CHEAP NEW ORIGINAL 18650 BATTERY CELLS AND PACKS
riba2233   1 MW
Re: BRAND NEW CELLS 18650 LG 2850mAh 2,49$ EACH! 99$-11Ah/36
Post by riba2233 » Nov 05 2014 3:28pm
In that case you need 10C batteries, which are samsung 25r and 20r, sony vtcr and vtc4, and lg he2. I prefer samsung 25r.
You only need to connect balance wires to the parallel group of batteries, because they always have the same voltage, and you should think of them as a one larger cell.
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
tumich   100 W
Post by tumich » Nov 15 2014 5:31am
My ebikes:
1. Sur ron
Cheap, new, oryginal li-ion cells 18650 up to 3500mAh --> viewtopic.php?f=31&t=61608
tumich   100 W
Post by tumich » Nov 24 2014 11:38am
New delivery.
My ebikes:
1. Sur ron
Nobuo   10 kW
Post by Nobuo » Nov 25 2014 4:00am
HI! I'm almost decided to buy those LG cells! For that price its the only thing I could afford.. :roll:
But I can't find some very important information as max Cycles Life, life expectancy in years, max Amps discharge..
I wanted to buy the panasonic ncr18650PF in NKON, because the price.. and they are very famous as I see, for durability one of the best cells in the market.
http://www.nkon.nl/rechargeable/18650-s ... 00mah.html
So what do you recommend?
(I will present myself soon along with my ebike project :))
Greetings from Spain
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
tumich   100 W
Post by tumich » Nov 25 2014 4:47am
Cycles life should be ~1000 as in all li-ion cells. Producent wrote that max discharge is 10A.
Panasonic 's reach higher capacities from LG at higher loads. It depends on what you use the discharge currents and how many cells will be made package . If you have a package made ​​from a large number of cells currents will decompose into individual cells so there won't be much difference between Panasonic 's . Above you can see a graph of the discharge cells LG and Panasonic 's .
My ebikes:
1. Sur ron
Nobuo   10 kW
Post by Nobuo » Nov 26 2014 5:42am
Thank you! I guess I have no reason to not buy them :)
Would be so diffcicult to remove all the welded nickel pieces?
Because I want to configure in a different way and weld again
tumich   100 W
Post by tumich » Nov 26 2014 2:18pm
If you do it before it's no problem. Need a tactic :) Also you don't need remove all, you can cut weld near cell. I have cells packs with 100% welded and 50% or less. You can choose less welded so will less to remove. I have 1 pack (40 cells) with all welds removed. More on priw.
My ebikes:
1. Sur ron
silviasol   10 kW
Post by silviasol » Nov 26 2014 4:01pm
Are all the cells at a 3.8v storage voltage?
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
jimwebo   1 W
1 W
Post by jimwebo » Nov 26 2014 6:07pm
Hello, I received 110 cells and all at 3.57v.
At the moment everything seems right.
Thanks for a smooth deal.
Por cierto Nobuo,saludos de un compatriota de Asturias.
Electric life.
tumich   100 W
Post by tumich » Nov 26 2014 6:55pm
silviasol wrote:Are all the cells at a 3.8v storage voltage?
All cells are 3,6V +-0,05V (fabric voltage).
My ebikes:
1. Sur ron
dbaker   100 kW
Post by dbaker » Dec 06 2014 9:48am
Can you ship to USA?
999zip999   100 GW
Post by 999zip999 » Dec 06 2014 2:31pm
Can the 36v 11ah pack deliver 40 amps safely ?
tumich   100 W
Post by tumich » Dec 07 2014 6:30am
dbaker wrote:Can you ship to USA?
Yes. More on priw.
999zip999 wrote:Can the 36v 11ah pack deliver 40 amps safely ?
It's like 10A on 1 cells. It's too much.
My ebikes:
1. Sur ron
Nobuo   10 kW
Post by Nobuo » Dec 10 2014 3:46pm
I've just recived 200 cells from Michal :)
It arrived to my home the best well packed items I've ever seen so far :shock:
Just a week to arrive to Madrid. Everything just perfect.
I will report cells voltage soon.
Some pics of what I recived.
ridethelightning   1 MW
Post by ridethelightning » Dec 10 2014 3:53pm
nice!
still waiting for mine, is on the slowboat and cant track it.
the post office said it could take 2 months to get to aus.
tumich   100 W
Post by tumich » Dec 10 2014 5:46pm
ridethelightning wrote:nice!
I would like that You get it before Christmas.. Shipping economy to Australia takes so long :/
My ebikes:
1. Sur ron
Post by ridethelightning » Dec 10 2014 8:48pm
cheers tumich.
im hoping so too,
the postage was so cheap so i dont mind so much. possibly the cheapest lithium battery shipping iv ever seen :D
my bikes not quite ready for the cells yet anyway..
andrius0   1 µW
Post by andrius0 » Dec 18 2014 4:25pm
Just a quick feedback - received 120 LG cells few days ago. Everything went really smooth, the cells got delivered in around a week, the packaging was probably the best I've seen. All the cells are around 3.6V as promised, exact marking on mine is LGDBMG11865.
Thanks for a great deal. For anyone still undecided - can really recommend.
dbaker   100 kW
Post by dbaker » Dec 18 2014 4:30pm
tumich   100 W
Post by tumich » Dec 20 2014 4:15am
Yes.
My ebikes:
1. Sur ron
Post by ridethelightning » Dec 22 2014 2:39am
200 cells arrived today.
thanks tumich!
well packed (more or less the same as the pics above)
jimwebo   1 W
1 W
Post by jimwebo » Dec 22 2014 11:34am
Hello.
Panasonic need 40 cells.
Are available?
If so, tell me the price with cheap shipping to Spain.
best regards.
Electric life.
Jazzman56   100 mW
Post by Jazzman56 » Dec 23 2014 2:51am
Hi Guys,
I'm looking at the LG Cells in a 14s 6p config to power a BBs02. How much current can i safely draw continuously / peak from these LG Cells --> i can't seem to find a reliable data sheet :/
*/DATA --> 6p/5p current loading per cell in a 14s pack /*
Cell Loading 6p
Continuous
750w / 48v (nominal voltage ish) = 15.625amps --> for an individual cell (6p config) = (15.625 / 6) -->2.6amps
Peak
1400 /48v = 29.16667 amps --> for an individual cell (6p config) = (29.166667 / 6) --> 4.8611amps
Low end V at Peak load (is this a realistic issue ??)
1400/42 (14 * 3v --> low V cut off) = 33.3amps --> for an individual cell (6p config) = (33.333/6) --> 5.555amps
Cell Loading 5p
Continuous = (15.625 / 5) --> 3.125amps
Peak = (29.166667 / 5) --> 5.8333amps
Low V at Peak Load = (33.333/5) --> 6.6666 amps
Regards,
Jazzman56
mlt34   100 kW
Post by mlt34 » Dec 23 2014 3:56pm
Jazzman56 wrote:Hi Guys,
Cell Loading 6p
Continuous
Peak
Cell Loading 5p
Regards,
Jazzman56
According to this page: http://detail.1688.com/offer/38078378051.html (use google translate) the max discharge for each cell is 10A, so just under 4C. I am pretty sure that is peak discharge, not constant. I wouldn't go above about 2.5C constant discharge on these just to be safe. They'll probably do more, but you'll shorten the life of the cells.
Are you planning your first electric bicycle conversion? I wrote a book that teaches beginners everything they need to know about building their own ebike.
Then I wrote the book (literally) on building custom lithium batteries.
I also write for EbikeSchool.com, a site that does mainly how-to style articles and other informational write-ups. Check out our youtube channel for great how-to battery building videos.
Lastly, I run www.Vruzend.com, which sells solderless 18650 battery kits, 18650 cells, li-ion chargers, BMSs and more!
mlt34   100 kW
Post by mlt34 » Dec 23 2014 3:59pm
Got my 80 cells and just like everyone said they were packaged great! What an awesome source for cheap, brand new cells. I'm going to wire the two packs as 20s, add a BMS and wham bam got me a 72V 11.6AH pack for cheap :-)
