bigmoose
This is a brand new, never used, with original sealed accessory bag, TE Connectivity Kilovac Czonka III Relay Part Number EV200AAANA. Coil nominal voltage is 12 to 24 Vdc with ATTACHED ECONOMIZER! This item is the real deal, USA stamped as Santa Barbara CA. This is not a China relay, or a China knock off.
Features from data sheet:
Continuous carry current 500 amps
2000 Amp interrupt at 320 Vdc
Built-in coil economizer – only 1.7W hold power @ 12VDC
Hermetically sealed – intrinsically safe, operates in explosive/harsh environments with no oxidation or contamination of coils or contacts, including long periods of nonoperation.
Normally Open Contacts
Coil wire length 15.3 inches
Item is new. Item always stored in air conditioned space. Never used or installed. Pristine. Item is currently $171.80 at digikey plus shipping.
Asking $64.99 each shipped in the USA. I have two of them.
If you can use them, let me know. I am sure we can work something out.
