I put 25 KW bursts through these wheels and over 11 KW continious. They are bulletproof.Drum wrote: I am thinking of using one as a rear hub on a reasonably powerful (around 5kW peak) mid-drive off road bike, with sprocket one side and disc the other.. do you think they would be up to that?
Thanks,
Drum
*SOLD OUT* 17 Inch Moto Wheels - 150 Bux per set!
Re: 17 Inch Moto Wheels - 150 Bux per set!
3220 Mountain Bike http://endless-sphere.com/forums/viewto ... 17#p244317
Suzuki Lipo Upgrade http://endless-sphere.com/forums/viewto ... 86#p335986
Race Bike http://endless-sphere.com/forums/viewto ... =3&t=32486
Definitely keen, PM sent.
Anyone know of more like this? Got the front covered, rear wheel with disc and sprocket is what I'm looking for.
- nutnspecial 1.21 GW
I'm on the search too barnfresh- if voloci's aren't available the oset bikes use a similar setup I think.
Stevil_Knevil wrote:Hi there,
I have 1 last set of17 inch wheels for sale.
*3/29 Edit: 1 last set available*
The rims are 36H FEMCO 1.20x17 chrome plated steel (that's 40+ mm wide folks!). Spokes are 12 gauge (2.58mm dia.) Stainless Steel laced 2-cross to a 100mm wide, disc compatible QR alloy front hub. Building a very strong, hub motored wheel should be pretty straight forward if you cut & thread these spokes to length, or just plop it in your disc compatible (QR dropout) fork as is!
Yes, DOT compliant. Cost is 75 bux each +shipping from NorCal ..you lucky people
ERD = 418.5 mm
Spoke Hole Diameter = 5.14mm
Spoke Diameter = 2.58mm
Nipple Diameter (before the flare) = 4.6mm
Weight = 4.25 pounds
Hub Flange Diameter = 58mm
Hub Flange Width (C->C) = 58mm
Bearings = Sealed cartridge (made in Japan)
EDIT: Measurements and details in bold type added/fixed.
____________________________________
We don't care. We're riding Ducatis in our dreams.
- skeetab5780 10 MW
- Contact:
Hey Stevil are they both fronts or do you actually have the rear one laced to a dual disc hub?
Youtube channel http://www.youtube.com/skeetab5780
Kuberg Freerider Project viewtopic.php?f=28&t=90187
Direct Drive Genesis http://endless-sphere.com/forums/viewto ... 28&t=59122
Voloci Pageviewtopic.php?f=12&t=58410&p=1372424#p1372424
Denzel 4-Spd Electric Dirt Bikeviewtopic.php?f=12&t=99606&p=1580294#p1580294
Yes Skeet, 1 each front and rear fully built moto wheels. I also have a brand new 17 X 2.50 Michelin Gazelle and tube for another 30 bux.
- skeetab5780 10 MW
- Contact:
That is temping. I think I want to buy them just to have the last set! you have 2x gazelles?
Only 1x Gazelle & tube ..does 175 bux make your 'buy now' trigger finger itch?
- skeetab5780 10 MW
- Contact:
Ya..What is shipping
Not sure, let me get back to you on that..
..the deal will include a spare rear axle
- skeetab5780 10 MW
- Contact:
Oooo nice you found one
Yep, PMed..
Re: *SOLD OUT* 17 Inch Moto Wheels - 150 Bux per set!
All gone.
Thank you, Spherites!
Long may you roll..
Long may you roll..
I'm trying to find a rear hub like you use here. Two sided 6-bolt. Any information on where to find those? or what style or intended application it is for? Thank you!
