Assembled Hi-Power LiPo battery packs - any interest?
Rube   100 W
Re: Assembled Hi-Power LiPo battery packs - any interest?
Post by Rube » Nov 07 2018 4:54am
Congratulations Chris, really cool is a huge understatement. I've followed your work, and the research and development to produce this as a viable product deserves its own paper. Massive respect for pushing the envelope to adapt LiPo to such an unforgiving Australian climate. I can only imagine the hours of research and development it took to deliver such an elegant solution. Super cool :es: :lowbatt: :bigthumb:
Might see you this weekend. :D
Toby82   100 mW
Post by Toby82 » Nov 07 2018 5:47am
Hey Chris,
New liquid cooled packs look great.
What's even better is the dimensions are perfect for my build.😁
Be great if I was not on the other side of the continent so I could drop past for a chat and to check out your work.
Cheers
jonescg   1.21 GW
1.21 GW
Post by jonescg » Nov 07 2018 6:17am
Toby - we can compromise - come to Brisbane for the AEVA conference and Expo! Brisbane is just up the road (in West Australian terms) :mrgreen:
Doctorbass   100 GW
Post by Doctorbass » Nov 07 2018 1:44pm
Hmm I see power here!!!
Properly installed/used copper buss, excellent current share, great thermal management, well protected cells, AWSOME WORK :wink:
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Samd   1.21 GW
1.21 GW
Post by Samd » Nov 07 2018 8:36pm
Awesome work Jonesy.
http://ballaratebikes.com/
Danny Mayes   1 kW
Post by Danny Mayes » Nov 25 2018 3:40am
Very ambitious battery Chris. I love it.
Cool to see the cells glued in with thermal epoxy and the cooling base looks rad.
D
Frank   100 W
Post by Frank » Nov 25 2018 1:06pm
Nice looking pack Chris. Very nice. Have you had a chance to grab any Delta-T under-load data yet ? i.e. top of pouch versus heat sink? My limited experience with pre-heating indicates the cell innards conduct heat fairly well. Great idea BTW, you could also circulate warmed coolant on chilly days. :thumb:
Frank
jonescg   1.21 GW
1.21 GW
Post by jonescg » Nov 25 2018 7:57pm
Frank - hope to get that data this week. I've been busy with other stuff, but hope to get some numbers soon.
I have a test rig where I measure inlet and outlet temperatures, as well as cell top temperatures. The thermal conductivity in that plane is very good (it's like 50% copper and aluminium through there).
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 08 2018 7:11am
Just some pictures of the Prelude battery coming together:
4 done and a spare.jpg (220.67 KiB) Viewed 1744 times
Volts   1 W
Post by Volts » Dec 27 2018 10:54am
These things are works of art dude good job, my only thing is why the hell would you do all that work only to run lipos with a 5c rating when there are single cells out there with 50c rating?
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 30 2018 7:24am
Volts wrote:
Dec 27 2018 10:54am
Specific energy. These 5C cells are over 208 Wh/kg at 1C, so using 18650 testing regimes they are well over 220 Wh/kg.
This gives a vehicle which will never exceed 2C discharge a range of about 160 km on the highway, and probably 190 km around town.
The 30C/60C cells I have for the race bike are only about 158 Wh/kg at 1C. So it's all about range.
Arlo1   100 GW
Post by Arlo1 » Dec 30 2018 12:11pm
jonescg wrote:
Dec 08 2018 7:11am
Very nice man, Did you cycle each cell to weed out the duds?
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 30 2018 7:59pm
Hey Arlin,
I didn't cycle each one, but I do check voltage and DCIR. If a cell was below 3.80 volts I left it out, and likewise if the DCIR was above 15 mOhm I put it aside. Most of them fell a few milliohms either side of 8 mOhm.
I hope to finally get around to thermal testing it this week, but the car itself has been keeping me busy. Just cut the back seat divots out of the car yesterday and will be welding up the subframe today.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 31 2018 3:50am
So I decided to set up the test rig for measuring heat removal with the liquid cooling plate.
I borrowed a few parts from work, including the PC cooling pump and radiator. However, the thermocouples are not giving satisfactory readings through the multimeters, so unfortunately I will have to borrow the datalogger from work too.
All set up to deliver a 150 amp (6.6 kW) discharge. In the car, this would equate to about 53 kW, which is pretty close to maximum power from the inverter, but we might be surprised.
At least the datalogger can manage 8 separate thermocouple channels so I will put a few on the top side of the battery as well.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 31 2018 6:23am
Hehe, so it turns out it's a 330 amp discharge, which is almost 5C. Considering how they don't sag a huge amount, I reckon that's pretty good. At worst this pack will see 2C continuous, for about 2 minutes or so.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jan 10 2019 9:04pm
I finally got around to testing the cooling system on this battery module. To be honest I'm disappointed, but it's not all bad. Let me explain.
First up, this is a 4.4 C discharge on a cell which is nominally 1-2 C and 5 C burst - so I'm fairly hammering it. At 330 amps, the busbar linking the two half modules is not rated for this sort of continuous rate (neither are the cells, but that's not what I was testing).
Secondly, the cells were still warm from the day - they have a specific heat capacity of about 2000 J/kg.K so they retain heat fairly well. The cooling loop was bringing them down to ambient slowly before I started the run, hence the higher starting temperatures for the cells.
Finally, the thermal epoxy application on this particular module was poor - the cells to the rear of the module have very little contact with the potting material, while the ones at the front were OK. This is evident in the difference in temperatures of the two probes I had in the pack. I applied the thermal material with a spatula, rather than squeezing beads out with a gun like I did for the others. So there would definitely be better contact and heat transfer in the later modules.
Still, the delta T on the inlet and outlet was at best 0.6 'C with a flow rate of 3 litres per minute.
temp plot.JPG (48.3 KiB) Viewed 1470 times
So at the point where the cells are as hot as they can be, the water in the cooling loop was removing heat at a rate of about 120 W. At this point the cells are generating about 1000 W of waste heat, so they get hot fast. They cooled down once the load was removed at a rate which was OK, but when I turned the pumps off for the night and went to bed, the rate of cooling was not much slower.
I might try to cool the busbars above with airflow as they are in direct contact with the core of the cells. It may end up being as effective as the liquid cooling :confused:
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jan 11 2019 9:28am
How I make them.
Enjoy!
Frank   100 W
Post by Frank » Jan 11 2019 12:54pm
Fun video - what is that, a couple of hours in real time?
Cooling busbars makes sense, would it be hard to try now? It sounds like you've already got some temp sensors embedded in the pack. :thumb:
Frank
Arlo1   100 GW
Post by Arlo1 » Jan 11 2019 1:17pm
Guys I read a paper showing how cooling the Tabs is the most important thing to do in cooling pouch cells.
www.powerdesigns.ca
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jan 11 2019 7:56pm
Tab cooling is the most effective way to cool a pack but other than air convection you're limited to low thermal conductivity polymers stuck to the battery terminals. Not only that you cant seal a battery completely from the elements when you aircool. This is the perpetual dillemma. Base cooling is the best compromise here given the constraints.
Arlo1   100 GW
Post by Arlo1 » Jan 12 2019 2:15am
jonescg wrote:
Jan 11 2019 7:56pm
That's where some fancy potting comes in ;)
www.powerdesigns.ca
jonescg   1.21 GW
1.21 GW
Post by jonescg » Feb 02 2019 6:13am
Just finished up a 28s8p battery pack (100 V, 40 Ah, 4 kWh) for another electric motorbike using the 30C continuous cells. It's built as a 24s8p pack, and a small 4s8p pack which is placed somewhere else in order to fit.
EV-Power BMS, polycarb enclosure. The cells should be good for over 1000 A continuous, but the buslinks are only 35 mm2 solid copper so probably only 200 A continuous. Not that it matters - even at 200 A the pack is flat in 12 minutes.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Mar 18 2019 1:25am
I figure it's about time I shared the Prelude battery pack.
This battery pack sits in the fuel tank space and has six 12s10p liquid-cooled modules in series. The conversion needs two more modules up the front to make a standard 355 V nominal pack with 24 kWh of useful energy. This rear battery stored 19 kWh as it is.
A bit of patching, sealing and some black paint to hide my sins...
cover painted.jpg (228.54 KiB) Viewed 966 times
It makes for a neat fit:
HV cable routing.jpg (185.31 KiB) Viewed 966 times
I used that aluminium honeycomb sandwich material with epoxy resin potting. It's good, and very space and weight efficient, but in another life I would put some additional fixings in tension in the middle of the pack. It will be fine for this job though - only 125 kg being supported by 26 high tensile M6 bolts.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Apr 05 2019 1:34am
Finally shipped off this 24s10p battery where it will be going into an electric cruiser motorcycle. BMS by EV Power as before, this time with a full 12-cell read out per screen.
Splash screen 2.jpg (262 KiB) Viewed 865 times
4.4 kWh, and will be paired up with a Motenergy and Sevcon combination (50 kW). I think it will look good when painted black (of course) :)
Pauls bike.jpg (264.04 KiB) Viewed 865 times
jonescg   1.21 GW
1.21 GW
Post by jonescg » May 16 2019 1:36am
Guess who's not going to have a weekend or evening free for the next month...
