CHEAP NEW ORIGINAL 18650 BATTERY CELLS AND PACKS
ozon22   1 µW
Re: BRAND NEW CELLS 18650 SAMSUNG/SANYO/PANASONIC 3500mAh
Post by ozon22 » Feb 17 2016 11:39pm
will you ship to Canada?
cwah   10 GW
10 GW
Post by cwah » Feb 18 2016 3:51am
Any cycling data?
Help me find my stolen electric brompton: http://bit.ly/1a0vbBC and Bosch Sinus B3 http://bit.ly/1eV0WQz
Offroader   100 MW
Post by Offroader » Feb 19 2016 11:28pm
I got 3350 MAH (capacity test only) with the Sanyo cells at 1 amp. Which is around what others got at 1 amp, and basically meets the cell capacity specification. Cells have July 2015 date I believe.
I had to actually make sure to cycle the battery at around 25C, because below this temp you will get noticeably lower capacity. My basement is around 14C in the winter so I had to improvise to cycle the cell at 25C.
I also had to make sure to get the cell to exactly 4.200 volts before discharge.
vsop   1 µW
Post by vsop » Feb 21 2016 5:25pm
Im returning customer - cells are great and the prices beautiful. I already recelled 3 of my Bosch Classic bateries from 288WH to 500. Everything works fine.
vsop   1 µW
Post by vsop » Feb 21 2016 5:26pm
VicDiver   1 µW
Post by VicDiver » Feb 25 2016 10:52pm
Pm sent looking for around 150 cells to start and another 300 after shipped to Canada
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 25 2016 10:56pm
vsop wrote:Image
Do you have a source or name for those cell holders?
They are perfect for putting the cells as close together as possible. :)
Cheers
My stuff:
Cowardlyducks - Videos - Ride videos
For Sale:
Custom made 18650/21700 battery packs - Australia only
tumich   100 W
Post by tumich » Feb 26 2016 1:01am
There are holders which are inside Bosch PowerPack's.
My ebikes:
1. Sur ron
Cheap, new, oryginal li-ion cells 18650 up to 3500mAh --> viewtopic.php?f=31&t=61608
markz   100 GW
Post by markz » Feb 26 2016 2:00pm
tumich wrote:There are holders which are inside Bosch PowerPack's.
BINGO, I guessed right in my previous post! Someone asked, I threw out my guess, went unanswered, asked again and answered.
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 26 2016 10:43pm
Thanks for the info.
That sucks they are Bosch only. I would have like to use some of them for my builds.
Oh well...a minute amount of weight savings without them at least. :)
Cheers
My stuff:
For Sale:
ridethelightning   1 MW
Post by ridethelightning » Mar 01 2016 9:49pm
220 LG mg1 cells, arrived sept14, been running solid ever since, still going strong!
thanks again tumich!
DasDouble   100 kW
Post by DasDouble » Mar 08 2016 6:56pm
pm send.
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
markz   100 GW
Post by markz » Mar 08 2016 7:15pm
My birthday is coming, and I need something more then 60V and 8 to 9Ah of battery pack. Summer is coming, seems like a perfect time to splurge on some 3.5Ah GA's.
Whats the transit time on these batteries again, to North America? Lets say BC, AB or West coast of USA.
DasDouble   100 kW
Post by DasDouble » Mar 09 2016 5:33am
A Guy told me that the cells wouldnt work correctly for high voltage like 74 Volts, 20Ah, 22s. What do you guys think? Want to buy the Sanyo ones because people here say they are as good as Panasonic. :roll:
-Built own ebike: ✔
up0   10 mW
Post by up0 » Mar 09 2016 5:52am
I am sorry you have to listen to a "Guy" that tells you that kind of non-sense ;-)
Better not to listen to him any more, because the statement in itself is ridiculous:
The individual cell in the chain knows nothing about the total Voltage of the pack.
Each of them just sees their own 3.7-4.2V
You can put as many as you like in a series - with any type of cells.
Read here: https://en.wikipedia.org/wiki/Sanyo
"On December 21, 2009, Panasonic completed a 400 billion yen ($4.5 billion) acquisition of a 50.2% stake in Sanyo, making Sanyo a subsidiary of Panasonic."
Also read Here: https://www.electricbike.com/18650-cells-for-e-bike/
and look for : '' What happened to Sanyo? "
Cheers, Ulli
Hummina Shadeeba   10 MW
Post by Hummina Shadeeba » Mar 09 2016 12:47pm
im not trying to promote the idea that the cells cant do such high voltage but wouldnt each cell in series add its voltage to the next so that the final cell would experience the high voltage?
opperpanter   100 W
Post by opperpanter » Mar 09 2016 1:18pm
Hummina Shadeeba wrote:im not trying to promote the idea that the cells cant do such high voltage but wouldnt each cell in series add its voltage to the next so that the final cell would experience the high voltage?
No, it's all relative.
up0   10 mW
Post by up0 » Mar 09 2016 2:07pm
I looked for one of these "Water Analogy" pictures to illustrate, but couldn't find anything suitable.
So I modified one I found on the web.
New additions on the left of the water-tower:
I hope it is self-explaining?
Darn it - of course right after posting this, I found a ready-made picture that fits:
Ulli
Post by Hummina Shadeeba » Mar 09 2016 2:24pm
wouldnt it go from 12 volts, to 24, then 36 ...etc?
up0   10 mW
Post by up0 » Mar 09 2016 3:18pm
I was trying to stress the point that each battery only "LIFTS" the water by "12V".
Of course the potential of the water is getting higher and higher (24,36...)
But the individual battery doesn't care.
You can also think of it like a series or little locks that block water:
Each small lock only has to withstand the "pressure" of 12V.
Each of these locks does not care at all that there is another lock above or below it.
But if you run a pipe from the highest point down to the lowest, it will see the FULL pressure of all accumulated heights.
Ulli
Post by Hummina Shadeeba » Mar 09 2016 3:21pm
I see. While in series the voltages add up but each battery only has a voltage difference of 12 volts that it will experience.
markz   100 GW
Post by markz » Mar 09 2016 3:36pm
DasDouble wrote:A Guy told me that the cells wouldnt work correctly for high voltage like 74 Volts, 20Ah, 22s. What do you guys think? Want to buy the Sanyo ones because people here say they are as good as Panasonic. :roll:
Voltage does not matter, its the discharge you need to pay close attention to, I believe both these current batteries are 8 to 10A of discharge. Unlike a 25R battery which is much much more then that. Keep in mind however that the more battery strings you put in parallel, the higher your discharge can be and obviously the higher your Ah.
Simple example using 3.3V nominal, 3.5Ah and 10Amax discharge batteries.
#series and 2 parallel, whatever voltage and 20Amax discharge at 7Ah.
1S-10P then you have nominal voltage of 3.3V and 100Amax discharge at 35Ah.
10S10P is 33Vnominal and 35Ah at 100Amax discharge
30S30P is 99V, 105Ah and 300Amax discharge.
*So you buy/build a pack in terms of VOLTAGE to suit your controller, and/or speed you want. This is the series part, 1S, 10S, 30S. Then you want a certain Ah for the distance you want to travel, this is the parallel part or P in the numbers given. 1S10P, 10S10P, 30S30P. Discharge is yet another factor. Too low a discharge battery and you will burn the batteries up, going up hills, too heavy a load on bike, etc etc etc.
Voltage is added in series. Ah is added in parallel.
I struggled with the discharge aspect myself, but you add it just like Ah in parallel. So if you have 3.5Ah batteries as my examples are, for the current battery Tumich is selling.....then 10S and 10P would indicate 33Vnominal for 3.3Vnominal batteries, 35Ah (3.5Ah for each battery times 10) and a discharge of 100Amax, because the batteries are rated for 10Amax discharge. These are just examples, if your batteries are different then substitute in different numbers. I will summarize again.
Voltage is added in series, and disregarded in parallel. 10S10P you go 3.3Vnominal x 10 = 33Vnominal pack.
Ah is added in parallel, disregard series. So 10P would be = Ah of battery times 10. 3.5Ah x 10 = 35Ah.
Example given: 33Vnominal 35Ah pack.
Discharge is similar to Ah in formual/calcuation. If you have 10S10P of 10Amax discharge batter
Example given: 33Vnom. 35Ah and 100Amax discharge.
Post by Hummina Shadeeba » Mar 09 2016 3:47pm
I wonder about "burst" max. Rarely do I see it posted by manufacturers and doesn't seem to be a standard test. The best info I've found is that as long as the cells aren't getting too hot (how hot is too hot?) they will just experience voltage sag and less capacity. If that's the case no problem but at some point a high or long burst equates to "damage" with less capacity with further charging and maybe they will shut down and not produce any current
can you generalize about what the burst would be based on he continuous max?
up0   10 mW
Post by up0 » Mar 09 2016 4:22pm
Guys, please don't invent new and confusing terms for existing terms:
"DISCHARGE" is a very misleading term for what is really "Current" (measured in Ampere)!
If you read the Wikipedia page on CURRENT: https://en.wikipedia.org/wiki/Electric_current
you will not find the word 'discharge' used anywhere on the page!
When I read "discharge" I immediately think of https://en.wikipedia.org/wiki/Electric_discharge : Sparcs and electric Arcs!
Same with "BURST" :
Of course you don't see it posted, because it is no standardized term.
@Hummina: I suggest that you go back to your physics text-book from school or find some Youtube videos on Electricity basics.
I really don't mean that as an insult, but as an honest and friendly advice!
This is a post about 18650 Cells, and not really the place to explain the very basics of electricity.
Thanks for understanding,
Ulli
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 09 2016 4:40pm
up0 wrote:Guys, please don't invent new and confusing terms for existing terms:
Same with "BURST" :
Ulli
Well almost everywhere you see 18650 cells or Lipo or Lifepo4 you will see some reference to C value. High C value means battery can discharge fast, and in real life that means you can dump an ton of amp into controller and motor very fast. That will be important for fast acceleration.
