). I doubt he cares about what any of us do or can do, as long as he gets more business. :/
TDB   1 mW
Post by TDB » Jan 31 2021 1:46am
amberwolf wrote:
Jan 31 2021 12:00am
:thumb:
If that is the case I'd make it a double point to not give him a cent. The first was running down people for their choices.
