OFFICIAL Electric Motoped
kfong   1 MW
Re: OFFICIAL Electric Motoped
Post by kfong » Jan 21 2014 11:12pm
I just placed an order for the frame kit and shocks. On the fence if this will be an electric conversion. The gas version seems quieter than most and I like the power and range. The 125cc motors are cheap as well, inexpensive dirt bike setup.
I will be following what you come up with Matt. This setup, screams for power.
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Feb 09 2014 8:12pm
post kickstarter dealer & retail pricing announced.. :
All Prices U.S. Dollars!
Fully Assembled with 49cc Motor:
· 1-4: $2,149 per bike
· 5-9: $1,500 per bike
· 10-24: $1,250 per bike
· 25+: $1,150 per bike
Retail Prices:
Non-Assembled Rolling Chassis & Frame Kit
Dealer Pricing - All Prices U.S. Dollars!
· 1-4: $1,999 per bike
· 5-9: $1,250 per bike
· 10-24: $1,100 per bike
· 25+: $999 per bike
· Complete Frame Kits: $599
Retail Prices:
· Full Bike MSRP: $1999
· Frame Kit MSRP: $599
· Full Bike MSRP: $2,149
https://www.facebook.com/photo.php?fbid ... 959&type=1
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Post by efMX Trials Electric Freeride » Mar 18 2014 2:05pm
Great news! :D
Electric Motopeds are coming! :mrgreen:
for those not on phasebook you can view updates, videos etc on the Motopeds Blog
Cromotor meets Motoped! 8)
http://endless-sphere.com/forums/viewto ... 88#p867635
GCinDC   10 GW
Post by GCinDC » Mar 19 2014 7:38am
efMX Trials Electric Freeride wrote:Electric Motopeds are coming!
i think it's safe to say there's a lot of interest here in the electric versions. hub motor's cool, but that drive train is itching for a middrive motor. anyone going that route yet? photos?
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
skyungjae   10 kW
Post by skyungjae » Mar 19 2014 10:07am
+1
Cyclone has a 6kW mid-drive motor. It shouldn't be too difficult to make a custom bracket to mount it in there as well as some sort of battery box. If I had some sort of infinite money cheat in real life I'd try it. :lol:
¯\_(ツ)_/¯
2005 Jamis Dakar build thread: http://endless-sphere.com/forums/viewto ... 27#p972546
2005 Kona Stink-E build thread: http://endless-sphere.com/forums/viewto ... 64#p690597
Post by efMX Trials Electric Freeride » Mar 20 2014 11:36am
Motopeds want YOU!
to design the perfect motoped!..
ebike design contest!!
swag, discounts, profit sharing..
what would your perfect motoped look like???
:idea: :?: :mrgreen:
references :
https://www.facebook.com/motopeds/photo ... 168865004/
https://www.facebook.com/motopeds/photo ... 508940570/
https://www.facebook.com/motopeds/photo ... 175608170/
MitchJi   1 GW
1 GW
Post by MitchJi » Apr 01 2014 6:21pm
Hi,
efMX Trials Electric Freeride wrote:Motopeds want YOU!
It would have enough space around the Jackshaft for a big pulley, something like 120t and 25mm wide so that we could get enough reduction (quietly) to eliminate the necessity for secondary reduction. Better yet, the pulley should be an option (instead of the exhaust system :D ).
It would also have enough space in the battery box for some for Nissan Leaf Battery Modules. The going price, at wrecking yards is about $100. We could carry enough in saddle bags for huge range, but it would be great if we could fit four, or even eight :mrgreen: under the top tube. Eight would be 16s 58V nominal and 60 Ah or 3.5kwh, plus two or four on each side in saddle bags (8 in saddle bags plus eight in the middle 32s and 60 ah = 116V nominal and 7kwh for $1,600).
http://endless-sphere.com/forums/viewto ... 62#p773858
icecube57 wrote:Battery module specs
Number of cells 4
Construction 2 in-series pairs in parallel
Length 11.9291" (303 mm)
Width 8.7795" (223 mm)
Thickness 1.3779" (35 mm)
Weight 8.3775 lbs (3.8 kgs)
Output terminal M6 nut
Voltage sensing terminal M4 nut
Module fixing hole diameter 0.3582" (9.1 mm)
Cell specs
Cell type Laminate type
Cathode material LiMn2O4 with LiNiO2
Anode material Graphite
Rated capacity (0.3C) 33.1 Ah
Average voltage 3.8 V
Length 11.417" (290 mm)
Width 8.504" (216 mm)
Thickness 0.2795" (7.1mm)
Weight 1.7624 lbs (799 g)
Best Wishes!
Mitch
Buying a new Tesla? Use a referral code and get six month's of free supercharging. Please consider using our referral code:
https://ts.la/lynnem96959
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
PRW   10 kW
Post by PRW » Apr 01 2014 7:49pm
I have a question - the website says "Rear hub: This is a custom made rear hub that must be used with the motoped. Rear hub is 135mm wide with 14mm axle. 36 spoke. Left side is ISIS mountain bike disc brake mount, right side is solid mount for sprocket. Hub has sealed bearings and is anodized black."
What standard hub motor would fit in this, or would there be an adaptor for common hubs?
thanks
jesset33   100 W
Post by jesset33 » Apr 01 2014 10:55pm
From memory my pit bike had a 12mm read axle so a hub should fit fine
If not I can get them made
Post by efMX Trials Electric Freeride » Apr 02 2014 11:28am
well the motopeds specific rear hub would of course be used for a mid-drive application..
the beefed up rear hub is needed due to the extra weight & power of the motoped vs a more standard mtn bike hub..
as for a hub drive build..
im guessing that most any hub motor with (close to) 135mm dropout spacing could be fitted..???
zombiess fitted a cromotor to the motoped chassis as a proof of concept for testing
but i think it was the wider motoped fat-bike version swingarm..
maybe ask zombiess on the other motoped thread.. :
from what ive read on their facebook etc, i think motopeds is trying to source both hub kits
& mid-drive kits that can be fitted or adapted to the current motopeds design..
PRW wrote:I have a question - the website says "Rear hub: This is a custom made rear hub that must be used with the motoped. Rear hub is 135mm wide with 14mm axle. 36 spoke. Left side is ISIS mountain bike disc brake mount, right side is solid mount for sprocket. Hub has sealed bearings and is anodized black."
What standard hub motor would fit in this, or would there be an adapter for common hubs?
thanks
Drunkskunk   100 GW
Post by Drunkskunk » Apr 02 2014 12:07pm
Damn that's cool! I would love to throw that pedal and swingarm setup onto the back of something like a Raptor frame.
melodious   100 kW
Post by melodious » May 03 2014 11:00am
Jeez. I love this frame and design. It's a great learning platform as well. Lot's of places to put the battery (or batteries). My only complaint is it's relegated to a motored wheel (135mm width) vs. a mid motor which translates to more mass on the rear swingarm. But at my age, I don't think I'll be crushing down rocky descents or leaping 25 feet into the air :?:
So who is going to take the leap of faith and try to get a group purchase here on ES :?: :mrgreen: LFP? He's probably your neighbor across the highway :wink:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
Post by efMX Trials Electric Freeride » May 03 2014 8:47pm
why would the motoped be limited to hub drive???
did you not read the whole thread and see the two motoped mid-drives (so far)???
with the jackshaft design motoped is made specifically for mid-drive...
also, the new fatbike version has 170mm rear spacing (fatbike standard?)
so room for wide high power hub motor if desired..
but don't count on group buys anytime soon..
they seem to be having some delivery problems..
melodious wrote:Jeez. I love this frame and design. It's a great learning platform as well. Lot's of places to put the battery (or batteries). My only complaint is it's relegated to a motored wheel (135mm width) vs. a mid motor which translates to more mass on the rear swingarm...
windtrader   1 kW
Post by windtrader » May 03 2014 9:24pm
That's sad to hear. I've followed this project for some time, well before it went crowd funding. It sees a great niche but something is not right with the folks at the helm. For whatever reason, they seem to be unable to get a production system in place, even after getting funding behind them. Also seem different hands involved behind the scene but that is all speculation. Just wish they would get all the motor kits out and maybe have some time to get some e-motor versions into the production lineup.
Post by efMX Trials Electric Freeride » May 03 2014 9:42pm
i don't think we should get too discouraged..
likely just some speed bumps on a long & winding road..
going from a small operation to international sales/distribution..
stay tuned.. i betting more motoped deliveries & e-motopeds are on the way...
kfong   1 MW
Post by kfong » May 04 2014 7:05am
I'm still waiting for mine, I did send them an email and they said mid May for those who bought frame kits and end of May for full bikes. Hopefully, it's true. Will post when I get it. I bought the frame with the upgraded suspension.
MitchJi   1 GW
1 GW
Post by MitchJi » May 04 2014 10:26am
efMX Trials Electric Freeride wrote:i don't think we should get too discouraged..
And is a pretty brave best, considering that the first post in this thread which announced them is dated October 2010!!!
Best Wishes!
Mitch
MitchJi   1 GW
1 GW
Post by MitchJi » May 04 2014 10:32am
Or check this post from 2011:
Everything has slowed down quite a bit in the last 2 months as we prepare to get the business end all figured out. I have recently been working with a business assistance program that has along with others, felt this project has great potential based on what we have so far. We are currently finishing up all the formality and then moving to seek out investment to make our first 100 frame run of a fully electric version of the bike. We may in the future produce some more of the gas ones but as of now they are pretty much dead, electric is the focus.
Best Wishes!
Mitch
MitchJi   1 GW
1 GW
Post by MitchJi » May 04 2014 10:34am
That is a pretty brave best, considering that the first post in this thread which announced the electric version is dated October 2010!!!
Best Wishes!
Mitch
Post by efMX Trials Electric Freeride » May 04 2014 12:19pm
apparently its a very long road! ;)
im not sure if the OP is even still involved w motoped or not???
since motoped has been crowd sourcing for more ebike designs..
gas is much cheaper than batteries for range so until that changes gas will out sell and be the focus..
its been a long wait.. hoping to get my frame & suspension soon..
supposedly electric kits are in the works but please don't hold your breath..
maybe the kits will become available about the time i finish my build.. :roll:
MitchJi   1 GW
1 GW
Post by MitchJi » May 04 2014 1:26pm
efMX Trials Electric Freeride wrote:apparently its a very long road! ;)
supposedly electric kits are in the works but please don't hold your breath...
These Nissan leaf cell battery modules, costs about $100 at wrecking yards.
They are a little big and heavy, but not hugely expensive.
http://endless-sphere.com/forums/viewto ... 25#p889766
I think a great configuration for these cells would be 6 sardine cans, unhacked, and wired into 12S/2P. Stack them up and figure out where to mount them on your bike. - Would give you 50V HOC and 2.5 kWhs. Weight would be pretty significant, but so would range and discharge capacity. This may not be the ideal configuration for a light & stealthy commuter/offroad bike, but for a long range touring ebike, I can see this being an easy and cheap solution. As an alternative to a Ping LiFePO4, this would work well. For light and stealthy, I will stay with HK LiPo. - It just seems like too much effort to break open the cans, cut the bus bars and reconfigure, for what still amounts to a hell of a big, heavy battery.
Best Wishes!
Mitch
Post by efMX Trials Electric Freeride » May 04 2014 3:33pm
thanks for the tip.. i'll check into it!
MitchJi wrote: These Nissan leaf cell battery modules, costs about $100 at wrecking yards.
Post by efMX Trials Electric Freeride » May 09 2014 11:45am
Motopeds are in production & getting ready to ship! :
Electric Bikes and street legal supermotos are next!
:D :mrgreen:
EDIT:
i have no affiliation with motopeds or it dealers etc..
its just for the interests of the readers etc..
Last edited by efMX Trials Electric Freeride on May 09 2014 6:37pm, edited 1 time in total.
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » May 09 2014 5:02pm
Sweet. I have two customers who ordered two stage drives from me for their Motopeds.
I think I can see my frameset in that bunch. :-)
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
