Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
diggler   1 kW
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Post by diggler » Apr 15 2014 8:46pm
just wondering if these would be a good fit for my bike. I'm going to put a rear 1000w motor on here.
Good news it's steal. Magnet sticks. Do you recommend pulling the dropouts apart and just welding the arms to the inside. As of right now I think I might have to pull them apart a little already. If I do that I don't need the inside washers right. just tighten TA right to axle?
Easiest would be to just weld one on the left outside. But will be running 60v possibly so is one on each side recommended? Someone told me max is 2500w 45A at 58v.
GAS ELECTRIC FAT BIKE 49CC/3000W MXUS V1 18s Lipo 18 Fet BUILDING...http://endless-sphere.com/forums/viewto ... =6&t=65638
600W CAPACITIVE SPOT WELDER BUILDING... http://endless-sphere.com/forums/viewto ... =2&t=66466
HOLANDIA BEACH CRUSER 1000W 9C ?TURN REBUILDING... no thread yet.
Next project will be 18" Iron Horse hard tail mid drive
Doctorbass   100 GW
Post by Doctorbass » Apr 20 2014 9:39am
diggler wrote:just wondering if these would be a good fit for my bike. I'm going to put a rear 1000w motor on here.
Your frame look pretty easy to match with the ultimate Y-A. Inside or outside is not a problem too. You could weld these in place and have the oem derailleur arm cut to leave place to the one on the T-A. The steel on the frame is usually soft so i suggest to have the T-A welsed inside, but is is not that much important. You seem to have also enough surface to epoxy them or to bolt them.
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
cwah   10 GW
Post by cwah » Apr 20 2014 10:08am
Can the holes in the torque arms be threaded easily? I'd like to use the holes to mount stuff in it
Doctorbass   100 GW
Post by Doctorbass » Apr 22 2014 4:29pm
cwah wrote:Can the holes in the torque arms be threaded easily? I'd like to use the holes to mount stuff in it
The heat of the laser make the metal to become really hard so you will need to drill a hole before to make the threads otherwise you will break your tap threads
Chalo   100 GW
Post by Chalo » Apr 22 2014 10:30pm
You could also heat the part with a torch until it glows dull red, then let it cool slowly. That would return the material to a mild temper and make it easier to machine.
cwah   10 GW
Post by cwah » May 03 2014 5:18am
Thanks guys, sorry I didn't see you answered me. I'll do that.
I think I need REAL torque arm, not those sold in commerce with cheap metal. Look happened to my dahon jetstream with a BPM and 2.8KW only :(
Left torque arm:
Right torque arm:
Do you think your torque arms will be better than these ones? The holes aren't going to be wider like these torque arm?
Doctorbass   100 GW
Post by Doctorbass » May 03 2014 10:08am
cwah wrote: Do you think your torque arms will be better than these ones? The holes aren't going to be wider like these torque arm?
Yes it will not happen so easily! From EVERY ULTIMATE T-A i sold, that NEVER happened :wink: None ever break actually. This might be the answer for why i need to make a new batch every 6 month since years :lol:
I am sorry for what happened to you with your commercial torque arm, YEs the Steel Quality is making a big difference.. The Ultimate Torque arms i'm offering are made of top quality Canadian Steel QT100. The laser cut also harden the metal on teh surface that make contact to the axel wich help to avoid it to deform from the high pressure that the edge of the axel.
Next batch coming after i will be back from my trip to California. :wink:
Doc
cwah   10 GW
Post by cwah » May 03 2014 10:34am
Thanks doc. I'll get few pair from you as soon as you come back from california
broke   100 W
Post by broke » Jun 12 2014 3:39pm
Hay Doc did you get my PM?
kona stinky - adaptto - HT3525 - https://endless-sphere.com/forums/viewt ... 4#p1005754
bikes owned:
new build LR kit dirt bag frame adaptto - rohloff
kona stinky adaptto ht3525
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
hill toper kit (first kit)
2 Sanyo ebikes from japan
2 cheap folding bikes with 36v settups
Doctorbass   100 GW
Post by Doctorbass » Jun 13 2014 10:35am
broke wrote:Hay Doc did you get my PM?
Yes I got it and replied :wink:
Doc
arar1971   100 mW
Post by arar1971 » Jun 25 2014 6:04am
hi doctor bass. I need 1 pair of Torque arms and send you pm.
Larseren   10 mW
Post by Larseren » Jul 02 2014 4:30pm
Hi Doc,
I am also desperately in the need of a pair of torque arms for my new build, shipped to Norway if you can?
I have pm`ed you earlier but haven't got a response.
PeteB   10 W
Post by PeteB » Jul 03 2014 8:37am
Pm'ed for a set as well..Thank's Dr,Bass for the discount and free stickers...JUST KIDDING!.. :shock:
“The problem with quotes on the internet is that you can never know for certain if they’re accurate.” – Abraham Lincoln
TheBeastie   1 MW
Post by TheBeastie » Jul 10 2014 10:43am
I don't know if this is a good idea or not but I was just looking around the web at flux's mainly in the interest of etching metals with out getting too hot when I came across this, SUPER ALLOY 1, its a special flux and solder rod that claims it can solder aluminium and steel together. Their words below, I noticed the video was only posted a good month ago..
http://muggyweld.com/super-alloy-1
Previously, joining these two metals was unheard of in the welding community. Super Alloy 1, the 350f degree solder, makes easy work of this seemingly impossible of application.
This multi-metal solder is paired with a unique flux that works as a temperature guide, turning brown at the proper working temperature, and indicating when to add the Super Alloy 1 rod.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
Doctorbass   100 GW
Post by Doctorbass » Jul 10 2014 3:19pm
UPDATE ON T-A availlablility
Hi all I know there are dozens of you of you waiting for the next T-A batch to come available. Some of you have been waiting for weeks or months. :shock: :oops:
Your wait will have worth guys :wink: . I will get some soon.
The problem is that my last laser cut shop now refuse my order because they say it is too hard on their machine and it cost them too much to cut my 3/8" CHT100 steel. I was unhappy with the quality they delivered to me few times and i had returned them ans asked to get the same quality as the very first T-A batch I got from them wich was excellent. Unfortunately they now refuse to make them for me anymore.
With weeks of search I finally found a new shop that agree to make these for me at reasonable price but a bit higher than previously. This is not all shop that accept laser cutting 3/8 steel plate made of CHT100 with the precision I require. This require special tuning and many try before they succeed to make a nice cut. It also depend on the source for their CHT100 steel. Some are harder to cut than others and this require time and tuning for getting the quality I require. I also worked hard to keep price as low as possible.
Next T-A batch should arrive at the end of next week and will be 36$ /pair :wink:
Doc
RLT   10 kW
Post by RLT » Jul 13 2014 5:27pm
Doctorbass wrote: ....Next T-A batch should arrive at the end of next week and will be 36$ /pair ...
Doc
Keep me on the list. I'll sell some blood or something to pay the increase :P
arar1971   100 mW
Post by arar1971 » Jul 14 2014 7:31am
sorry I did not mean like that.
rear hub torquearm.jpg (76.31 KiB) Viewed 2668 times
eBikeWannaBe   10 mW
Post by eBikeWannaBe » Jul 14 2014 10:13am
arar1971 wrote:dr. you did not respond me and finally I decided to make my own torque arms 301 s.steel laser cut. 2 different models.if someone interests, I have 5 pairs more.
http://endless-sphere.com/forums/viewto ... 31&t=61579
Man that's so not cool to try and sell your TA's in Doc's thread! :evil:
ejonesss   10 kW
Post by ejonesss » Jul 14 2014 3:30pm
Doctorbass wrote:UPDATE ON T-A availlablility
Doc
ask the shop where they got their laser cutter from and go out and buy one (yes it will be thou$and$)
if worse comes to worse have them cut them thinner say 1/8 and stack 3 plates to make the 3/8.
and note to other users selling their brand of torque arms please make a separate thread and keep this thread for the doc's brand topic.
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
Dream_Crusher   100 µW
100 µW
Post by Dream_Crusher » Jul 22 2014 1:18pm
any updates? been waiting about 2 months now... :cry:
Doctorbass   100 GW
Post by Doctorbass » Jul 22 2014 6:41pm
Dream_Crusher wrote:any updates? been waiting about 2 months now... :cry:
i'll get these This week! :wink:
Doctorbass   100 GW
Post by Doctorbass » Jul 30 2014 8:49pm
OK guys Great New!!
I got the new batch of 75 T-A set today. :wink:
I am really satisfied with teh QC and overall result! :mrgreen:
All of you that sent me PM for these will be replied soon, but this week i'm really too busy and next week i will go for a 6 days 2000km trip with my Zero and the new 15kWh setup.
When i'll comeback i'll begin request payment and shipping these.
Doc
waynebergman   10 kW
Post by waynebergman » Oct 08 2014 9:34pm
Hi Doc
Please send me a set. These will be for my tadpole in progress http://www.endless-sphere.com/forums/vi ... =6&t=63755
I will shoot you payment when you have them ready to go. Wayne
Doctorbass   100 GW
Post by Doctorbass » Oct 08 2014 10:29pm
waynebergman wrote:Hi Doc
Pm sent :wink:
ERASTABIKE   1 µW
Post by ERASTABIKE » Oct 09 2014 3:59pm
how can i order a set of 2, NEW 10.?mm+++ ?
i need them please
