FUTR frames, Adaptto Controllers, Eaton Chargers, batteries
TheDougB52 Bomber   100 µW
100 µW
Re: Adaptto Controllers, Eaton Chargers, battery packs
Post by TheDougB52 Bomber » May 03 2016 5:42pm
I know there's lots of talk about motors out there is the MXUS3000 a dependable motor that's can take a lot of abuse, has this motor been around a wile.Will i get the same speed I have now on flat roads.Also will the wiring be the same and plug into the bikes connections. your right about the forks i'm going for the Marzocchi 888 RC3 Evo unlesss there's a better choice out there.
100 µW
Post by TheDougB52 Bomber » May 03 2016 5:46pm
TheDougB52 Bomber wrote:I know there's lots of talk about motors out there is the MXUS3000 a dependable motor that's can take a lot of abuse, has this motor been around a wile.Will i get the same speed I have now on flat roads.Also will the wiring be the same and plug into the bikes connections. your right about the forks i'm going for the Marzocchi 888 RC3 Evo unlesss there's a better choice out there.
Allex   1 GW
1 GW
Post by Allex » May 04 2016 1:47pm
Not sure about the speed, if 4t does not get you there then maybe you need to go with 3t. Better ask teslanv, he cells them so he knows.
It is the most popular motor here in ES so sure it has been tested, even the pros around here ditched all motors in favor of mxus.
You will have to change all the connectros to make it fit.
888 is a very good choice.
Allex   1 GW
1 GW
Post by Allex » May 04 2016 1:48pm
I dig this flat battery I made for a scooter, those holders makes it look pro!
DSC07164 kopia (kopia).JPG (109.58 KiB) Viewed 2486 times
multifrag   10 W
Post by multifrag » May 06 2016 7:12pm
What charging coil should I use for 90V 45Ah?
Allex   1 GW
1 GW
Post by Allex » May 07 2016 2:23am
45Ah should be charged at about half of the capacity so 22Amps. 30A Coil would be ok for that. If you want to fast charge at 1C=45A take the bigger one, but you need to have a PSU that can produce 45A
mudale222   10 W
Post by mudale222 » May 09 2016 7:18am
hey Allex, i searched, but didn't find an official answer.
What is the real life continues power that the MaxE can do? can it take 8kw like the Sabvoton 72150 in this clip?
[youtube]https://youtu.be/H92IUE7VpTg[/youtube]
SUNDRIVE   10 W
Post by SUNDRIVE » May 11 2016 9:26am
Hey Allex,
Wiring in the Hall sensor connector for my recently purchased Max E from Envolt I was suprised to see it was a six pin unit instead of the 7 pin connector that came with the Mini-E. I checked the diagram onthe website and found how the pins are numbered, then looked in the manual to check which circuits go to which wires. BUT.... it seems when I opened the connector at the Adaptto end it was different to the table in the manual! According to the manual: Yellow connects to 1), Green connects to 2), and Blue connects to 3). According to the pins on the connector Blue is connected to 1), Yellow is connected to 2) and Green is connected to 3).
Question is, do I go with the manual, or with the colours observed in the actual connector attached to the Max-E ? Will it make any difference, or does the autodetect put hall sensors in right sequence?
Why do some have 6 Pin some have 7 Pin? That must make it difficult to swap controllers unless you know what connectors the unit has. Was it related to build date or controller model?
6 Pin Hall connector diagram.JPG (72.4 KiB) Viewed 1051 times
Allex   1 GW
1 GW
Post by Allex » May 12 2016 2:32am
Mudale, with suffucient cooling you can do 8kW with no problem, make sure to install it out side the frame.
Sundrive, yes the last batch of controllers use 6 pin connectors. I dont know why they changed but it could probably be that they could not get 7 pin at the moment.
This is something both me and Adaptto are now regretting.
It does not matter how you connect the halls, autodetect will solve this anyway.
Mine is:
1 - Green
2 - Yellow
3 - Blue
bionicon   100 W
Post by bionicon » May 17 2016 5:01am
Hello i have a mid-e controller it has a 5 pin connector output,and there was a 6 pin connector with it to connect, what doesn't work.
I had to wait till next week before they could send me the rigth connentor so i decide to change the output connector. Strange adaptto use another colorcode on the outputconnector.
Two red and green for the hall sensors and yellow for positive and brown negative, is this normal?
Allex   1 GW
1 GW
Post by Allex » May 17 2016 5:43am
Yes, the colours on the controller side may be different.
bionicon   100 W
Post by bionicon » May 17 2016 5:48am
Hey Alex do you have a charger for me? Dont sure yours will work for me because i am riding on 50 volts (12 S)
Architectonic   1 kW
Post by Architectonic » May 20 2016 4:29am
"OUT OF STOCK" :(
Any word on when you're getting more stock?
Allex   1 GW
1 GW
Post by Allex » May 20 2016 5:02am
Bionicon, sorry Eaton can be programmed as low as 43V and this will be 3,58V per cell at 12s You need a PSU that can deliver 12s*2,5(3)=30V(36V) or lower.
Max-Es are out, Adaptto tells that next batch will be ready in two month :(
Architectonic   1 kW
Post by Architectonic » May 20 2016 6:08am
Allex wrote:Max-Es are out, Adaptto tells that next batch will be ready in two month :(
K, thanks for giving a timeframe.
mudale222   10 W
Post by mudale222 » May 21 2016 11:12am
and vector is 100$ more for the MaxE.. don't know if it was like that before or just now after u ran out of stock.
Allex   1 GW
1 GW
Post by Allex » May 21 2016 1:35pm
Could be because of the big demand but the product is not available -> price go up.
Allex   1 GW
1 GW
Post by Allex » Jul 20 2016 4:44pm
Compadres!
During a limited time you will have a rare opportunity to get a Midi-e controller for as low as 540USD(635USD Retail), thats 15% off the price!
Shipping, BMS and coils are still at the same price.
This is perfect for those who wanted to get a Midi but can only stretch to a Mini :)
I have 7 units and this is my contribution to ES community.
This offer is now expired
Just place an order http://adaptto.envolt.se/Products/Controllers/ and during check out, write "endless-sphere" on the comment field so I know that I need to deduct the correct amount.
You will have to use friendly paypal transfer when paying.
Architectonic   1 kW
Re: SALE Adaptto Controllers, Eaton Chargers, battery packs
Post by Architectonic » Jul 23 2016 5:34am
Max-E still out of stock. :(
Allex   1 GW
1 GW
Post by Allex » Jul 23 2016 1:38pm
Yes they still are :( only minis and midis are available
Allex   1 GW
1 GW
Post by Allex » Aug 16 2016 7:58am
I have one white Flux frame left
And also a few DNM suspention sets, perfect fit for this frame.
Shipping is quite high so I will avoid ship them to countries outside Europe.
Frame: 1200USD
DNM kit: 550USD
Rest is on the page:
http://adaptto.envolt.se/Products/ADDITIONAL-PARTS/
CobraJet   1 W
1 W
Re: Flux frame, Adaptto Controllers, Eaton Chargers, batteri
Post by CobraJet » Aug 16 2016 6:07pm
That is one damn fine looking bike! If it were any closer to me I'd have to pull the trigger on my credit card!
Allex   1 GW
1 GW
Post by Allex » Aug 17 2016 8:13am
Where are you located? I can always hook you up with a US/AUS dealer
We have Hyena in AUS and Probably Rix in US.
CobraJet   1 W
1 W
Post by CobraJet » Aug 17 2016 5:32pm
I'm in Us Ca.
Hyena   100 GW
Post by Hyena » Aug 18 2016 6:53pm
CobraJet, I can hook you up easily.
I sent you a PM.
Alex, these frames are now called FUTR/future - can you edit the title to reflect this so there's no confusion with the 'other' flux.
www.HyenaElectricBikes.com
