Advanced ADAPTTO controllers and compatible products
ecruz   1 kW
Re: The most advanced Adaptto Mini-E Controller + BMS
Post by ecruz » Jun 11 2014 4:56pm
Guys how did you get your order of the Addopto Max_E I am waiting to order can someone tell me?
arcticfly   100 W
Post by arcticfly » Jun 11 2014 11:21pm
Thanks Alex!, Now if only someone would answer my emails over at Adaptto so I could order. Funny business model not answering emails :?
liveforphysics   100 GW
Post by liveforphysics » Jun 12 2014 12:33am
I am drooling to get one myself.
anttipaa   10 W
Post by anttipaa » Jun 12 2014 1:01am
Got response from Adaptto. They sayd Max-E controllers would be ready late this week.. Hope so..
Canyon Torque + ?
ridethelightning   1 MW
Post by ridethelightning » Jun 12 2014 1:47am
hang in there guys, dont compromise :D
crea2k   10 kW
Post by crea2k » Jun 12 2014 4:07am
I have everything paid for just about other than the controller, I got a reply at the start of the week and they asked for my address, but haven't heard anything else back yet, so fingers crossed !.
GCinDC   10 GW
Post by GCinDC » Jun 16 2014 7:27am
a bit of lazy tutorial here, hopefully helpful...
edit: from my ride in this morning, i can say that max regen, at ~34A was very strong. no need to use actual brakes, and better be sure to have two hands on the bars! i also enabled Smooth, and found it nicer than the instant hard braking w/o it enabled. if it were only set to ~20A regen, i might not want the smooth, but at 34A, it comes on just a bit slower...
i forgot to show the throttle/brake configs. it was dumb not to ensure that was configured properly, but seemed to be w/ factory settings..
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
GCinDC   10 GW
Post by GCinDC » Jun 16 2014 7:35am
the ride, fyi:
and quickie of the bms in action:
and a handy bms diagram, fyi (from here- thanks to ridethelightning for the link)
crea2k   10 kW
Post by crea2k » Jun 16 2014 7:56am
How many attempts at contact did it take before you could place your order ?. Iv got everything ordered / arrived for mine other than the controller, just waiting still for a 2nd reply so I can get this ordered.
upek   10 W
Post by upek » Jun 16 2014 7:58am
@GCinDC
Your regen was so strong not only because you set 34A battery but you also set maximum regen phase amps (see 24:07 on your video - 131A )
Post by ridethelightning » Jun 16 2014 8:08am
crea2k wrote:How many attempts at contact did it take before you could place your order ?. Iv got everything ordered / arrived for mine other than the controller, just waiting still for a 2nd reply so I can get this ordered.
mine took about 1 week to get the order sorted...i waited a while, then sent them another email asking for an update.
Post by ridethelightning » Jun 16 2014 8:17am
upek wrote:@GCinDC
i set my regen amps in the regen setup(not the phase amps in the power mode profiles)up real high and got some awesome braking power. because i was concerned itmay be too high charge rate for the battey, i toned it down, which was annoying cause it was great.
however, even though braking force was strong, the actual charge going to the battery according to the display was not exceeding max charge rate and was less then the set regen amps.
after toning down the settings to max20A in regen setup, i noticed much less braking force, but the max amps going to the battery as seen on the display during severe braking doesnt seem to be much less :?:
im tempted to just crank it up again. any clues guys?
wingsuit   100 W
Post by wingsuit » Jun 16 2014 4:02pm
trying to run through battery setups and just trying to confirm something.
I'm looking at going for hobbyking lifepo4 packs and am looking at this setup.
12 x 6s2p packs 4500mah, 19.8volt packs) wired to be 24s6p (basically a 79.2volt13.5ah pack)
the mini-e kit I order with bms is good to 28s according to the specs.
The part I'm trying to make sure I'm clear on is:
the hookups to the bms are in 4s blocks but that doesnt mean I have to use 4s batteries, just that the connections are done 4s per bms hookup correct? so I'd just have to wire my balance leads in proper order for the bms hookups.
are there any posts (havent found a search result thats put me in the right area) that describes how to hookup the balance leads from multiple batteries in a way to connect this type of battery setup to the bms on the mini? ie what gets wired in series vs parallel when connecting the balance leads together from all the batties to make the 4s connection leads to the bms.
madin88   100 MW
Post by madin88 » Jun 16 2014 7:41pm
wingsuit wrote: are there any posts (havent found a search result thats put me in the right area) that describes how to hookup the balance leads from multiple batteries in a way to connect this type of battery setup to the bms on the mini? ie what gets wired in series vs parallel when connecting the balance leads together from all the batties to make the 4s connection leads to the bms.
you have single 6s2p packs and want to wire them to 24s6p.
i would do it like this:
build two 12s6p packs with three 4s balance leads (5 wires per lead like the pins on the BMS). If you do so, you do not have to solder a wire bridge to the bms (the bridge will already be in the battery). imho this makes connection more easy.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
broke   100 W
Post by broke » Jun 16 2014 8:13pm
I thought you had to use 4 cell packs? with the bms
kona stinky - adaptto - HT3525 - https://endless-sphere.com/forums/viewt ... 4#p1005754
bikes owned:
new build LR kit dirt bag frame adaptto - rohloff
kona stinky adaptto ht3525
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
hill toper kit (first kit)
2 Sanyo ebikes from japan
2 cheap folding bikes with 36v settups
Mammalian04   100 kW
Post by Mammalian04 » Jun 17 2014 12:41am
Sheesh..... These guys are really bad about responding to email orders............... :shock:
I hope it isn't indicative of support should a problem arise but I am probably fooling myself into thinking otherwise. :oops:
Seya   10 W
Post by Seya » Jun 17 2014 1:06am
Yeah in Russia i don't think they understand how forums can make or break a product like this. Someone in California should ( Create something similar or better ) and sell it globally.. Tesla just open sourced their patents and I'm betting a lot can be applied to ebikes
Having said that, until it does.. I hope they become improve customer service..
madin88   100 MW
Post by madin88 » Jun 17 2014 1:10am
Im also waiting for a reply (want the BMS).
Adaptto needs to make an office and hire up a secretary as quickly as possible :lol:
crea2k   10 kW
Post by crea2k » Jun 17 2014 3:11am
Yes my build is going to be brought to a halt very soon if they don't get themselves into gear, as il soon have all the parts and still be waiting for the controller.
Post by ridethelightning » Jun 17 2014 8:28am
finally got the bms wired up correctly. working great. pretty ittle lights! :D
remarkably easy to configure really..
thanks for all the advice.
GCinDC   10 GW
Post by GCinDC » Jun 17 2014 8:46am
wingsuit wrote:I'm looking at going for hobbyking lifepo4 packs.... 12 x 6s2p packs 4500mah, 19.8volt packs) wired to be 24s6p (basically a 79.2volt13.5ah pack)
i actually think lifepo4 may be a strong move, but i highly recommend going with 4s packs to keep the wiring simple.
wingsuit wrote:how to hookup the balance leads from multiple batteries in a way to connect this type of battery setup to the bms on the mini?
for a 24s2p pack (of 4s batts), you'll need 6 of these: JST-XH Parallel Balance Lead 4S 250mm (2xJST-XH)
for 24s2p, create two rows, like this:
batt:batt:batt:batt:batt:batt:
and use the parallel balance leads to connect each column. then you can connect the big wires in series for each row... they don't really need to be paralleled for each subpack.
wingsuit   100 W
Post by wingsuit » Jun 17 2014 11:28am
thanks for the info. I had looked at 6s mainly because with a 24s6p I could get a 80v 15ah pack (roughly) and still fit in my phasor frame.
the trick with my frame is its 91mm wide, so while I found a decent 4s here:
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
its too wide to put side by side, so it makes it hard to fit 12 into the frame. and the ones that will fit side by side are only 4200mah 13.2v, taking it down to a 52v 15ah battery
I'm trying to find a way to make a pack thats roughly the same as the stealth bomber but not go to lipo.
the other hard part has been c rating. I'll find a limn that 72v 20ah but its only rated for a 2c continuous. I've only got the mini-e, but its still a 65amp controller .
I know a lot of people say with care you can make them safe, but I just have some liability stuff I cant get around.
broke   100 W
Post by broke » Jun 17 2014 3:32pm
Hay guys trying to figure out a power supp. Can you use something like this? or would a computer power supp. work?
http://honolulu.craigslist.org/oah/mat/4467032836.html
bikes owned:
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
Post by ridethelightning » Jun 17 2014 6:36pm
that would probably work, but it would take perhaps a week to charge!
look for aprox 48v ~ 30A
broke   100 W
Post by broke » Jun 17 2014 7:45pm
Pm sent
bikes owned:
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
