18 FET Low RDS MOSFET Overclocker Ready LYEN Controller $199
Lyen   10 kW
Re: 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller
Post by Lyen » May 18 2015 2:11pm
Clarified with Louis. Thanks!
Items For Sale
Please sign up here and donate your marrow to save life.
ohzee   1 MW
Post by ohzee » May 18 2015 2:16pm
Lyen you should change the url in your contact info from
Website:
http://www24.brinkster.com/lyen/beta
to
lyen.com
Just a suggestion. Hope you are doing well.
markz   100 GW
Post by markz » Aug 30 2015 1:40pm
72V battery optimized (for higher or lower voltage & current such as 36V-100V, you may need to change the resistor network to avoid damage to the voltage regulator)
65A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 62.6v
Can I go down to a 60V battery and change the LVC in the programming of the controller without any mods?
What is the voltage range of the controller in stock form?
alsmith   100 kW
Post by alsmith » Aug 30 2015 3:45pm
I've got both the 4110 (100V) ans 4115 (132V) Mk 2 18 FET controllers- both work at 36V and 72V for me with no changes for the different Voltages. It's worth letting Lyen know your intended Voltages if you're ordering in case there are changes he recommends.
Krakajax   1 µW
Post by Krakajax » Aug 30 2015 7:40pm
If the Lyen Controller is passed information from the Cycle Analyst v3 will the settings be used from the CA or the Lyen Controller? In other words, which profile settings take priority when both the CA and Lyen are used in a system?
markz   100 GW
Post by markz » Aug 30 2015 7:48pm
I already have the Lyen 18fet controller, I guess it wont harm anything if I go lower just wondering if performance is hindered is all in the controller itself.
However the statement says a lot and I understand 36V, and 100V, but if I am only going down from 72 to 60 shouldnt be any issues should there?
alsmith   100 kW
Post by alsmith » Aug 31 2015 6:39pm
I've had none. I just have my low voltage set for the 36V which I use most of the time, and monitor the capacity when using 72V (I have a CA).
lionelt   10 mW
Post by lionelt » Feb 05 2017 5:15am
HI
I ve a 18fet Lyen with 10AWG phase and Battery, very smooth and power with 18S lipo 40Ah 75.6v t 70 A (5000w) on mxus V4 4T (on vector frame 26")
my setting is 65A bat and 120A phases, and speed is enough 75km/h (MTB) but i hope more punch at starting .... (cannot do little wheeling)
do you think i can increase phase current to 150A or more and not exceed 70A on bat, neither overheat my motor
other questions
I do not have CA (and don't want, i've wattmeter) but I would like to be able to read the temperature of the sensor KTY from the mxus V3, do you know a small circuit that would make it do it (LCD/Led panel) ?
Nobody has ever developed a mobile application (android) for this controller with a bluetooth adapter?
Thx
Vector MXUS V3
18FET Lyen
18S 40AH LIPO
E-Chopper Nirve Switchblade
GM MP2 front wheel
GT 130 Wattmeter
48V 12Ah LI-ION case
All electronic & battery inside bag in leather brown assorted with Seal and handle
Range 35 kms - Speed 40km/h no assist direct from handle throtle
yannick85   10 µW
10 µW
Post by yannick85 » Sep 25 2017 11:53am
Hi,
I'm a newbie in ebikes but not in electronic.
i've just received a controller from fasterbikes.eu :
https://fasterbikes.eu/en/controller/27 ... oller.html
but i have no pinout or datasheet or serial number or manual.
I can unmount it but prefer not to if possible.
I don't know the exact model to verify data or program it (protocol ?).
The motor is a mxus 3k v3 with hall and speed sensors. Don't have the pinout...
I can make a pdf to help all of us in exchange because the doc is difficult to find...
Thank's for all.
rumme   100 kW
Post by rumme » Sep 25 2017 12:25pm
I just purchased this 18 FET lyen controller that can be ran sensorless. I'm gonna run it sensorless on a 72 volt rear hub motor at about 5kw nominal and 7 kw phase/burst . Is anyone else here running this controller sensorless with a high power hub motor, and if so, how does it perform ? Thanks.
yannick85   10 µW
10 µW
Post by yannick85 » Sep 25 2017 12:41pm
Hi @Rumme, do you have a photo for the pinout ?
rumme   100 kW
Post by rumme » Sep 25 2017 12:58pm
yannick85 wrote:Hi @Rumme, do you have a photo for the pinout ?
pinout ? no..im just hooking up 3 phase wires...if the rim turns in wrong direction, I just switch 2 of the phase wires . Supposed to be real simple.
yannick85   10 µW
10 µW
Post by yannick85 » Sep 25 2017 2:53pm
rumme wrote:Supposed to be real simple.
The problem is for connector that are not usual.
The controller is a china one i suppose.
So i'm not in the good topic (this topic is for Lyen ones).
Thanks for all.
rumme   100 kW
Post by rumme » Sep 27 2017 9:21am
On this 18 FET sensorless controller , is it proven that running a high powered brushless hub motor sensorless , is less efficient then running it with the 5 hall wires hooked up ?
I was told that there is a significant loss of efficiency , in sensorless mode , especially when running a motor above 2K and on 60-72 volt batteries.
Is this wrong ?
rumme   100 kW
Post by rumme » Oct 11 2017 12:35pm
I'm using the Lyen 18 FET sensorless controller with a Magura throttle. I have 1" of deadspot on my magura throttle when I twist it from a dead stop . I don't get any power to the controller/ motor until I twist the throttle 1 inch . What parameter must I change in the controller, so my throttle will engage power immediately when it is twisted ?
markz   100 GW
Post by markz » Oct 14 2017 5:18am
I dont know, but my first instinct was, if I remember correctly, adding a pull down resistor of 1.5k or something.
I could be totally wrong. This could be totally out in left field.
I swear I read something like that a couple days ago from a reputable ES member.
Its not so much the controller, but the throttle specifically.
amberwolf   100 GW
Post by amberwolf » Oct 15 2017 1:34am
He's probably already got an answer in one of the three or four threads he has running about this problem. :roll:
Gtech   1 µW
Re: 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller $199
Post by Gtech » Oct 12 2018 12:32pm
Hi, I'm buying this controller second hand but does somebody maybe has some basic info how to wire this controller? Like which wires are mandatory to connect?
Also, some pictures and download files in the first reply's are not available anymore. Is it possible that someone can share a mirror for downloading?
Promise that If all parts are in I will start an project topic :D
Thanks
Gtech   1 µW
Post by Gtech » Oct 13 2018 12:00pm
Joely   100 µW
100 µW
Post by Joely » Nov 05 2018 4:00pm
Hi, I have a 3kw brushless motor and am currently running it with the c and d 18 mosfet controller and ktlcd3 dash. I am after something similar or slightly bigger if necessary to gain an more instant punchy throttle response. I am not keen on the delay i have from the twist grip when off road. I have used and still have a risunmotor 100 amp controller and 750c colour dash which does offer great performance but is very big. Is there something i could purchase around 50-60 amp that has 3-5 levels of assist that may hook up with my existing lcd's or may come with one? Thanks for any help.
amberwolf   100 GW
Post by amberwolf » Nov 05 2018 10:45pm
If you'd like to try it, there is an alternate firmware for KT controllers. Look up Casainho & Stancecoke's thread(s) for the controller and display firmwares.
