12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129
Lyen   10 kW
Re: 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition
Post by Lyen » Jan 14 2011 5:57pm
999zip999 wrote:Lyen, Just sent $129.00 the Paypal don't let me add $10.00 for upgrade. But please get started and tell how to send the $ 10.00. Thanks. I'm running a bmc 600 h.s. will it plug right in with my hall sensers plug, and have andersons on the phase wires. If not please send a diagram. I must be careful for now as this ping is running on a 40amp crstalyte con. I think this was made for a 5303 ? If the 6 pin on that controller is giving out mixed voltage 48.9v 50.5v and batt. at 53.2v how deep can it be. I need to wate for new Lyen controller before operation on old con.. Back to 32mph. It's hard to slow down. THANKS.
Hi 999zip999,
I have just sent you the controller via USPS Priority Mail. You should be able to received it by tomorrow or Monday. :)
I also have sent you the pinout information on the connectors you need via PM.
Please let me know you need help or have any questions. I will be more than happy to answer. :)
Warm Regards,
Lyen
Items For Sale
Please sign up here and donate your marrow to save life.
999zip999   100 GW
Post by 999zip999 » Jan 20 2011 1:25am
Hi Lyen, Recieved the controller tues.thanks that was fast.
aaronski   1 kW
Post by aaronski » Jan 20 2011 6:17pm
Great controller, great motor, but um, word of advice, don't set the power to the highest setting then go off roading. Edward(Lyen) is currently re-wiring the phase and power lines on my 9c, I melted the Anderson connectors and blew up a couple HALs in the process! But lucky for me Edward lives right down the street. :D
Wow I've been here 7 years! had a kid and took a break. Back on a Vector Ebike just for fun.
Broken bike and electric bits everywhere. Sometimes it's a bike and I ride it.
Broken too much crap. pulled 3kw from a 350 watt ebike kit motor, pulled 100c out of HK lipo. much melted wire and plastic. Amazed at the progress this group has made in ebiking.
SoMoney   10 mW
Post by SoMoney » Jan 20 2011 11:46pm
My 12x4110 (EC-124110LD) LYEN EDITION Arrived!
Regarding Programming. I fired up Keywin E-bike Lab and sorta understand what I'm doing :oops: .... Can some one point me to the thread where I can get an asv file or screen shots of people tweaking running the 12x4110 controller with a 9C motor? Still on the test bench but the 9C is running noisier/rougher then with the stock E-bikekit 48V 500W controller. Must be some setting or bad wiring on my part I need to track down.
EDIT/UPDATE: Got it.. To work on my E-bikekit 9C rear hub I needed too swap Blue/Green (Y/B/G) on the 12 x 4110 Controllers Hall Connector as well as on the Y/B/G Phase lines and its quiet.. Just spins MUCH faster :twisted:
rumme   100 kW
Post by rumme » Jan 28 2011 7:52pm
edit
AussieJester   100 GW
Post by AussieJester » Jan 28 2011 7:55pm
rumme wrote:Can someone please help me ?
I ordered the 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129:
its for a 1000 watt/48 volt ebike kit I got from hong kong...I was told the hub motor is a Bafang...heres the link to the kit :
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
and heres the stock controller that came with the kit..but blew up :
http://www.conhismotor.com/ProductShow.asp?id=111
LYENS controller instructions does not show the proper wiring of phase/ motor wires to get my kit to work properly...
does anyone know the proper wiring of blue/green / yellow wires to get it to work for my kit ?
I have tryed all the combinations I can think of , and all I get is the hub motor running forward but with a loud growling noise...or the motor runs backwards but it doesnt make the growling noise.
When in the combination with the motor running backwards, swap any pair of phase wires it should then run forward, if the growling starts you need to swap some hall wires, iIRC there's something like 32 or 36 combination's?
Sounds like your close anywayz you have movement LoL..
KiM
rumme   100 kW
Post by rumme » Jan 28 2011 8:43pm
when it was running in reverse, smoothly...I tryed to change the motor wires ..and all that did was make the motor run forward but with the growling noises again..
AussieJester   100 GW
Post by AussieJester » Jan 28 2011 8:48pm
rumme wrote:...I think its poor practice to just tell your customers.." spend a few hours and try 36 different combinations" ...
Where exactly is this written by Lyen? Never seen it myself. I realise your likely frustrated but theres no
reason to start that business, Edward Lyen is a long time seller
on this forum and highly respected.
KiM
rumme   100 kW
Post by rumme » Jan 28 2011 8:52pm
edit
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jan 28 2011 9:02pm
I have spoken to him today...and he basically told me that I need to try out all possible combinations to get it to work properly...
I never heard of selling a product, and not being able to tell your customers how to hook it up properly so it works. I spent $129 on a controller from someone in the U.S, fully expecting to get proper instructions on how to wire up the controller.
I would not sell someone a car and tell them, you need to try 36 different wiring combinations , to get it to work proeprly...r
It is almost impossible to be sure that any combination will work since the motors do vary for time to time and if you don't do the wire swap you will never know.
One motor was yellow to blue and green to green on the phase and the halls, another was yellow to green and blue to blue.
Take your time. Turn the bike upside down and it will be easier.
Dan
rumme   100 kW
Post by rumme » Jan 28 2011 10:00pm
someone helped me on another thread...blue/green on both phase and motor needed to be swapped..
thanks for your help everyone.
friedwires   100 W
Post by friedwires » Feb 26 2011 1:11pm
thanks for the fast ship Edward!
outbackwb   100 µW
100 µW
Post by outbackwb » Feb 26 2011 2:07pm
Edward, Please send me a PayPal link for purchasing a 48v version of this awesome controller. I need a 3sp switch as well. :D
edcastrovalley   1 kW
Post by edcastrovalley » Feb 28 2011 1:01am
Thanks for the fast ship too. The controller works great! :D
Twin Controllers!
Challenge: Guess the real bike color.
shorza   1 kW
Post by shorza » Mar 03 2011 8:01am
Lyen, I'm thinking of putting a pre-charge resistor switch on my setup to prevent the arcing that happens when connecting my lipos to the controller.
Would connecting the red controller wire that turns the controller on (not sure what it's called) to the battery before the main positive wire pre-charge the caps in the controller?
itchynackers   100 kW
Post by itchynackers » Mar 03 2011 9:23am
I don't believe it does (although I've never tried it). I have my resistor on the positive battery wire. Plug in resistor, wait 5 seconds, plug in main wire, no spark, works good.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
shorza   1 kW
Post by shorza » Mar 03 2011 7:59pm
Cheers, I may just have to do that.
999zip999   100 GW
Post by 999zip999 » Mar 04 2011 4:22pm
Hi Lyen, I was told the 124110ld controller might be a little hard at the starts for my BMC 600hs is this true ? Or is this a good fit ? Also I didn't get the pins for the white connecters or the phase wires. Could you send them or my I buy them ? And what is the best motor for this controller if not the BMC ? Still sitting on my desk. Thanks.
Lyen   10 kW
Post by Lyen » Mar 05 2011 2:04am
Hi Shortza,
PM sent with suggestions. :)
Regards,
Lyen
shorza wrote:Lyen, I'm thinking of putting a pre-charge resistor switch on my setup to prevent the arcing that happens when connecting my lipos to the controller.
Items For Sale
marcexec   1 kW
Post by marcexec » Mar 09 2011 4:54am
Controller arrived safely on Monday, brackets were a little bent, though.
It is a lot smaller than expected.
What are the max values someone has put it through, anyway?
Thanks, Edward.
I think, I'll hook it up to the PC this weekend.
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
aaronski   1 kW
Post by aaronski » Mar 09 2011 1:54pm
marcexec wrote: What are the max values someone has put it through, anyway?
I've done 3kw peak, 2kw sustained on the 12 fet.@ 72v
It's a limitation of my battery, the controller is set to 300 amps phase, 100 amps battery.
Who's got me beat?(there are a lot of you I"m sure!) :mrgreen:
itchynackers   100 kW
Post by itchynackers » Mar 09 2011 3:22pm
I've done 3500 peak and 2300 continuous. Never really thought much about it. I assumed I'm a "middle-of-the road" guy when it comes to ebikes. My controller doesn't get beyond lukewarm. It is in the open air though. And not many stee[ hills around here.
tostino   10 kW
Post by tostino » Mar 10 2011 11:44am
My non-Lyen 12 fet that I built sees 170 phase 100 battery at 54v. It gets a little warm in open air, but too bad at all.
TMaster   1 kW
Post by TMaster » Mar 10 2011 12:13pm
Peaks of 7500W, spikes of 4000-5000W and some steady 2000-2500W for 30 sec. Heavily modded, air cooled and fan cooled internally, gets pretty warm. I dont burn my fingers touching it, but its pretty warm on the outside in the summer time. Prolly 45c, 50c ? I should probe it next time to see for sure.
Specialized HR - 75 lb's
A123 26650M1 23S4P(75.9V Nominal) 7500W Peak
Infineon Lyen 12 Fet/45amp controller heavily modded pushing 110 Amps peak
Yescom Motor with upgraged phase wires (Golden Motor/9C replica)
Hyena   100 GW
Post by Hyena » Mar 10 2011 7:29pm
aaronski wrote:the controller is set to 300 amps phase, 100 amps battery.
They'll take short trips to 100 amps battery current but 300 phase amps is really pushing your luck with a 12 fet.
I have a modded one running 80a peak that sees 5kw daily and spends most of the time around 20a so around 2000w like tmaster. It's also drawing around 30 amps alot with 30-60 second runs at ~40. Even an air cooled 9C gets very hot with this treatment
www.HyenaElectricBikes.com
