Customized Deep Cycle 60V 25Ah Lithium Ion Battery for E-bike
- Contact:
Model: 60V 25Ah
Nominal Voltage: 60V
Nominal Capacity: 25Ah
Dimension: 344 * 208 * 73 mm (or Customized)
Weight: 8.3 kg
Cell Type: LiFePO4
Cycle Life: 1200 cc
MOQ: 1 Pcs
Brand: Thinked
Certificates: UN38.3, MSDS, Certificate of Safe Transport of Goods
If interested,contact Scott at +86 18868121883 or via email sales@li-battery.com
The color of membrane outside the battery can customized as red,black,blue,green.
The clear image is in the attachment:
The Sale Price is 254.79 USD/Pcs.
The UN38.3& MSDS certificates is in the attachemnts. The product specification is also in the attachemnt:
Weight: 8.3 kg
Cell Type: LiFePO4
Cycle Life: 1200 cc
MOQ: 1 Pcs
Brand: Thinked
- Attachments
- 60V 25Ah 电动自行车电池-规格表2.jpg (174.29 KiB) Viewed 282 times
Re: Customized Deep Cycle 60V 25Ah Lithium Ion Battery for E-bike
What are the rules if you post here you got to put a price.
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Doesn't matter--I'm sure the factory already ran out of these, too.
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
What cells are used inside?
- amberwolf 100 GW
- Contact:
Good luck getting any actual info...especially that doesn't just "change". Check out the last sale thread:
viewtopic.php?f=31&t=110113
thanks. no harm in asking, I wouldn't consider buying without trust, and starting point for that is full disclosure
- Contact:
- Contact:
Pls delete this last sale thread,aborted .amberwolf wrote: ↑Feb 19 2021 3:58amGood luck getting any actual info...especially that doesn't just "change". Check out the last sale thread:
- Contact:
- Contact:
- Contact:
- Contact:
Thank you for specifying the actual maker / brand / model cells.
And if the builder switches to a different one, is that disclosed, or would that need to be verified with each batch ordered?
- Contact:
Thanks for your reply. The certificates are corresponding to its factory makers,which means it is the factory's responsibility to do the certificates.
- Contact:
Thanks for your supervisiation. I will try my best to improve this thread.amberwolf wrote: ↑Feb 19 2021 3:58amGood luck getting any actual info...especially that doesn't just "change". Check out the last sale thread:
- Contact:
the product specification will be uploaded (China Time) Next Monday Afternoon .
So are these 19S, to be charged at 68-69V ?
Sorry, but I did not ask about certificates, nor do I know why they matter.libattery21 wrote:Thanks for your reply. The certificates are corresponding to its factory makers,which means it is the factory's responsibility to do the certificates.
My question is, are you promising that the internal cells will be the same Dynavolt model in future as they are now?
Or if the cell used changes, how will you handle keeping buyers informed?
- Contact:
- Contact:
Yes, we promise the internal cells generally will always be the same Dynavolt model in future for the factory of this product(the brand of this product is Thinked). The cells generally will not easily changed.john61ct wrote: ↑Feb 20 2021 8:38amSorry, but I did not ask about certificates, nor do I know why they matter.libattery21 wrote:Thanks for your reply. The certificates are corresponding to its factory makers,which means it is the factory's responsibility to do the certificates.
Changing internal cells is a major material change. If we going to change internal cells,we will send notification letters to customers in advance.
- DogDipstick 10 kW
Bet it is 500-1000$ for this 1500Wh.
We pay on average much less here in the U.S.A.
83.1v of Ironhorse XC..
by Chevy
Broke 10 horsies
(..about 85% healed..)..
Waddyamean? You cant tell me how many amperes/Ft.^2 of the plate ?!?!?
1 (pound / second) Horse Power = 338.24 M^2 Kg^2 / Sec^4 (
prove me wrong
(gottenymoem4115thangs?Yall?)
Fabricator @ BSECo. Inc.
- Contact:
I need to inquiry internation freight company next Monday for approximate shipping fee to US. The exact shipping fee can be given when providing the quantity of this product.DogDipstick wrote: ↑Feb 20 2021 9:20amBet it is 500-1000$ for this 1500Wh.
16S LFP is comparable to LI 14S,libattery21 wrote:it is 16S 10P and to be charged at 60V.
around here usually called "52V", but actually 51.2V nominal.
Personally I would charge to 55.2V for better longevity
approaching 58.4V would be absolute maximum, IMO only for stress testing and capacity / SoH benchmarking.
I get 1280WhDogDipstick wrote: 1500Wh
That is, assuming cells measure at 2500mAh in real life.
- Contact:
