Advanced ADAPTTO controllers and compatible products
Cowardlyduck   10 MW
Re: Advanced ADAPTTO controllers and compatible products
Post by Cowardlyduck » Jan 22 2017 9:32pm
atomek1000 wrote:I would advise to make motor tuning one more time. It takes time to get it right and settings could be different for each controller so dont just set the same as previous.
Please post your current setting as well as profile sets (amps etc) so we can tell more.
Yes, I definitely need to try tuning some more. I didn't just set the same as before as I re-seated the halls, so knew this would change.
I'll try and get some photo's and post up soon.
atomek1000 wrote:Also, did yo blew only fets on last adaptto or whole cpu etc?
Well, it was just the FET, however it blew so hard I think it's likely it also took out other stuff with it.
More details here:
https://endless-sphere.com/forums//view ... 6#p1228275
Cheers
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Ebike Garage - My YouTube Ebike ramblings.
madin88   100 MW
Post by madin88 » Jan 23 2017 5:45am
Cowardlyduck wrote: Or, have I just got a messed up tune? I did crack open and re-seat(epoxy) the hall sensors on my HS4080 since I had my last Mini-E. I also can't remember if I was running 18S or not on the last controller. Does the voltage increase significantly increase heat that much?
When I'm moving at a decent speed, 30-50kph, in Boost mode, this thing just shoots like a rocket up to 70-80kph and scares the hell out of me on the dirt.
yes, 12s to 18s makes a big difference in top end acceleration
but this also means there is much more power converted by the controller (the phase amps will be very high for a longer time which means more heat).
It's only when I'm trying to go up steep inclines, it basically becomes unusable unless I use Eco mode and pedal like mad. Keep in mind also that my Mini-E is covered in Heat sinks, cooling fans and thermally sinked to the frame, and it is still overheating reaching 75C.
sounds like the hall angle is not optimal. i bet if you do manual tuning, it will be much better.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
BCTECH   100 W
Post by BCTECH » Feb 01 2017 11:19am
Does anyone here have been in contact with adaptto recently? I have been trying for a month to get my controller back, received one email from Oleg 2 weeks ago said will ship out but no tracking number neither received.
I am not sure if all my emails went to their spam . If adaptto see this thread, please reply. Or much appreciated if anyone already talking to them, pls help pass the message, tks
Rix   100 GW
Post by Rix » Feb 01 2017 11:53am
BCTECH wrote:Does anyone here have been in contact with adaptto recently? I have been trying for a month to get my controller back, received one email from Oleg 2 weeks ago said will ship out but no tracking number neither received.
I haven't been in contact with Adaptto, but its possible with winter storms that your controller is delayed. I have several packages that have still not made it to me due to storms.
BCTECH   100 W
Post by BCTECH » Feb 01 2017 12:13pm
I hope that's the case. my feeling is that it's not shipped yet since no tracking number given. Or for some reason they have not received my emails that I provided my address.
Merlin   1 MW
Post by Merlin » Feb 01 2017 12:22pm
did you tried email or the website form?
http://adaptto.com/Contacts/
if you use this you can be sure they get the message.
to bad that behavior repeats from the early years. dont get why, but it sucks.
iam really happy that my max-e still runs.
but i had some infos that qulbix switch to another supplier/product....
says also something to me....
edit:
or try a call and ask for oleg (or someone who talk english)
115230 Electrolitniy Proezd 3 Bld 1
Moscow, Russian Federation
Phone: +7 495 215 2878
Fax: +7 495 510-22-86
Email: sales@adaptto.ru
Website: http://adaptto.com
BCTECH   100 W
Post by BCTECH » Feb 01 2017 12:51pm
Merlin wrote:did you tried email or the website form?
thanks, and I just sent a message from there
sending back is the worst thing that I ever wanted to do, but no choice as adaptto wouldn't sell parts to user for fixing.
brumbrum   100 kW
Post by brumbrum » Feb 01 2017 1:57pm
Check the time differences from Canada and then phone them up. Hopefully they keep a record of repairs and a record of your controller number. I am not sure my conteoller had a tracking number when sent back.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
BCTECH   100 W
Post by BCTECH » Feb 09 2017 11:23am
chucho wrote: If you have news please send me MP cause i am also waiting. Thank you :wink:
Just received my controller back.
maybe Oleg is away, there was another person at adaptto replied me and sent the controller back for me
richdeloup   100 W
Post by richdeloup » Jul 02 2017 5:02am
Hi all, quick question that I'm sure has been covered before.
Can I charge my Adaptto system using just a Easton apr48v without using the coil?
I have a coil but would like a second charger and already have 2 Eatons?
Thanks in advance
9 ebikes, one pair of legs, small apartment, no wife
Altair   100 W
Post by Altair » Jul 02 2017 7:38am
No, the coil temporarily converts the controller into a boost converter, which allows it to match different voltage power supplies to your battery requirement, and control the charge precisely.
The only other way would be to disconnect the battery from your system and charge it with some kind of other controlled & limited power supply, but then bad things could happen if not monitored closely.
richdeloup   100 W
Post by richdeloup » Jul 02 2017 8:04am
Thanks Altair that explains it, I wondered how it got up to voltage.
2nd question, where to buy one, does anyone have a spare coil in Europe that I can purchase?
Altair   100 W
Post by Altair » Jul 02 2017 8:11am
Alex in Sweden could surely sell you one. http://adaptto.envolt.se/
richdeloup   100 W
Post by richdeloup » Jul 02 2017 8:46am
Great, thanks for that
Rix   100 GW
Post by Rix » Jul 02 2017 8:49am
Altair wrote:Alex in Sweden could surely sell you one. http://adaptto.envolt.se/
Allex is on Holiday at the moment. May not get a quick response.
Altair   100 W
Post by Altair » Jul 02 2017 9:19am
Then try Artur at http://www.vectorebike.com/
richdeloup   100 W
Post by richdeloup » Jul 02 2017 9:35am
Yep thanks, I've just messaged Artur.
On the off chance, has anyone got the the tuned Adaptto settings for a mini-e with a Mxus 3k turbo?
If not I'll get the manual out and go through the process
Rix   100 GW
Post by Rix » Jul 02 2017 3:56pm
richdeloup wrote:Yep thanks, I've just messaged Artur.
I played with the settings on my MAX E. I couldn't find a better combo than running the Auto-detect a couple of times. All I did after running Auto detect was increase the IND Timing and PWR Timing. I think I am running 158 and 622 respectively on those timing values now. I have OVS set on 3. I noticed more power and accleration after 30MPH with an 18s pack. Within your Mini-E I would start off by running the auto-detect and give it a try with just that.
richdeloup   100 W
Post by richdeloup » Jul 02 2017 4:28pm
Thanks Rix, I'll give that a go and see how it spins:)
douglashart   100 W
Post by douglashart » Jul 05 2017 12:23pm
My mini display wont come on. I had it running on the stand, charged , autodetect all good. took a break , when I came back , the display wouldn't come on. I did hook up an adjustable brake for a minute but wasn't sure of my wiring so disconnected that, and ran it some more after that. Ive tried contacting adaptto , with no replies, ive also posted on the other adaptto threads. Still NO answers. Any suggestions for any solutions? I would ship it in a minute, if they would just talk to me. thnx doug
ridethelightning   1 MW
Post by ridethelightning » Jul 06 2017 5:17am
possible to swap out for another display to see if thats the issue?
i have had intermittent issues with display coming on, like the screen would not boot properly. fixed by disconnect battery and reconnect.
open display and check to see if the wimpy wires from controller are well soldered to pcb or not.
richdeloup   100 W
Post by richdeloup » Jul 09 2017 6:28am
Quick questions about the cell balancing procedure.
Does the controller need to be left on for the cells to balance down?
Does the charger/coil need to be left connected for the cells to balance down?
My display says that its balancing for a while, then stops saying this before the cells have balanced out??
Thanks for any guidance
Merlin   1 MW
Post by Merlin » Jul 09 2017 6:59am
... Controller has to be on.
... Coil or charging connectors had not to be connected.
... This "bms" is not what you may expected. It's more a safety feature.
It bleeds only the cells down to your voltage you like.
Not really balancing cells out.
If you setup your bms to 4.15 it will bleed down all cells to 4.15
If one or more has less then 4.15, it will not be "affected" of "balancing"
richdeloup   100 W
Post by richdeloup » Jul 09 2017 7:26am
Thanks Merlin, that explains what I needed to understand.
Longshot   100 W
Post by Longshot » Jul 11 2017 8:27pm
Merlin wrote:... Controller has to be on.
Hey merlin, I have an EIG 20s 20AH battery from NYX. My cell #9 is at 4.15 and eveything else is at 4.0. I cant get the BMS to give me that juicy last 1.0volt. What can I do?
