Blacksword
- Joined
- Jul 21, 2020
- Messages
- 32
Brand New QS205 5T Winding built for torque great for an off road eMoto build.
Currently on eBay and fb marketplace also. https://www.ebay.com/itm/254941838196
Local to the Worcester, MA area if your near or buy through auction.
Recently purchased so new out of box I am selling this due to relocation - I just dont have time to build my next eBike right now so recouping costs.
$475.00 OR BEST OFFER
ALSO SEE MY AUCTION FOR NUCULAR 12F CONTROLLER THAT WOULD GO WELL WITH THIS
Motor Main Specification:
1. Motor Type: BLDC Hub Motor with Permanent Magnet
2. Motor design: Double axle out
3. Spoke hole: 3.4mm x 36pcs
4. Matching Rim:16inch-26inch
5. Magnet Height: 50MM
6. Pole Pairs: 16 Pairs
32pcs Curved Magnets with "SH"(150Degree) Heat resistance Level
7. Rated Power: 3000W
8. Max. Power: 6000W
9. Rated Voltage: 72V (Can be working from 48V-120V)
10. Max Torque: 180N.M
11. Max Efficiency: 88%
12. Continious current:45A
13. Max current:80A (Peak 100A in short time)
14. Brake type: Disc brake
15. Rear Fork width for installation: 150mm
16. Winding Frame material: Aluminium
17. Cross Section of Phase wire: 10 mm2
18. Hall sensor phasing angle: 120 degree
19. Temperature Sensor: Optional
20. Max. Working Temperature: 70 degree, Peak 120 degree
21. Waterproof Grade: IP54
22. Color: Black
23. N.W./ G..W. : 14kgs / 15kgs
24. Package Size: 34*34*33CM
Winding / RPM List:
4T 820RPM 72V
5T 650RPM 72V
3T 1110RPM 72V
22. Color: Black
Winding / RPM List:
4T 820RPM 72V
5T 650RPM 72V
3T 1110RPM 72V
