12T 520 conversion sprocket for QS138 v3 motor
Jordan325ic
This allows you to run the stock 520 chain and rear sprocket on your electric motorcycle conversion, instead of having to convert the drivetrain to a 420/428 chain. I've got a few of these left from a batch I had made. I searched the internet forever before I had these produced, they just don't exist so I had to have them custom made. Price is $25 + $5 shipping to the continental USA.
These fit the 17mm / 14mm splined shaft on a QS138 V3 (the one with the integrated gearbox).
Depending on your chosen chain you may have to file the case slightly for clearance. See photo for clearance with an RK X-ring 520 chain. Non o-ring chains should be fine.
I would read the QS 138v3 thread for discussion on shaft/sprocket wear and shaft fitment issues with the QS138v3 (relating to other sprockets) before making a decision to purchase. https://endless-sphere.com/forums/viewtopic.php?f=10&t=110723&start=100
My project is not yet complete so I haven't been able to abuse-test the sprockets. Fit appears very good on my shaft, requiring a little bit of force to slide on by hand, like the other typical $10-$15 420 sprockets I have test-fit on this motor.
I’m almost out, but it looks like someone else makes this, finally.
https://mighte.me/product/13t-520pitch-qs-v3-and-70h-sprocket/
No affiliation, just FYI
