Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Baron   100 W
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Post by Baron » Feb 04 2017 11:21pm
Will "loctite metal" work well as an epoxy? It's about 3200psi vs. 3M DP420 4500psi.
I am making two torque arms for my genesis v2100, 1/4" thick steel, looks like I can get about 2 to 3 sq inches surface contact on each side.
Doctorbass   100 GW
Post by Doctorbass » Feb 05 2017 1:12am
Baron wrote:Will "loctite metal" work well as an epoxy? It's about 3200psi vs. 3M DP420 4500psi.
It should be enough. best is to cure it at higher temp like 60-70degree C.. for that youc an make your own DIY quick OVEN using cardboard box and hairdryer that you put the output into the box.
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
ebike11   100 kW
Post by ebike11 » Nov 12 2017 4:05pm
Hi do you still make these? If so anything for M16 axles?
Doctorbass   100 GW
Post by Doctorbass » Nov 12 2017 11:05pm
ebike11 wrote:Hi do you still make these? If so anything for M16 axles?
I dont make these anymore. Sorry
Doc
cwah   10 GW
10 GW
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Post by cwah » Jun 05 2019 10:42am
I've got 2 pairs for sales for anyone interested:
https://www.gumtree.com/p/bicycles/hard ... 1342410610
whereswally606   100 kW
Post by whereswally606 » Jun 05 2019 11:13am
sent a message on gumtree for both. thanks
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
Post by whereswally606 » Jun 05 2019 11:35am
money sent just in time before my phone battery died. :thumb:
cwah   10 GW
10 GW
Post by cwah » Jun 05 2019 11:36am
Sold
Firstlobster   1 µW
Post by Firstlobster » Sep 05 2019 8:52am
Have you thought about releasing the CAD files for the torque arms on thingyverse or something?
ejonesss   10 kW
Post by ejonesss » Mar 13 2020 3:31am
from page 13 there are 2 images of the dimensional drawings so it may be possible for someone with machine shop to copy them.
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
