12 FET 84-132V High Voltage Racing Controller - LYEN $199
Lyen   10 kW
Re: 12 FET 84-132V High Voltage Racing Controller - LYEN $19
Post by Lyen » May 27 2010 11:41am
tostino wrote:Lyen, what are the chances of parting with 24 of em? Or do you think the Mike guy would be willing to sell me them in such a low quantity? I'd love to get the two controllers for my dual motor bike built up.
Hi Tostino!
I apologize for not being helpful. I have pretty much soldered all the MOSFETs onto the circuit boards prior I saw your post here. Let me see what I can do with the next badge of orders and get back to you.
Regards,
Lyen
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen   10 kW
Post by Lyen » May 27 2010 11:53am
Hi Knuckles!
I valued your informative suggestions. You are truly the godfather of all Infineon controllers. I really appreciate it. :)
Best Regards,
Edward Lyen
Knuckles wrote:Also,
The VR circuit components are susceptible to burn out from initial current surge.
These components only have a max rating of 100V to 120V. The resistors are maybe 1/8 watt.
I use a FJP9100 transistor circuit to keep the voltage to the VR circuit under 100V.
Side benefit of this mod is it makes the unit "any voltage" 39V to 150V.
I also add a temp switch to the fet heat sink.
Very simple to solve all these issues with a mod "module".
PM me and I'll share all my mods with you.
This way your controllers will be "bullet proof"
-Knuckles.
PS Nice fets!
PSS So methods has cornered the irfb4115 market too! :shock:
PSSS Have you tried tweaking the block times yet? Really cool post about that ...
http://endless-sphere.com/forums/viewto ... =0#p272438
Items For Sale
tostino   10 kW
Post by tostino » May 27 2010 12:07pm
Hi Tostino!
Regards,
Lyen
You have no idea how much I would appreciate that! Thank you very much.
Knuckles   10 kW
Post by Knuckles » May 27 2010 5:16pm
Here you go ...
High res pic here
peace 8)
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Arlo1   100 GW
Post by Arlo1 » May 29 2010 5:04pm
subscribed
My Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
Lyen   10 kW
Confirmed > no overheating issue on SMD resistors
Post by Lyen » Jun 04 2010 4:16am
Dear all respective members and buyers,
Good news!
This is the clarification and response to the potential overheating issue on the SMD thin film resistors on R10, R11, and R12. I have escalated it all the way to the supplier as well as actual designers for the print circuit board. We both have executed a series of testing including highest voltage, highest temperature, highest motor rotation, as well as highest current drawn. The resistors on R10, R11, R12 pads actually do not take direct voltage from the battery. Therefore, the current and power draw is more than sufficient with the SMD resistors.
Here is the hard evidence with the tested results executed in San Francisco, California, USA:
The voltmeter and the EC-124115-LYEN Edition controller being used for testing at 155.9V (Do not try this at home! It is very dangerous!) :shock:
Temperature meter with the probe sensor being used (The probe is quite sensitive) :)
R10 resistor temperature result shown in Celsius after one full hour:
R11 resistor temperature result shown in Celsius at the second full hour:
R12 resistor temperature result shown in Celsius at the third full hour:
As you can see, the overheating issue was incorrectly informed previously. We can conclude the case is now dismissed. :D
Your Truly,
Edward Lyen
To see my test equipment, click here:
http://img227.imageshack.us/img227/2429 ... ipment.jpg
Items For Sale
Knuckles   10 kW
Post by Knuckles » Jun 04 2010 6:53pm
#1) Buy from Lyen. I like Lyen and I think he builds EXCELLENT controllers. A+ Lyen.
#2) This statement is incorrect ...
Lyen wrote:The resistors on R10, R11, R12 pads actually do not take direct voltage from the battery.
This is false. R10, R11, R12 resistors absolutely DO take direct voltage from the battery.
#3) I just measured the current thru the R10-R11-R12 circuit on an isolated "naked" XieChang pcb.
At 152 volts the current thru this circuit is 8.6 ma just as I had predicted.
#4) Fortunately the 12-fet controller tested by Lyen has a large capacitor directly above R10 and R11.
Clearly this large cap is acting like a heat sink and helps "save" these components from overheating.
Please realize that the 6-fet, 18-fet, 24-fet and 36-fet MAY NOT have a large cap directly above the R10 and R11 'lil' resistors.
Just a FYI to all the folks whom like math.
Buy Lyen ... Stay lean!
cheers,
-Knuckles
8)
Lyen   10 kW
Post by Lyen » Jun 05 2010 4:32am
Hi Knuckle!
I thanks again for your commentary and compliment. The direct battery connection was actually interpreted incorrectly as the original word by word translation meant connect both positive & negative to each individual component such as the resistor from end to end. :)
Anyway, I am seriously listening and made the change to make sure the controller is 100% reliable and last for years although it is not really necessary. The higher wattage resistors are now used. Below is the improvement:
Best Regards,
Edward Lyen
Items For Sale
Tom_D   100 mW
Post by Tom_D » Jun 10 2010 12:28pm
to Edward,
Pm sent
-- Tom
Bike: wally world 26" Roadmaster mtn
Trailer: Bob
Motor: front Clyte 5305
Controller: LYEN 124115 HV
Charger: Soneil 4808 SRF (onboard), parallel charging (4) 48V blocks, NO BMS
Batt: 84s2p Toyota Prius Gen III
Dashboard: Cycle Analyst
Lyen   10 kW
Post by Lyen » Jun 10 2010 12:52pm
Tom_D wrote:to Edward,
Pm sent
-- Tom
Hi Tom!
PM replied. I appreciate your business and your hint to deliver to Hawaii. :)
Regards,
Edward Lyen
Items For Sale
steveo   1 MW
Post by steveo » Jun 13 2010 11:55pm
Hey Everyone,
For all of you that know me i have run a 24 mosfet irfb 4110 controller with 145v of a123 for months .. even before lynn has released his controllers in for sale thread
Lynn
You must modify r115 as per knuckles .. IT WILL FAIL; I gaurentee it, I've had failure 2 times since march 2010; that ive been running this controller
R10, r11, r12... WILL BURN OUT
the current is to high ..
I could even take a photo of the resistors on my board... the resistors are turning brown due to the heat over last 3 mnths
I don't want to hurt your thread... but buyers must beware that if they but this board .. it will faill .. may not be for a few months ... but it will happen..
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
Lyen   10 kW
Post by Lyen » Jun 14 2010 1:25am
Hello Steveo!
Thanks for letting me know another potential failure. Yes, please take a picture of your "browned" resistors on your circuit board. May I also ask what was circuit board revision that failed on you? I appreciate it!
Regards,
Lyen
steveo wrote:Hey Everyone,
Lynn
-steveo
Items For Sale
The Mighty Volt   10 MW
Post by The Mighty Volt » Jun 15 2010 11:05am
Hi Lyen, in light of SteveO's post, do you mind if I wait until the issue is resolved before I pay you the remainder of the money I owe you for the controller?
Thanks.
PS I am sure SteveO is a legit dude who just wants the best for forumites.... 8)
Lyen   10 kW
Post by Lyen » Jun 15 2010 11:56am
Hi Mighty!
Yes, I would not sell any controllers with potential issues. The potential issue that Steveo suspected is being escalated and reviewed by the engineers from the manufacturer and me. I will get back to you once it is clarified. :)
Regards,
Edward Lyen
The Mighty Volt wrote:Hi Lyen, in light of SteveO's post, do you mind if I wait until the issue is resolved before I pay you the remainder of the money I owe you for the controller?
Thanks.
Items For Sale
Tom_D   100 mW
Post by Tom_D » Jun 15 2010 1:36pm
Hi, Lyen,
I have a few questions on the controller I just received from you:
:arrow: You posted the mod June 5, and sent mine out June 9. Does it have the resistor mods to it as pictured above? I just want to make sure.
:arrow: . Your screenshot on page 1 shows parameters for an 18fet (EB218) board. All the examples I find from Methods are for EB218 boards as well. Can you provide the .asv file for this EB212 (12 fet) board showing the default values for all the parameters ?
:arrow: Can you just change and flash one parameter value, or do you have to populate them all ? I don't want to upset the rest of defaults values.
Thanks in advance for your help. :mrgreen:
-- Tom
Trailer: Bob
Lyen   10 kW
Post by Lyen » Jun 15 2010 2:48pm
Hi Tom!
I have replied back to you via PM. Thanks! :)
Regards,
Lyen
Items For Sale
Tom_D   100 mW
Post by Tom_D » Jun 15 2010 4:21pm
Lyen, PM received. You have answered all my questions with real information. :mrgreen: You are good guy.
Thanks.
--Tom
Trailer: Bob
Post by The Mighty Volt » Jun 15 2010 5:50pm
Lyen wrote:Hi Mighty!
Regards,
Edward Lyen
Thanks.
Thanks Lyen. As soon as everything is clear, just send me a PM and I will pay you the remaining 75% plus the postage. Thanks and good luck with everything!
Lyen   10 kW
Post by Lyen » Jun 17 2010 4:48am
Here is the remedy. I have engaged a bunch of people from the manufacturer for the potential issues that was mentioned by the young fellow Steveo again. I was told by the engineer and designer of the circuit board being used was good as is. But to relief the worrying of people, here are more changes as shown on the pictures below. The R115 resistor will not turn brown. The possible reason was because Steveo operated his controller at 145-150v which was not safe to begin with. The engineer told me the R115 resistor can sustain 15 degree Celsius above normal operation temperature. The engineer has also said switching power circuitry for voltage regulation is embedded onto the circuit board, so the additional VR or voltage regulation circuitry is unnecessary. Resolved. :)
Your Truly,
Edward Lyen
Items For Sale
Post by The Mighty Volt » Jun 17 2010 7:18am
Hi Lyen, in a PM you mentioned 18 Fet and 12 Fet.
I have a basic notion, more fet's = better.
Is this correct.
How much is the 18 Fet controller?
Thanks.
Lyen   10 kW
Post by Lyen » Jun 17 2010 7:38am
The Mighty Volt wrote:Hi Lyen, in a PM you mentioned 18 Fet and 12 Fet.
Is this correct.
Thanks.
Hi Mighty!
Here is the link for the 18 FET High Voltage controller I am also selling:
http://endless-sphere.com/forums/viewto ... 31&t=18605
In theory, more MOSFETs can generate more power with less heat. But a properly optimized configuration between battery and motor and price are also important. In addition, enclosure size, range, weight, and battery discharge ability should be consider. :)
Regards,
Edward Lyen
Items For Sale
AmpEater   10 W
Post by AmpEater » Jun 18 2010 10:26pm
Is that last one still for sale? I'll take it
Lyen   10 kW
Post by Lyen » Jun 18 2010 10:35pm
AmpEater wrote:Is that last one still for sale? I'll take it
Hi AmpEater!
Thanks for your interest in the controller. Yes, it is still available for purchase. :)
Regards,
Edward Lyen
Items For Sale
steveo   1 MW
Post by steveo » Jun 18 2010 11:36pm
how about r12 heat issue?
Repair Thread
Lyen   10 kW
Post by Lyen » Jun 21 2010 10:53am
steveo wrote:how about r12 heat issue?
The issue was escalated and resolved. I appreciate your respect and concerns. :)
Regards,
Edward Lyen
Items For Sale
