12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129
chroot   100 kW
Re: 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition
Post by chroot » May 14 2010 6:55pm
Lyen's profile says Location: San Francisco, CA, USA, of course, He is in states :lol:
auraslip wrote:I am willing to pay for express shipping. Are you in the states?
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
Lyen   10 kW
Post by Lyen » May 14 2010 7:20pm
auraslip wrote:What is shipping time like? My controller burned up, and I am left stranded.
Hi Auraslip!
I am sorry to hear that your controller is burned up. I do controller repairs. To be honest, I think it would be best if you can send me your controller for inspection so you can save yourself some money. I can also offer you a loaner controller with a security deposit while I am fixing yours.
In case you decided that it is about time to upgrade with a better controller, I am more than happy to send you one from San Francisco, California by USPS Priority Mail for a small fee. Just let me know. :)
Best Regards,
Edward Lyen
Items For Sale
Please sign up here and donate your marrow to save life.
oldhaq   100 W
Post by oldhaq » May 14 2010 7:27pm
This is the third controller I've bought from Edward, he has proven to be a helpful, reliable and honest person, so this one I sent the paypal payment as a "Gift", to help lower the fee that they charge our man Mr Lyen.
My bikes:
WCC Chopper longtail - http://endless-sphere.com/forums/viewto ... 60#p170594
Choppermeister and JJWCC - http://endless-sphere.com/forums/viewto ... 50#p246270
Huffy MTB http://endless-sphere.com/forums/viewto ... 50#p252774
BMC Super Trail http://endless-sphere.com/forums/viewto ... 61#p619089
www.youtube.com/user/OLDHAQ
I thought of that while riding my bike.
Albert Einstein
on the Theory of Relativity.
MrKang   100 W
Post by MrKang » May 18 2010 3:06am
Yesterday i hooked up the new LYEN controller and came up with some issues.
first the hubmotor spinned well, silent and correct when my e-scooter was placed on his stand.
When i wanted to drive with it i noticed that it had no torque.
i think i have to change my green and blue phase wires also.
Because i just copy the wires from my old modified controller to the new LYEN didn't matched i think.
And the brake switch doesn't work. first i noticed that the LYEN controller needed a ground sig. for breaking.
so i resoldered it to the + BRAKE and tried it out. Because when i brake i will put out a 15V signal to the controller.
After resoldering this and put it for the test it still won't shut the motor down when breaking.
Does the LYEN controller need a higher positive voltage ? like 72V or higher ?
if so i have to put a relay which will give the voltage from the controller supply to the brake+
tonight i'm gonna switch the green and blue phase wires as the hall wires. hopefully this will work.
MrKang E-Scooter : 24V 750W Bosch Motor modified with YK-43 48V 1kW on 12S6P Lipo - top speed 44kmph
Xinling XTD800A : LYEN 4110 72V (modified for safe 100.8V with extra cooling) - 24S4P/100.8V 25Ah Turnigy + CA with Datalogger + SOUNDSYSTEM + USB power outlet + 78km top speed(120%)
MrKang Retro II : in progress.. ** 12FET MKII LYEN + 28S 20AH LifePO4 cells **
Project link [/color]: http://endless-sphere.com/forums/viewto ... 10&t=13442
amberwolf   100 GW
Post by amberwolf » May 18 2010 4:04am
So far the few controllers I've investigated only use about 5V for the e-brake lines. Typically they supply a +5V output, a ground, and a signal input wire. Not sure if it is more common to ground the signal line to start braking, or if it is more common to input 5V to start braking.
I dont' know what would happen if you input 15V to it, but I think pack voltage would probably damage or destroy the MCU chip inside. ;)
If you are not already doing so, I'd suggest you try using only the supply output from the (probably 3-wire) brake connector to generate the braking signal. See if it works that way.
Lyen   10 kW
Post by Lyen » May 18 2010 4:28am
Dear MrKang,
I apologize for not making it clear the brake connector with the yellow & black wire is meant for signal only. The yellow and black wire will triggered & stop the motor if connect together. There is a potential damage if you feed it with voltage in stead of signal. Please PM me if you have any other questions.
Sincerely,
Edward Lyen
MrKang wrote:Yesterday i hooked up the new LYEN controller and came up with some issues.
Items For Sale
MrKang   100 W
Post by MrKang » May 18 2010 4:45am
On the PCB you can see two connections for the brake signal. when i get it it was soldered to the EB- and GND
which indicates when you ground it it will stop. next to the EB- You will see the EB+ padding. This will change it by listening to a positive signal/voltage
just like my other controller this worked fine. Brake signals -or + are both secured by a resistor/diode network before they go to the MCU.
so i don't think i have blown up the circuit yet.
The brake wire in original state is working wel. ..if i hit throttle and connect the gnd with the yellow it shuts down.
But in my situation i only can provide a positive signal because it's linked with my braking lights on the back of the scooter.
I will fix this with a relay which i will trigger when breaking which will shortcut the black and yellow brake line to the controller.
i will fix this tonight and give you an update. also with the phase/hall wire switch
Lyen   10 kW
Post by Lyen » May 18 2010 4:57am
MrKang wrote:On the PCB you can see two connections for the brake signal. when i get it it was soldered to the EB- and GND
Hello again MrKang!
I have a similar setup up like yours with my scooter style electric bike. What I did was I wire the braking voltage to a relay to trigger the braking signal instead of the direct feed.
Thanks again for your reply to share the information with us! By the way, I have noticed on your signature stating you have upgraded the controller to 150v? May I ask how did you managed to do that? Just for my curiosity. :)
Items For Sale
MrKang   100 W
Post by MrKang » May 18 2010 5:16am
Hi LYEN
That is still in progres. Like your controller i use the 4115 and use 200V caps. It is stated 150V but that's the maximum working voltage.
it's more like supersafe for 24S lipo system. Then you will not have any concern blowing out your controller while driving full speed at 40 miles away from home.. :? it's a long walk...
MrKang   100 W
Post by MrKang » May 18 2010 1:32pm
i tried switching the wires but didn't helped..
problem: i got 1 original controller which is pretty the sam as LYEN one.
phases are A B and C as the hall sensor wiring.
So i thought this is the same wire setup as my old one.
After placing LYEN controller the hub motor spins as smoothly as my old controller. (THIS IS WHEN MY SCOOTER WHEEL IS HANGING ABOVE THE GROUND SO NO RESISTANCE)
I can play with the throttle like young kids you know....vroom..vroom..! it spins super!
When putting the scooter on the ground and hitting the throttle it don't have any torque...it just moves a bit forward and that's it...
Can it be the programming ? i just use the standard parameters LYEN programmed it with.
Somebody also has the same problem with not having any torque...what was his sollution ?
PLEASE HELP!
MrKang   100 W
Post by MrKang » May 18 2010 1:46pm
SOLVED !!! :D :D :D
I focused the settings from a picture from Edward. But it was set for 18FET model on the picture..
I switched it to 12 FET model and BAM!!! it worked baby !!
tommorow i'm gonna place the relay for the brake signal .
MrKang   100 W
Post by MrKang » May 19 2010 8:55am
Question: Why has this controller no autocruise ? You can see the parameter on the software (1 to 15s)
or do i have to connect it on the PCB somewhere ?
Lyen   10 kW
Post by Lyen » May 19 2010 9:57am
This is in response to MrKang's cruise control question. I have edited the response to correct what I have previously mentioned.
The actual way that it is supposed to work is like this:
1. Press a momentary switch button that connects between the CR pad and ground
2. Hold the throttle steady let say for 5 seconds to activate the cruise control
3. Press the momentary switch button or ebrake to deactivate cruise control
Thank you very much Number1cruncher's help on the post below! The information is very valuable! I appreciate it. :)
Items For Sale
number1cruncher   1 kW
Post by number1cruncher » May 19 2010 10:53am
On the 846 boards, there is a CR pad that when grounded, allows the rider to set the cruise control. I set my cruise time to 5 seconds in PD, so after holding the throttle steady for 5 seconds, it cruises until I hit the throttle or brake again. I'm not sure if the 116 has this pad, but it wouldn't hurt to look...Edit: Attached is a pic from LYEN that shows the CR pad in the upper right side, circled in red.
Go to http://www.ebike.ca and buy stuff to support the rEVolution!
Electra Townie 700c Euro 8i - 20s2p Zippy LiPo - Rear 9c clone
Performance x201 - 18s2p - Rear 9c 8x8
All things lead to the path of least resistance.
"Political correctness is tyranny with manners." ~Charleton Heston
MrKang   100 W
Post by MrKang » May 19 2010 2:33pm
i'm gonna try it out and let you know if it's possible.
AND IT WORKS !!...So just shortcut the CR with GND and you have cruise control which you can adjust with the software (1s ..15s delay)
Thanks for the picture! ( i was to lazy to get the controller out again (for the 5th time)
CRUISE CONTROL IS POSSIBLE AT LYEN CONTROLLER !! :P :P :P
Hyena   100 GW
Post by Hyena » May 19 2010 8:13pm
So you can permanantly ground CR and cruise will automatically kick in after the defined time in PD ? Nice.
I thought it was possible and emailed Lyen but I got the impression I needed an external cruise module.
www.HyenaElectricBikes.com
Post by number1cruncher » May 20 2010 8:53am
I ran wires from the CR pad and the GND pad to the outside of the controller. Right now they are just terminated with andersons, but I will install a switch at some point. That way I can physically turn off the cruise when I don't want it. It can get annoying in heavy traffic, just like in a car.
auraslip   1.21 GW
1.21 GW
Post by auraslip » May 21 2010 3:37pm
I just got my very well packaged controller from Lyen today.
Does anyone have phase wiring instructions for a nine continents ebikekit front hub?
THANKS TO EVERYONE HERE WHO TAUGHT ME ABOUT EBIKES. I'M IN YOUR DEBT.
I sell Ebike Brake levers and throttles with custom connectors crimped on! $10 shipped!
ES facebook group
r/ebikes ebikes on reddit
Lyen   10 kW
Post by Lyen » May 21 2010 4:05pm
auraslip wrote:I just got my very well packaged controller from Lyen today.
Hello Auraslip!
I'm glad you have received your controller within the week. :)
Please try the color lining for your 9C motor below:
Controller: Motor:
Hall:
Y Y
G B
B G
Phase:
Y Y
G B
B G
Best Regards,
Edward Lyen
Items For Sale
auraslip   1.21 GW
1.21 GW
Post by auraslip » May 21 2010 4:27pm
I just tried that color combo and nothing. :(
ES facebook group
Lyen   10 kW
Post by Lyen » May 21 2010 4:38pm
auraslip wrote:I just tried that color combo and nothing. :(
You need to connect the small thin red wire to the battery positive to start your "engine". :)
Items For Sale
auraslip   1.21 GW
1.21 GW
Post by auraslip » May 21 2010 4:43pm
It is....
I checked the continuity of all the wires to the motor.
I checked the thottle. It varies around ~5 volts like it should.
I checked the hall sensors. They varies around ~5 volts while I turn the wheel.
Brakes disconnected.
ES facebook group
auraslip   1.21 GW
1.21 GW
Post by auraslip » May 21 2010 5:07pm
frock it. I'm going camping. I'll deal with it when I get back on sunday. I was looking forward to taking my bike with me ;(
I opened up the controller to have a looksie btw....
nice FAT solder traces :D
ES facebook group
Lyen   10 kW
Post by Lyen » May 21 2010 5:49pm
auraslip wrote:I want to hug it. I'm going camping. I'll deal with it when I get back on sunday. I was looking forward to taking my bike with me ;(
Hi Auraslip! I suspected you may have created an issue here since you have mentioned you switched the red & black wire on your throttle. I have sent you a private message and lets troubleshoot and narrow down your issue there. Thanks!
Items For Sale
turbobass   1 mW
Post by turbobass » Aug 03 2010 12:14pm
wrong thread ... sorry
Conhish Motor 1000w front , 9C 500w rear , Lyen 12fet 4110 prog. controller for rear , Headway 40160S on it's way ,
