CHEAP NEW ORIGINAL 18650 BATTERY CELLS AND PACKS
Ddt   100 mW
Re: CHEAP ORYGINAL CELLS 18650 and welded packs for 36V
Post by Ddt » Jun 17 2017 5:39pm
Hello someone know the size of the new battery pack?
pianoman   10 mW
Post by pianoman » Jul 02 2017 12:10am
Hi,
Can anyone post a pic of Sony Konion 10s7p pack?
4,5kw 65kmh Vector frame/Crown TC80/17x2.75" Shinko 241/Lyen 24fet 4110/22s2p vtc5+22s3p v3
1,5kw 50kmh Votek V.sx enduro dual susp/Bafang BBSHD/14s4p Panasonic GA
1kw 50kmh Trek 4300 hardtail/Bafang BBS02/12s6p A123
2,2kw 32kmh Mibo Tiny Top 12" kick scooter/2WD rear DD front geared hub motor/infineon 12 and 6 fet/A123 lifepo4 12s6p
1,5kw 43kmh Mibo Mastr Top 16" kick scooter/Mac 10t rear motor/infineon 12fet/SonyV3 22s3p
Gotway MCM4 HS electric unicycle,stock
mxer   1 kW
Post by mxer » Jul 02 2017 10:12am
Can someone explain why it is dangerous to remove welded tabs from cells? What can happen?
Ptit_Philou   10 mW
Post by Ptit_Philou » Jul 02 2017 11:08am
Short circuit, fire, explosion, house burnt and... Death... :-)
e-Scooter Matra e-MO+ (Eaton) + battery 15 Ah
Takemehome   1 kW
Post by Takemehome » Jul 02 2017 6:57pm
pianoman wrote:Hi,
Just open the image link on first page in a new tab
Don't dream your life, live your dream.
Don't buy anything before visiting http://ebikes.ca
Justin, Thank you.
Ptit_Philou   10 mW
Post by Ptit_Philou » Jul 03 2017 3:07am
"Just open the image link on first page in a new tab"
> Images links dead on first page...
mxer wrote:Can someone explain why it is dangerous to remove welded tabs from cells? What can happen?
Ask NASA ! :D
Kin   10 kW
Post by Kin » Jul 03 2017 1:36pm
Here is a possibly more thorough answer:
A properly welded tab will have meaningful metallurgic bonds to the metal on the 18650 housing. This means you cannot remove them without damaging the bottom surface, at which point you can risk a puncture that lights the pack on fire (usually not so fast as the image shown, that was probably a specific destructive test.)
realistically, the majority of packs welded for laptops do not have sufficient strength to damage the 18650 shell, although my understanding is Tumich's packs are welded together with stronger bonds and are harder to remove. (because meant for higher current and more rigorous environments than laptop cells)
Ideally you can just cut the tabs you need to cut, and spot weld or solder to the nickel instead of trying to remove a well bonded nickel strip from the cell.
New to endless-sphere? Notice a lot of signatures recommending Ebikes.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
mxer   1 kW
Post by mxer » Jul 03 2017 3:27pm
Thank you for the explanation. So the danger is puncturing the cell, Thank you..
I never knew these cells are so volatile, gawd I'm sticking with lipo for the minute, I've never had any issues what so ever in the 6 years daily I've been using them.
Not that I ever would!.
But I've seen and read, people using two bits of wood in a vice and a pin to remove puffy cells on lipo, just goes to show?
The more and more I read on 18650 the more and more I dislike the technology, but I can't help being drwn to the rewards and challenges of building my own pack. Perhaps it's the complicated challenging satisfaction of success? I do like the impossible and challenges in life
Ptit_Philou   10 mW
Post by Ptit_Philou » Jul 03 2017 4:08pm
Picture cames from NASA RoboSimian which exploded while charging...
https://www.wired.com/2016/10/samsung-i ... -ask-nasa/
Despite of this, good 18650 batteries are very reliable and you can find a lot of tutorials about building packs on this forum, on electricbike blog, or on YouTube...
I saved my Matra e-Mo /Eaton EV3 scooter and a ebike with my spot welder machine :-)
Kin   10 kW
Post by Kin » Jul 03 2017 4:11pm
mxer wrote:Thank you for the explanation. So the danger is puncturing the cell, Thank you..
Uhm, I'm sorry - but FYI lipo is much more violatile than these cells are, simply due to lack of any casing, hence why I didn't think Ptit's response was very good. Edit FYI I see Ptit actually responded with a followup clarifying a bit. Sorry I missed that. 18650 cells require some background knowledge but are much harder to screw up than Lipos (the only exception might be if the fact that they're harder to screw up makes you think you *cant* screw them up, since that would be folly to think.))
Kin   10 kW
Post by Kin » Jul 03 2017 4:17pm
So, uhh, keep reading about 18650 cells, if you do want to make your own pack. If you feel they are more dangerous than lipo you might want to keep reading. I am not making my own pack again because once done I realized it was a PITA of work (especially starting from a base of used laptop cells and sorting/grading them painstakingly.)
Also it is a little jumbled to call the cell formats "18650" vs "LiPo.' Someone who knows more could clarify, but my understanding is LiPo just refers to the fact they're pouch cells (with polymer insulator.) 18650 is the 18mm diameter 65mm length metal casing. The insulator is different I believe in both cases, but the fact one is one or the other doesn't tell you so much. Some 18650s are terrible hazards, others are not.
Compare 1st gen lipo to modern lipo. 1st gen lipo is when things *really* lit on fire all the time. Still possible now, but less egregiously. And 18650 cells can be a variety of chemistry, not just LiCo. Soo err, yeah.
Takemehome   1 kW
Post by Takemehome » Jul 03 2017 8:05pm
Ptit_Philou wrote:"Just open the image link on first page in a new tab"
You did not click on it because it works for me.
Do not mind the message Right click and open in new tab.
Justin, Thank you.
Ptit_Philou   10 mW
Post by Ptit_Philou » Jul 04 2017 2:53am
First, my whole nickname is "Ptit Philou" :)
(contraction of "Petit" that means "little" in french and "Philou" for "Philippe")
And I agree that LiPos are more fragile than 18650 format batteries : 18650 seem hard to "explode" and it may happens especially when charging or with short circuits.
Most electrical vehicules use 18650 batteries (Tesla cars, ebikes, scooters...) because it's reliable, cheap, and easy to pack with spot welder.
Just use good products from Panasonic/Sanyo, LG, or Samsung to avoid fake/dangerous batteries...
For information, if Adobe Flash Player plugin in Firefox is not up to date, this causes warning messages to appear, instead of images in forum...
Kin   10 kW
Post by Kin » Jul 24 2017 10:21am
8 weeks delivery, as expected (6-8 weeks) but my cells did arrive beautifully packaged and in great condition :). capacity untested so far, but will sometime.
bobmutch   100 W
Post by bobmutch » Jul 25 2017 10:51pm
can you ship to Canada?
my ride Fuji 72V20Ah LiPo, CA3, 18F MC, 1500W Rear Hub. I'm here to learn.
Ptit_Philou   10 mW
Post by Ptit_Philou » Jul 26 2017 2:17am
Post 1 :
"Cells are located in Europe. No fees to EU countries.
SHIPPING TO WORLDWIDE BY COURIER AND BY POST."
Takemehome   1 kW
Post by Takemehome » Aug 06 2017 8:01pm
Very nice pack but check the spot welds, there are misfires.
Check by sliding a small sheet of paper under the welds.
Otherwise, very nice pack for the price. Would buy again.
Justin, Thank you.
droospoos   1 µW
Post by droospoos » Aug 25 2017 2:27am
Hi!
Does someone know if I can still order some NCR18650GA cells from Tumich?
I need 42 of them.
What is the price per cell?
Thanks
Ptit_Philou   10 mW
Post by Ptit_Philou » Aug 25 2017 3:09am
See post 1 : Tumich sells only packs right now...
tumich   100 W
Post by tumich » Aug 29 2017 8:09am
I have cells in bulk right now: Sanyo Ga, LG MG1.
My ebikes:
1. Sur ron
Cheap, new, oryginal li-ion cells 18650, 21700 up to 5000mAh --> https://endless-sphere.com/forums/viewt ... 31&t=61608
jimwebo   1 W
1 W
Post by jimwebo » Aug 29 2017 8:29am
Great seller gentlemen.
Totally reliable and communicative.
A few thousand cells bought it and zero problems.
Greetings.
Jim
Electric life.
qwerkus   10 kW
Post by qwerkus » Aug 31 2017 6:00pm
tumich wrote:I have cells in bulk right now: Sanyo Ga, LG MG1.
So you do sell bulk, or only packs ?
DVDRW   100 W
Post by DVDRW » Sep 01 2017 11:28pm
I'm excited too :)
sevillano1982   100 µW
100 µW
Re: CHEAP ORYGINAL CELLS 18650 3500mAh
Post by sevillano1982 » Sep 16 2017 7:51pm
Hello friend.
I speak few english. Excuse me.
Have you cell lg 2850mah or panasonic 2900mah or alternative it?
Thank you much
brumbrum   100 kW
Post by brumbrum » Oct 08 2017 2:47pm
Subd
