Assembled Hi-Power LiPo battery packs - any interest?
jonescg   1 GW
1 GW
Re: Assembled Hi-Power LiPo battery packs - any interest?
Post by jonescg » Oct 13 2017 9:33am
Wooop!
Cells are in!
LiPo arrived.jpg (105.99 KiB) Viewed 2110 times
jonescg   1 GW
1 GW
Post by jonescg » Nov 07 2017 3:56am
I've started putting a couple of packs together already - but I do have about 280 spare cells so if anyone wants a pack just let me know.
I also have some good pricing on 7 Ah pouch cells. These are a high energy density but low C-rate cell, perfect for range. They will work out to about AUD$20 each + GST.
Minimum order is 1000 cells, so there would need to be quite some interest...
jonescg   1 GW
1 GW
Post by jonescg » Dec 19 2017 9:18am
Hi all,
I'm putting a small order together for some 18650 cells. I don't normally work with cylindrical cells, but a particular project has popped up where they will be good enough for the job. I can get any number of the following:
Panasonic NCR18650GA 3500 mAh (10A max current - and even then that's pretty generous)
Sony US18650VTC6 3000 mAh (30A max current)
Samsung INR18650-30Q 3000 mAh (15A max current)
LG18650HG2 3000 mAh (20A max current)
Price is about AUD$4.50 each landed, but will confirm once I have some numbers.
Let me know if your're interested!
Chris
jonescg   1 GW
1 GW
Post by jonescg » Jan 01 2018 8:53am
A 2 kWh battery for a Motard project. It's not as crazy high power as most - maybe a top speed of 100 km/h, but heaps of fun!
2 x 14s2p RHS.jpg (213.64 KiB) Viewed 1854 times
2 x 14s4p LHS.jpg (187.75 KiB) Viewed 1854 times
This will be going inside an aluminium enclosure (with plenty of thermally conductive encapsulant) for better cooling since it will probably be hit pretty hard.
alec   10 W
Post by alec » Jan 01 2018 4:08pm
Gorgeous work! That cable management on the BMS’s makes me drool.
❝ With great power comes an even greater PG&E bill.
12kW+ Greyborg, Cromotor V3, SSC96150
sabvoton.wire.bike [unofficial user's guide]
wire.bike [personal projects]
jonescg   1 GW
1 GW
Post by jonescg » Feb 17 2018 8:17am
This pack is finally going together.
Kapton in.jpg (201.99 KiB) Viewed 1669 times
I was sent a sample of some of DuPont's latest Kapton - it has a thermal conductivity of 0.8 W/m.K which is about 7 times better than the regular stuff. It's also very thin. I just used contact adhesive spray to put it in place. I also have some thermally conductive, electrically isolating epoxy which will fill in the gaps and keep the pack snug inside it's aluminium enclosure. Yes, this will be a permanent battery. Now is the time to make any final adjustments!
Plan is to provide a decent thermal path from the hot cells to the outside of the pack where convection can do it's job.
Arlo1   100 GW
Post by Arlo1 » Feb 17 2018 11:04am
What BMSs are those?
My Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
jonescg   1 GW
1 GW
Post by jonescg » Feb 17 2018 9:04pm
Arlo1 wrote:
Feb 17 2018 11:04am
ZEVA. Ian Hooper also lives in Perth - good bit of kit but the quiescent current is higher than I'd like for small capacity packs.
jonescg   1 GW
1 GW
Post by jonescg » Feb 17 2018 10:31pm
Battery potted.jpg (208.19 KiB) Viewed 1627 times
Well that was stressful. Thermal epoxy ensures its permanent; no going back.
Despite all the efforts to keep it isolated, I'm still measuring a few volts between the terminals and the case. It rapidly diminishes so it could be a capacitive thing. That's why I like polycarbonate I guess...
Arlo1   100 GW
Post by Arlo1 » Feb 17 2018 11:10pm
Its very likely capacitive my car does that you need to be careful but its likely ok.
jonescg   1 GW
1 GW
Post by jonescg » Feb 17 2018 11:12pm
Zero packs are potted inside aluminium cases too aren't they? My first bike has this problem - I'd get shocks off it all the time. That's why I went to polycarb enclosures...
Arlo1   100 GW
Post by Arlo1 » Feb 18 2018 12:01am
There is a way to design it out. Polycarbonate absorbs water over time and becomes conductive.
jonescg   1 GW
1 GW
Post by jonescg » Feb 18 2018 12:06am
I think the Kapton and potting compounds are probably the best way to go about it for now. And perhaps a 100 ohm resistor between the negative terminal and the chassis to ground any build up. This enclosure was also a very tight fit. If I'd made it a little bigger and used more potting compound to fill out the gaps it would probably be better still, but the thermal path is worse.
Arlo1   100 GW
Post by Arlo1 » Feb 18 2018 1:28am
jonescg wrote:
Feb 18 2018 12:06am
I don't recommend that!
Any time the chassis is connected to either side of the pack its potential for all kinds of problems including threats to life safety.
I touched the precharge side of the 1kohm resistor I had for bench tests with the other hand on 230v + and it hurt like hell. That was with dry hands etc. 1 100ohm resistor has potential for enough to stop a heart for sure.
jonescg   1 GW
1 GW
Post by jonescg » Feb 18 2018 9:33pm
Couple of shots of the battery potted inside the enclosure:
Just got to get the final terminations made through the Delrin and we're gold.
sacko   10 kW
Post by sacko » Feb 25 2018 11:01pm
These boards look excellent!
I am looking to do a 13s2p config using Turnigy 1s 5000 20c cells.
https://hobbyking.com/en_us/turnigy-500 ... -cell.html
Are you able to supply a PCB for that setup by any chance?
jonescg   1 GW
1 GW
Post by jonescg » Feb 25 2018 11:57pm
I'll have a look for what boards I have in the 42 mm wide range. I did get some made up a long time back.
I mainly have PCBs and copper matching the Turnigy 40C cells (9 mm thick, 50 mm wide, 135 mm long)
Are you stuck with the 42 mm wide cell or can you spare the room for a 50 mm wide cell?
sacko   10 kW
Post by sacko » Feb 27 2018 7:23pm
The room isn't an issue, but I can't get hold of the 40c cells over here it would seem.
jonescg   1 GW
1 GW
Post by jonescg » Feb 27 2018 8:08pm
sacko wrote:
Feb 27 2018 7:23pm
Hmm strange. I have some cells here but it would not be easy to ship them to you (no to mention expensive).
I can't find those 42 mm wide boards, but I've not had a thorough look. I may have discarded them because I found I can get custom cells made to match the 50 mm wide dimensions, but the minimum order is like, 1000 cells or so.
Will let you know either way.
Jaack   10 µW
10 µW
Post by Jaack » Feb 28 2018 1:04pm
hey Chris...been reading the posts(impressive packs) and i a bit concerned with the turdgy 20c 5ah cells with the puffing issue..is this the norm with these cells..im considering a 21s 4p x2 for a total of 40ah for a kart build.i may be able to source some a123 systems 20ah cells for 17.85 each..don't know if i trust the source though...tell me what you think...https://www.albania.com/product-detail/ ... 4.....they don't usually sell the cells separate out side of a pack but are going to sell me separate cells anyhow. herewin has the 30c cells for $8.00ea+ $270us shipping for 168x cells to US ..if i take a chance with the a123 cells ill need a board for connections...tell me if this would work ....take a length of acetal sheet and cut slots for the tabs with a table saw then insert the tabs through the slots and bend the tabs over the top of bolted down bus bars then sandwiching the tabs with the bus bars and join each connection with solder...
jonescg   1 GW
1 GW
Post by jonescg » Feb 28 2018 8:16pm
Turnigy cells from Hobbyking are not the best quality cells. They are all made in the same factories, but Turnigy-branded stuff is generally not the best. They will puff under normal use - the FEP cells I've tested don't puff at all, or at least not for a long while anyway.
A123 pouch cells are okay, I haven't worked with them for a while. But it's easy enough to devise a board with nuts on the back for terminating as I did here with the large NMC cells.
Herewin have been good in the past, but I found FEP cells to be a bit more consistent. It's all a bit of a gamble, but so far I'm content with them.
The only place I use solder now is for holding the nuts on the backs of the boards.
Jaack   10 µW
10 µW
Post by Jaack » Mar 01 2018 5:41am
jonescg wrote:
Feb 28 2018 8:16pm
do you have 22s 4p x2 boards available for sale along with the bus bars and push nuts? if so how would one order a set.... with pricing? does the boards come with the nuts solderd on,id like to avoid soldering if i could what are "NMC" cells?...
jonescg   1 GW
1 GW
Post by jonescg » Mar 01 2018 8:00am
Jaack wrote:
Mar 01 2018 5:41am
Yep, but only for 9 mm thick cells or 8.2 mm thick cells, and all at 50 mm wide. I can put them together for you and sent them off no trouble. With or without copper buslinks?
The NMC cells I was referring to in this thread a couple of pages back. They are a 25 Ah cell a customer brought in. We devised a PCB to suit and it came together quite nicely.
Jaack   10 µW
10 µW
Post by Jaack » Mar 01 2018 11:37am
jonescg wrote:
Mar 01 2018 8:00am
Jaack wrote:
Mar 01 2018 5:41am
yes i would need the bus bars too ...i haven't got the batteries yet so before i buy the boards and bars let me get the batteries..then ill place the order...whats the price for the kit $US
jonescg   1 GW
1 GW
Post by jonescg » Mar 01 2018 7:52pm
OK so 2 lots of 22s4p boards and copper busbars would cost $484 AUD - or about $370 USD. Shipping will be on top of this, maybe about another $70-$100 because of the weight of copper.
These can be for either the 8.2 mm thick cells from FEP or the 9 mm thick cells, both of which are 50 mm wide.
I suggest you buy the cells first then measure their thickness - we can assess which boards to use if they are too far away form either of these two measurements.
Cheers,
Chris
