CHEAP NEW ORIGINAL 18650 BATTERY CELLS AND PACKS
Kin   10 kW
Re: CHEAP ORYGINAL CELLS 18650 and welded packs for 36V
Post by Kin » May 14 2017 11:07pm
tumich wrote:
rojitor wrote:My question is legit.
But the second picture looks wired
Just 1 pack have cable :)
Oh! I never noticed. Tumich, I am not certain what your response means. Is this for all of these type of 10s5p packs? Or just the one pictured?
New to endless-sphere? Notice a lot of signatures recommending Ebikes.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
banjaxxed   10 mW
Post by banjaxxed » May 15 2017 2:31pm
tumich wrote:Hello,
I have 18650 Li-ion cells for sell, they are BRAND NEW, LEGAL, ORYGINAL, NEVER BEEN USED.
All cells have nominal, fabrical voltage usually 3,6V or ~3,7V.
Li-Ion cells are the most safest, lighter and more life cycles up to 2-3x than LiPO.
If you would like buy - msg me by private message.
Cells are located in Europe. No fees to EU countries.
SHIPPING TO WORLDWIDE BY COURIER AND BY POST.
Price is cheaper than from China.
All cells have real capacity!
Cheap shipping is possible!
I accepting PayPal and bank transfers in USD/EURO.
For shipping cost msg me by priv message.
Minimum quantity order: 40 cells.
LG MG1 (config 10S4P/36V, 14Ah/400Wh) - full welded - 2,99$/each cell (119,6$ for pack)
LG MJ1 - 3500mAh/10A - (config 10S5P/36V__7,5Ah/625Wh) full welded - 3,49$/each cell (174,5$ for pack)
Hi I would like 64 of the LG MJ1 please
rojitor   100 kW
Post by rojitor » May 15 2017 3:37pm
Pm him if you want to buy a pack.
gamerpaddy   1 µW
Post by gamerpaddy » May 15 2017 6:25pm
cerberpeter wrote:Has anyone tried to disassemble one of those already welded packs? It seems like almost impossible - the nickel is very thick and it is deforming the shape of the cell if I even manage to pull it off. It even left a hole on one cell, so I ended up using dremel tool... Another issue is - the cells are glued with some kind of strong epoxy and is impossible to separate them apart without tearing the insulation down. It is nothing like the laptop batteries :lol:
i had to take apart he samunsg 29E pack, very solid welds.
after a 1 hour, some "oh shit oh shit oh shit" moments and a few blisters on my hand later, 9 of 50 cells i put a hole in the bottom by ripping off the tabs.
some pressure escaped and i closed to hole by a blob of solder. no idea if that damaged the cell, test went fine no difference to the other cells after a few cycles.
some cells still have the tabs on the bottom and top, just trimmed to be as small as possibe. i went with soldering those cells into a new pack rather than spot welding.
###############################Signature##############################
i successfully reverse engineered the Yamaha DriveUnit Battery Protocol http://goo.gl/R1RWAc
>Haibike SDURO Hardnine SL 400Wh + 600Wh + SB SpeedBox
cerberpeter   10 mW
Post by cerberpeter » May 15 2017 6:49pm
I see, so it is not only the Sony KONION pack that strong. The only way of removing the tabs that I found is by filing down the spots on the nickel deep enough so the whole strip gets almost dismantled off the cells by using dremel tool or even angle grinder (with risk of damaging some cells, but a lot faster). With the Sony pack, the cells can not be unglued without ruining the insulation tubing...
Dr.Electric   1 mW
Post by Dr.Electric » May 25 2017 7:41am
Just received 3 packs of samsung 35E 10s4p.
The packs are clearly factory made and robot welded.
There are some smal copper wires welded to the battery terminals so it is very easy to solder BMS and complete the battery.
I´m done with soldering battery packages and will buy theese from now on !
After seeing the package i strongly recommend not to remove the weldings. Its probably better to cut the nikkel strips over and seperate the package in 4P bricks.
I warmly recommend this product !
sacko   10 kW
Post by sacko » May 25 2017 3:28pm
I am a bit late to the party, and have currently read 8 pages in so far,
I have only used lipo in the past, and now moving to 18650.
Out of the cells available in this post, which are the best ones to buy?
Takemehome   1 kW
Post by Takemehome » May 25 2017 7:53pm
sacko wrote:......Out of the cells available in this post, which are the best ones to buy?
The ones that are available right now. :P
Don't dream your life, live your dream.
Don't buy anything before visiting http://ebikes.ca
Justin, Thank you.
Ptit_Philou   10 mW
Post by Ptit_Philou » May 26 2017 2:43am
Panasonic Sanyo 18650GA 3500 mAh are among the best cells right now...
LG MJ1 are good too.
e-Scooter Matra e-MO+ (Eaton) + battery 15 Ah
Ddt   100 mW
Post by Ddt » May 26 2017 7:21pm
Do you have stand alone battery?
Ptit_Philou   10 mW
Post by Ptit_Philou » May 27 2017 2:30am
Tumich answers only to private messages.
He sells only products in post 1, and products vary according to stocks.
Check www.nkon.eu for standalone cells...
barbs00   100 W
Post by barbs00 » Jun 02 2017 5:15am
Umm..my PM to Tumich is just sitting in the outbox????
rojitor   100 kW
Post by rojitor » Jun 02 2017 5:31am
He is a busy person. Always answers but you have to wait for a few days. Be patient.
barbs00   100 W
Post by barbs00 » Jun 02 2017 5:54am
Thanks for your reply - All good with waiting but am not sure if he has got the msg as it says it is sitting in my outbox and not in sent folder?
A quirk of this site?
rojitor   100 kW
Post by rojitor » Jun 02 2017 6:10am
Your msg will be there Until he logs in.
barbs00   100 W
Post by barbs00 » Jun 02 2017 6:23am
ah ok - thank you!
barbs00   100 W
Post by barbs00 » Jun 05 2017 6:56pm
Has anyone had any success separating them out to say 4P bricks?
EddySPalm   10 W
Post by EddySPalm » Jun 06 2017 2:51am
I just received a bunch of cells from tumich, and I must say they look brand new (as he promises) and is very neatly packed.
Yes he is a slow replier at times, which is frustrating, but he delivers eventually!
Ptit_Philou   10 mW
Post by Ptit_Philou » Jun 06 2017 3:26am
barbs00 wrote:Has anyone had any success separating them out to say 4P bricks?
It's almost impossible to disassemble cleanly spot-welded batteries, especially if glued.
You can use Dremel tool to cut off nickel strips and a hairdryer to melt glue but you have lot of chances to damage cells or at least the tubular plastic protection.
Nickel strips are very sharp and you may easyly have short circuits by ripping the plastic skin...
I disassembled a used Samsung 22F pack (Tranz-X BL07 for Matra TX AGT) with a lot of difficulties and I killed 3 batteries (started to burn !).
The batteries have a lot of metal parts remaining on both ends which is not good for spot welding or any other uses...
If you search for individual cells, you'd better buy on http://www.nkon.eu or other shops.
barbs00   100 W
Post by barbs00 » Jun 06 2017 5:11am
Thanks for the reply.
I was thinking of cutting the nickel and black plastic into 4P bricks so I could make a 52v battery but after your post I am now thinking this is too hard.
Have you had success buying from NKON?
Ptit_Philou   10 mW
Post by Ptit_Philou » Jun 06 2017 5:28am
Sure, disassembling batteries can be very dangerous : I do not recommand to do this.
NKON is a well known store in Europe : fast and serious :-)
No problems with 4 orders (tracking) and verry correct prices.
According to your location, you may find other good stores but this one is reliable.
barbs00   100 W
Post by barbs00 » Jun 07 2017 3:36am
Cool, do you know any reputable stores in Australia or even China?
rojitor   100 kW
Post by rojitor » Jun 07 2017 3:51am
Now that I think about this maybe it is unapropriate advertising another seller in a sales thread. My purpose is to help you but maybe not like this. I will pm you with the link.
barbs00   100 W
Post by barbs00 » Jun 07 2017 4:10am
Thanks - I have just sent an email
tumich   100 W
Post by tumich » Jun 07 2017 5:44pm
Lower prices. Also some packs are welded just on 1 side - faster to remove welds :)
My ebikes:
1. Sur ron
Cheap, new, oryginal li-ion cells 18650 up to 3500mAh --> viewtopic.php?f=31&t=61608
